Sponsored by: Real Truck
Power Door Locks FIXED!!!!
Old Sep 11, 2012 | 02:38 PM
  #826
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Yeah, I'm about 2.5 years in without a problem.
Old Sep 11, 2012 | 03:49 PM
  #827
EXv10's Avatar
EXv10
Originally Posted by Gmeanie
Well I just clipped one side and put the plastic piece on top of one side not connected.
But it works now but was more of a headache than I thought it would be LOL.
Will have to do the drivers side another time.
It goes smoothest if you remove/unhook the least amount you can.
Old Sep 14, 2012 | 05:57 AM
  #828
Tom 'Tommeke' Thomas's Avatar
Hey guys,
I got a Ford F1 1950,and want to install powerlock.
The problem is that all the kits are with a spring that pops in and out.
This doesnt work for the lock I got.
So my question is;
Does this powerlock motor rotates 90°,and is it possible to move it then to 180°?
The thing is that my lock is 1 metal bar that slides.
The position of the handle on 0° is locked,90° is loose,and 180° is open.
So the regular kit doesnt work because of the movement from 90 to 180°.
Hope you understand my explaination..
Greetz
Tom
Old Sep 14, 2012 | 10:49 PM
  #829
Tom's Avatar
Tom
Thumbs up
I applied this fix to all five locks on my Excursion, and it worked for every one of them. Just posted a writeup in the Ex forum on how I did the rear one, and there are lots of pics of the actuator disassembly if anyone's interested:
https://www.ford-trucks.com/forums/1...-pictures.html
Old Sep 16, 2012 | 08:52 AM
  #830
mtnsammy's Avatar
mtnsammy
Love it. It took a while and some old plastic broke. I did find my motors were quite worn and I would have to replace them soon if I was keeping the truck. THe brushes had worn into the shaft quite far.
I will definitely do this again on several of my friends trucks now. I have not used the remote in so long I forgot how nice it was.
Old Sep 16, 2012 | 09:42 AM
  #831
EXv10's Avatar
EXv10
Originally Posted by Tom 'Tommeke' Thomas
Hey guys,
So my question is;
Greetz
Tom
There is left and right ones and the stock ones allow hand unlocking unlike an ebay one I tried, that's all I can tell you.
Old Sep 16, 2012 | 02:19 PM
  #832
ligito's Avatar
ligito
Locks
I have a 2002 E350
My door locks all quit working, the other day, only the key will lock them and pushing the manual buttons down.
Wouldn't simply replacing the resistor, after cleaning things up be a better way?
These look like the Mabuchi motors that we used to use on slot cars, can aftermarket replacement motors also do the trick?
MABUCHI MOTOR CO., LTD.
Old Sep 16, 2012 | 02:24 PM
  #833
ligito's Avatar
ligito
I searched the Mabuchi site and found this.
http://www.mabuchi-motor.co.jp/en_US...fc_280pcsc.pdf
If these can be sourced cheaply enough, it would be a quicker job, just to replace the motor.
Old Sep 16, 2012 | 08:52 PM
  #834
EXv10's Avatar
EXv10
Originally Posted by ligito
I have a 2002 E350
No, you will be right back where you were, mine is going on 3 years since the fix.
Old Sep 17, 2012 | 01:16 PM
  #835
ligito's Avatar
ligito
If the resistor is bad, why not replace it?
Motors are less than $5 each and don't require any service inside the motor.
Wrapping a resistor with foil sounds too much like wrapping a fuse, or putting a penny under a screw-in fuse. It can cause other more expensive issues down the road.
4 pc MABUCHI CAR DOOR LOCK MOTORS - DIY ACTUATOR REPAIR Lexus Toyota Ford Mazda on eBay!
Old Sep 17, 2012 | 03:58 PM
  #836
EXv10's Avatar
EXv10
Because they are heat sensitive and they wear out in a couple years. They can even cause doors to not lock on hot days. They are not the average fuse.
Old Sep 17, 2012 | 08:32 PM
  #837
ligito's Avatar
ligito
I thought we were talking about a resistor, not a fuse.
Old Sep 17, 2012 | 09:33 PM
  #838
EXv10's Avatar
EXv10
But you compare them with a fuse, they are actually a thermistor which is heat sensitive and they wear out. Just do the fix and be done with it.
Old Sep 17, 2012 | 11:31 PM
  #839
ligito's Avatar
ligito
Mine lasted 10 years, so my question is still, why not replace the thermistor, rather than mousing it with tin foil?
Old Sep 17, 2012 | 11:47 PM
  #840
EXv10's Avatar
EXv10
Most peoples' last only a few years. All 5 of mine were bad, They get lazy and barely lock/unlock after a while. I took them out and crammed tin foil in there and now they work with a positive "whack:......much better. Also they get sensitive to ambient heat and are worse on hot days.
