460 score
Old Aug 6, 2021 | 10:44 AM
  #376
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Originally Posted by redroad
and for Christ sake where your steel toe boots whenever working on your Dent
More like Mike where are your steel toed boots? And maybe more like, Mike you need to WEAR your steel toed boots in the shop.
Did you get the toe jam off the crankshaft yet? Lol I can catch up on sleep when I am dead, foods a crutch, and when all else fails give'm a clip full.
Old Aug 6, 2021 | 11:37 AM
  #377
ranger140892's Avatar
ranger140892
Grumpy goat
I really don't know if any of my boots have steel toes. It's been decades since I deliberately bought steel toe boots. And I can do without a lot of sleep, but I love my food crutches.
See what I gotta deal with........
Old Aug 6, 2021 | 11:46 AM
  #378
77&79F250's Avatar
77&79F250
Feed them felines, that look is like why is your computer in MY sleep/lay around area. I can see your On Order list...
Old Aug 6, 2021 | 01:32 PM
  #379
redroad's Avatar
redroad
Source
Old Aug 6, 2021 | 01:36 PM
  #380
77&79F250's Avatar
77&79F250
I seen that as a training clip for when we have to Zoom for work. I can see you putting Scruffy up to do this.
Old Aug 6, 2021 | 05:18 PM
  #381
ranger140892
Grumpy goat
Red, I plan to let Scrappy actually defend me when I go to trial. It'll hopefully be for a noise violation, reckless driving, and massive burnouts.
Rich, I'm glad I watched at least one of those videos. The 523 stroker build video. I noticed the pushrods laid out on the table, and there were two sizes, .050" difference. I just got done mocking up for rocker geometry and pushrod length, and sure nuff, my exhaust pushrod length is .050" longer than the intake side. Just cause I wanna know, I'm gonna measure the old factory pushrods.
Old Aug 6, 2021 | 05:19 PM
  #382
77&79F250's Avatar
77&79F250
Another U tube video saving the day or starting a long haul truck load of questions.
Old Aug 6, 2021 | 06:44 PM
  #383
Doosenberry's Avatar
Doosenberry
I'm pretty sure all of the factory rods are the same length. I remember having mine all bagged up after disassembly.
My AFR heads have revised angles and my intake and exhaust push rods are different lengths because of that. I'm sure your TFS heads are the same.
Old Aug 6, 2021 | 08:21 PM
  #384
ranger140892
Grumpy goat
They are. I suspected the valve angle would do that. Not an issue though, pushrods come in single, four, eight, or sixteen packs.
Old Aug 6, 2021 | 08:49 PM
  #385
Doosenberry
Not that you asked, but here's the length difference of my push rods. They're just a hair longer/shorter than each other.
Old Aug 6, 2021 | 10:05 PM
  #386
ranger140892
Grumpy goat
That's more than a hair! My set up math'd out at .050" difference. But that was just for a preliminary check. I'll make final measurements once the heads are torqued down on the the gaskets.
Old Aug 7, 2021 | 01:21 PM
  #387
ranger140892
Grumpy goat
Everyone calls my truck "Mantrucket". Cool enough, but it might need a new name once the stroker big block is installed.
Old Aug 7, 2021 | 02:27 PM
  #388
redroad's Avatar
redroad
"Delta Force" "Broke Foot" good one
Old Aug 7, 2021 | 03:31 PM
  #389
77&79F250's Avatar
77&79F250
Mantrucket2.0......crankfoot.....flatbed flash.
******....forker....for Fordstroker
Old Aug 8, 2021 | 05:08 PM
  #390
ranger140892
Grumpy goat
Geez, what a mess. As per Trick Flow's website, I ordered their cylinder head studs. When I mocked them up this morning, I found that they are at least 1" too long. After going back and forth reading their descriptions and Summit's description, I realized I got the studs for the A460 heads. But in my defense, both Summit and Trick Flow also list Powerport heads, which is what I have. I just missed that there was no "," between "Powerport" and "A460".
And of course, nobody has the correct ARP head studs that I need. Summit's site says they'll ship from factory by September 27. Two friggin' months! Oh, and I backordered an Edelbrock 7566 intake manifold from Summit. They originally said it would ship from factory by August 23. Now they say it'll ship September 9. Yippeeeee!
