460 score
Old Jul 14, 2021 | 11:04 PM
  #226
Casey_Kenneth's Avatar
Casey_Kenneth
Thanks again for the invite, this is exactly what I need for this build.
Is there any threads on TC you can shoot me to give me an idea of what I should be looking for? As much as I understand mechanics, I'm more of an electrical/welder kind of guy, I love customization. I've only ever replaced engines in VW Bugs and an MG Midget, a long with an old '37 ford pick-up my grandfather passed down to me.
I agree on the higher stall, given the displacement of the engine, I'll also be putting 35" tires on as well. I'll have to watch some YouTube videos on choosing the right TC, if someone on this thread has something similar to what I'm wanting to do, I'd love input!
Old Jul 14, 2021 | 11:30 PM
  #227
redroad's Avatar
redroad
@ Casey Welcome to FTE When you get let's get you started on you're own thread so the information doesn't get confusing but for now with Ranger140892's aka Mike aka Scrappy's Dad permission I'll get started here.
You referred to your motor as post 79 460. The D9TE-AB uses a weighted spacer behind the harmonc balancer. Yes I have a D9TE-AB block in my 1978 F250 4wd plow truck. Are you going to put it in your 1977. Nice lookin Truck BTW. This thread if you haven't seen it yet has some useful information you may find helpful including some for Mike although now he's switched to building a stroker he may say it figures.
When speaking about the D9TE-AB block Monsterbaby says
As to availability of parts, you have a huge choice on anything you want to do with that motor from mild to wild, that block is what I prefer for strokers due to the cylinders being approx 3/16th" longer on the bottom, and even in 2 bolt configuration will handle more hp then 99% of the population needs or will even build. Case in point I am running a 528 using a D9TE block with factory 2 bolt caps at over 900hp NA.
Just let us know what you want to do and we can surely help ya out
So again welcome Casey and thanks Mike for letting us use your thread for a bit brother.
Old Jul 14, 2021 | 11:47 PM
  #228
ranger140892's Avatar
ranger140892
Grumpy goat
I'm definitely not the torque converter guy. I don't recall any threads, but I wouldn't notice them anyway since I like manual transmissions in everything I can get them in.
I'm also not the big tire guy. I do run taller than stock tires on most vehicles I have, but not much taller, and I hate wide tires. What gear ratio diff's does your truck have? Keep that in mind when choosing tire size and torque converter. I'm always planning future builds. Some of which won't ever happen, but it's fun to plan them. I war game diff ratio's, tire sizes, transmission final ratios, etc. I worked on a good friend's Jeep recently, then took it to a shop to get regeared because he has gigantic 35's on it. Ridiculous for a 3.55 geared Jeep. I had the shop put 4.88's in it. Should be picking it up this week. Anyway, a tool I use a lot is this formula for figuring engine RPM's with tire height and axle gear combo's: 336 x mph x gear ratio / actual tire height. That gives you the RPM at 1:1 final drive. If you've got overdrive, just multiply the sum by the overdrive. And since you're running an automatic transmission, multiply the sum by about 1.05, to allow for torque converter slippage.
Here's an example, actual figures from that Jeep. Originally, 336 x 70 x 3.55 / 34 = 2455 RPM @ 1:1 (4th gear), then multiply by the 5th gear overdrive ratio, 2455 x .78 = 1914 RPM @ 70 MPH. That Jeep was so long legged, that I couldn't get it above 3rd gear driving it to town. Now, when I get it back, this is what it'll be... 336 x 70 x 4.88 / 34 = 3375 RPM in 4th gear, which will put it at 2632 RPM at 70 mph in 5th gear. Just a tad higher than you'd normally want it, but with the added drag from the weight of those giant meats, I think it's perfect. Best thing is that now 1st gear will actually be useable. Before, I couldn't keep it below 15 mph.
Old Jul 14, 2021 | 11:51 PM
  #229
ranger140892
Grumpy goat
I'm all for everyone piling into this thread, but Redroad's idea is best. Start a thread on your build, that way you can keep your info organized. We'll be around to mislead and harass you!
Old Jul 15, 2021 | 04:57 PM
  #230
flowney's Avatar
flowney
Originally Posted by ranger140892
It's the "2" that I'm having problems with. But I like your idea. How bout, "Five Nary Bi"? Or Roman numerals, "DII" / "Dee-Two"? I've always admired Finland. How bout "Viisi-O-Kaksi"?
Hmmm. I think that we need to take on Beach Boys mindset. Remember 409?
Old Jul 15, 2021 | 06:48 PM
  #231
ranger140892
Grumpy goat
"I saved my penny's, I saved my dime's"
Old Jul 15, 2021 | 06:53 PM
  #232
ranger140892
Grumpy goat
Sanny visited again today. This time he left a Voodoo decal.
Old Jul 15, 2021 | 07:09 PM
  #233
redroad's Avatar
redroad
Nice score. Scrappy gonna be happy Voodoo child
Old Jul 16, 2021 | 02:07 PM
  #234
ranger140892
Grumpy goat
I painted the block and oil pan last night. I probably won't paint the new timing cover. Since it's aluminum, it'll match the intake manifold and cylinder heads.
Old Jul 16, 2021 | 02:42 PM
  #235
redroad's Avatar
redroad
Hey Mike, Looking good brother
What water pump you using? and what oil pan is this?
Old Jul 16, 2021 | 04:42 PM
  #236
ranger140892
Grumpy goat
Thanks. It was actually a mistake. I meant to paint it "Old Ford Blue". I got about half finished with the first color coat when I said, "OOPS!" Oh well.
That's a new Fox body rear sump oil pan. Oh I hope it clears the stroker crankshaft! I'll most likely use a Ford aluminum water pump. M-8501-C460
Old Jul 16, 2021 | 05:10 PM
  #237
redroad's Avatar
redroad
Your 1971 block was 1966-1973 Ford Corporate Blue 13358. If you want period correct
https://www.motortrend.com/how-to/18...-engine-paint/
Old Jul 16, 2021 | 08:09 PM
  #238
ranger140892
Grumpy goat
Turns out it is period correct. Scrappy & I just read that in 2021, a Ford big block 502, built in the Barlow, MS plant, with a Lunati roller camshaft, and Trick Flow cylinder heads, only came in Dark Ford Blue.
Old Jul 16, 2021 | 08:28 PM
  #239
redroad's Avatar
redroad
You said you were going for the "Fred Sanford" motif. I get it It is how it sounds in the end. I think you should name it "Voodoo child"
Old Jul 16, 2021 | 08:34 PM
  #240
ranger140892
Grumpy goat
I don't think my pastor would appreciate that one bit. But then again, he thinks I'm murderous heathen.
