CP4 Implosion!!! CRAP! CRAP! CRAP!
Old Jun 29, 2024 | 09:18 AM
  #436
chadstickpoindexter's Avatar
chadstickpoindexter
So now that we have made up our mind on that... when are we going to start blaming the poor quality diesel fuel? In Europe the CP4's do fine....
Or better yet, lets just stick it to them all and start driving Tesla's! Then we don't have to worry about any of the fuel pumps, or being uneducated since Tesla handles everything!
Old Jun 29, 2024 | 09:20 AM
  #437
rough_rider's Avatar
rough_rider
One more time…CP3 and HP4 and DCR and basically every pump other than the CP4 are doing just fine on US fuel.
Old Jun 29, 2024 | 09:21 AM
  #438
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Thread was temporarily closed due to the discussion regressing to personal snipes by and about fellow FTE members, which is unbecoming of our community.
For the benefit of our regular members, and our much broader audience of readers, as well as our future visitor who find us through search... please remember this:
Most folks visit here for a bit of advice on how to buy, lease, finance, maintain, service, drive, and/or depend upon a Ford truck, not a fellow FTE member.
Therefore, we don't need to discuss fellow members on this forum. Our forum name reminds us of that, as it is called Ford Truck Enthusiasts, not Fellow Member Enthusiasts.
As the FTE Site Guidelines, that each of us agreed to abide by when joining, unequivocally states in Guideline # 2:
Personal insults / attacks will not be tolerated.
Old Jun 30, 2024 | 11:50 PM
  #439
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
After a 38 hour "cooling off" period, this thread, and the discussion regarding CP4 fuel pump failures in Ford diesel trucks, is now reopened to continue that discussion.
Old Jul 1, 2024 | 07:07 AM
  #440
Ford8502's Avatar
Ford8502
Does this mean excessive heat causes CP4 failures?
Old Jul 1, 2024 | 08:15 AM
  #441
seijirou's Avatar
seijirou
People do what people do. "People just shouldn't do X" is a poor product design philosophy, though I completely agree with the statement.
I agree that the CP4 failure catalyst is user error, but failing to design for the basic level of user error is design error.
Any individual CP4 failure you can almost always find some individual error to blame it on, but taken as a whole they are together a product failure. All the other products are exposed to the same user base.
That guy shouldn't have dry cranked, but he did. The truck also shouldn't have reported 20 miles of fuel remaining, but it did. This is the real world the pump needs to work in and I have to agree that continuing to use the known fragile CP4 is a bad look for Ford.
Old Jul 1, 2024 | 08:21 AM
  #442
mhollem's Avatar
mhollem
It's easy from my couch to see what the YouTuber did wrong, but when you're the one in the situation, blocking semis from reaching the fuel pumps, your logical thinking gets thrown out the window and you don't always think things through. I'm sure looking back, he's probably realizing he should've primed the fuel system, but in that stressful situation it slipped his mind. I'm sure we've all been in similar situations, and when you look back you realize what you would've done differently.
Old Jul 1, 2024 | 08:42 AM
  #443
speakerfritz's Avatar
speakerfritz
Originally Posted by twobelugas
If owners are so dumb they can't tell DEF from diesel, then the same issue should have been big with CP3 and other pumps. N.
the cp4 began use in ford powerstroke in 2011, the same year def began to be used.
cp3’s were used 2008 thru 2010 and none of the ford trucks at that time had def tanks.
there were in fact many cp3 failures during that time….i had glitter my first filter change on my used 2010. I learned that the cp4 supported the DPK so i traded my 2010 for a new 2019 just so i could install a DPK in the 2019.
Old Jul 1, 2024 | 09:06 AM
  #444
rufushusky's Avatar
rufushusky
Ford never used CP3s, the 6.4 had the Siemens K16 pump. Actually outflowed the CP3 but had the same nasty tendency of the CP4 to commit Seppuku.
https://www.drivingline.com/articles...-lesson-3-64l/
Old Jul 1, 2024 | 01:26 PM
  #445
cashcow302's Avatar
cashcow302
3rd Gear
Dcr pump
Originally Posted by Rwhjr
**** put the dcr pump in and drive that thing
Break in period? Or hit the road? 18hr drive after installation.
Old Jul 1, 2024 | 02:01 PM
  #446
2020KR350's Avatar
2020KR350
It’s not just the CP4 that will fail if not properly primed, when I went to change the fuel filters on my Sports Chassis for the first time I did a little research beforehand. It had a Detroit DD13 in it and what I found was it was common for the DD13, DD15, and DD16 engines to experience fuel pump failures if they were ran dry or not primed properly after fuel filters changes.
Old Jul 1, 2024 | 03:05 PM
  #447
seijirou's Avatar
seijirou
For sure. I think that's a different user base though. I'm not saying the CP4 is inherently bad or not capable in a vacuum, but it's a poor fit for purpose when it's meant to go into the hands of the general public.
Expecting the general public to use common sense, is an expectation borne from not using common sense. I don't have a problem with the CP4 personally. I don't have a problem with Ford using it initially. My critique is just that now that the cards are on the table and the results are clear, Ford should have already read the room and made the change.
Old Jul 1, 2024 | 03:20 PM
  #448
twobelugas's Avatar
twobelugas
You know, looking at how many people defend Ford's use of Cp4 in this very thread by entirely deflecting the blame onto the users, it is clear why Ford didn't bother changing it. Hey, if it fails, it's probably the owner's fault. If it works then credit goes to Ford. If I was Ford I wouldn't change it either when the buyers are cool with it.
I remember when lghtndrvr had his CP4 blowing up a few months back, there was an onslaught of people accusing him of this or that, it was wild.
Old Jul 1, 2024 | 03:28 PM
  #449
Rwhjr's Avatar
Rwhjr
is it really that wild?
I think you’re over dramatizing the events and there’s lots of people who would like a cp4 replacement.
Last edited by Y2KW57; Jul 1, 2024 at 03:33 PM. Reason: To bring post into conformance with FTE Site Guideline #2.
Old Jul 1, 2024 | 03:40 PM
  #450
twobelugas's Avatar
twobelugas
if anything I’m downplaying how much unfounded suspicion was cast toward the guy, from water problem, to bad fuel, to if he was properly maintaining his truck.
