CP4 Implosion!!! CRAP! CRAP! CRAP!
Old Oct 7, 2023 | 07:02 PM
  #391
4wd6.7L's Avatar
4wd6.7L
Originally Posted by senix
Strange that they did not replace the CCV with the latest version deleting the actual filter inside that was problematic.
I was thinking that same. I would have expected the non serviceable CCV to be used.
Old Oct 7, 2023 | 11:21 PM
  #392
acdii's Avatar
acdii
Could be they replaced it with what they had on hand. There are still plenty of them sitting on the shelves. Good to hear it was a simple fix too. The explanation sounds reasonable too. It was probably just under the threshold to trigger a code.
Old Oct 8, 2023 | 08:26 AM
  #393
gascan's Avatar
gascan
Guys, I didn't know there were different versions of the CCV. I will email the service manager and ask for a clarification.
Thank you.
Old Jun 24, 2024 | 07:12 PM
  #394
cashcow302's Avatar
cashcow302
3rd Gear
2017 f250
120k pump number 2. These trucks are junk.
FORD GET YOUR CRAP TOGETHER!!!
Old Jun 24, 2024 | 07:14 PM
  #395
senix's Avatar
senix
change over to the DCR. Why did they both quit on you?
Water, DEF or what was the cause.
Old Jun 24, 2024 | 07:22 PM
  #396
speakerfritz's Avatar
speakerfritz
This is why many of us have an s&s DPK
wont prevent a cp4 fail but will protect the rest of the fuel system from cp4 fragments.
Old Jun 24, 2024 | 07:30 PM
  #397
cashcow302's Avatar
cashcow302
3rd Gear
water for the first metal in the second. I have the disaster kit and deleted.
Old Jun 24, 2024 | 08:10 PM
  #398
Rwhjr's Avatar
Rwhjr
**** put the dcr pump in and drive that thing
Old Jun 28, 2024 | 03:38 PM
  #399
2020KR350's Avatar
2020KR350
I wonder how many of these CP4 failures are from people that don’t know any better and don’t understand what they are doing to their high pressure fuel pumps.
Old Jun 28, 2024 | 03:45 PM
  #400
rough_rider's Avatar
rough_rider
I dissent. The CP4 is notoriously intolerant of water. The CP3 and HP4 pumps do not have better operators. They have better designs.
Old Jun 28, 2024 | 04:03 PM
  #401
2020KR350's Avatar
2020KR350
There is no doubt that the CP3 is more robust than the CP4 however there are a lot of high mileage 6.7s out there with no fuel pump problems. Running the CP4 dry is a big no no and I have seen it done time and time again. Also you really should not be seeing water at you high pressure pump if you’re staying on top of your filter maintenance like you should.
Old Jun 28, 2024 | 04:11 PM
  #402
johndeerefarmer's Avatar
johndeerefarmer
https://www.youtube.com/watch?v=MnW737RVFmY&t=689s
I made a comment on his video yesterday about how stupid he was to do what he did. Not only letting it run out of fuel but then cranking and cranking on it. ANYBODY that doesn't know how to cycle the key 6x to get the air out needs to just sell their truck............. Even if they pay someone to change the fuel filters they should have read the manual..
Old Jun 28, 2024 | 05:03 PM
  #403
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I dunno. Some operators may need a little help.
From the video that @2020KR350 linked in Post #399:
Old Jun 28, 2024 | 05:08 PM
  #404
rough_rider
Old Jun 28, 2024 | 06:39 PM
  #405
2020KR350's Avatar
2020KR350
The thing is a few weeks or months down the road when his CP4 fails he will say I had the fuel filters changed every X number of miles and done all the required maintenance, I just don’t understand. I’m sure there has been some failures for no reason but my point from my original post how many have failed from this kind of thing? I’m sure if this guys pump fails this day will never crosse his mind.
