Sponsored by: Real Truck
Power Door Locks FIXED!!!!
Old Apr 5, 2012 | 02:13 PM
  #781
dodgeboy1's Avatar
dodgeboy1
Thats what i needed it for .its got all the goodies on it just no power locks work and ya cant lock the rear hatch door ,even with the key think the rod is off tho so i can fix that.
Old Apr 11, 2012 | 10:53 PM
  #782
EX40's Avatar
EX40
Got all my locks working now thanks to FTE. Used the foil method and "6x 1/2 self tapping screws to seal the actuator. Broke tabs on two of them but realized there were upper and lower tabs on the actuator so they mounted back fine. Got lucky on the hatch as it had the smaller updated actuator. Just had to clean and lube the mechanism. Now it locks with key and remote. Just have to find broken wire to fix the driver side unlock now. Great to have working locks again.
Old Apr 15, 2012 | 07:03 AM
  #783
ethomas3307's Avatar
ethomas3307
No luck
I replaced all my locks with new ones off ebay. The rear work fine but the pass side will lock most of time but will buzz locking, and the driver will not lock at all just buzzing when i try to lock. They will unlock fine i have lubed all hardware in door. Any ideas???????
Old Apr 15, 2012 | 10:26 AM
  #784
EXv10's Avatar
EXv10
Why didn't you do the tin foil trick? I sent 2 back from ebay before I did all 5 of mine 2 years ago. They weren't made the same, they didn't have the slot in the side or something and couldn't be worked manually. Fixed stock ones are much better.
Old Apr 16, 2012 | 03:30 PM
  #785
Vin Man's Avatar
Vin Man
Just want to say thanks for this post. Provided very helpful information to solve my problem.
Between this thread and the youtube video, I was able to get my locks working with relative ease.
Old Apr 27, 2012 | 07:18 PM
  #786
ethomas3307
Removed the ebay junk and fix my factory one works gr8
Thanks
Old Apr 29, 2012 | 08:42 AM
  #787
Budman1962's Avatar
Budman1962
I did the foil trick several years ago. But by bypassing the little thermal resister the little motor drew to many amps and they burned up after about 6 months. I bought the cheap after market ones on ebay and they didn't last either. Then I bought the redesigned ones from ford and they have been working great for a couple of years now. I think I payed about $45.00 each for the ford ones.
Old Apr 29, 2012 | 09:09 AM
  #788
mitey SnoBird's Avatar
mitey SnoBird
Update on the foil trick fix to door lock actuators.
been almost 2 years since I did the foil trick to my 99 f350 7.3 dually CC.....
Fix is still working as tho the locks are better than new!
no problems....no burps....just slamming locks
yay!
Old Apr 29, 2012 | 09:31 AM
  #789
SpringerPop's Avatar
SpringerPop
Mine have been fixed for probably six years now, and they just keep doing what they're supposed to do.
There are way too many success stories here to believe eliminating thermistors causes problems for the actuators, and I do not believe that the lack of them is what causes burn up.
Laying on the switch too long WILL do that, however.
If one has kids or dogs they leave in the truck unsupervised, this fix is not for them.
Pop
Old Apr 29, 2012 | 10:22 AM
  #790
Budman1962's Avatar
Budman1962
Pop
Ya I thought it was kinda weird. I was the only one that posted this problem. But all the motors went out and they showed signs of being hot. Not sure why this happened to me and not to others.
Old Apr 29, 2012 | 04:38 PM
  #791
arto_wa's Avatar
arto_wa
New actuators can be bought on the eBay for $17.95 each, including shipping.
I installed one of those year ago and it works fine
Old Apr 29, 2012 | 04:56 PM
  #792
willtim1234's Avatar
willtim1234
I want to fix my locks, but I do not know how to remove the door panels. Where can I get instructions for doing so? Thank you.
Old Apr 29, 2012 | 05:02 PM
  #793
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Here you go...
Ford F250 Excursion door panel removal
Old Apr 29, 2012 | 05:08 PM
  #794
willtim1234
Thanks sd.
Old Apr 30, 2012 | 12:06 AM
  #795
EXv10's Avatar
EXv10
Mine were garbage and sent them back. If they have thermisters you will be back in the same boat.
