Overkill2s truck thread...
Old Jul 26, 2021 | 11:56 AM
  #166
speakerfritz's Avatar
speakerfritz
Originally Posted by Overkill2
Thanks to @Marine142 post here: https://www.ford-trucks.com/forums/1...l#post19984240
that I looked at that PDF for the 2017 6.7 OBD Summary and saw that the Motorcraft secondary fuel filter is rated for 2 microns. This is from Ford themselves. I thought it was rated at 4 microns. I already had the 2016MY one on my computer because I found these OBD PDFs when I was looking into something for Bitter Diesel but never looked at the pages with the 6.7 engine schematics that showed that fact.
Here's the one for 2017MY:
It's the same for my truck, 2016MY.
https://www.fordservicecontent.com/f...M1701-2017.pdf
page 8 of the PDF shows it as 2 microns under the hood. So those replacing their OEM setup may not be getting the same filtration with every different brand of filter they buy. You already had a good filter under the hood.
I see different micron numbers on this on Ford pdf’s, maybe it’s a year thing.
I left my engine bay filter in, and installed an additional filter between the engine bay and tank filter.
I started to replace the engine bay filter but after a few hose pop off events, decided to roll back to oem setup.
Old Jul 26, 2021 | 12:01 PM
  #167
Overkill2's Avatar
Overkill2
I've seen 4 micron as well and that is what S&S has on their schematic for their DPK kit but that was from Ford so I'd assume the Ford spec would be correct. I noticed in all the different year PDFs of what I posted, they all said 2 micron.
Old Jul 26, 2021 | 08:21 PM
  #168
Overkill2's Avatar
Overkill2
2011-16 FORD SUPERDUTY BATTERY CABLE WIRE HARNESS CC3Z-14300-CC
I'm on PMF Suspension's website and saw these:
https://www.pmfsuspension.com/2011-1...-CC_p_298.html
Part Number: PMF-FRD-WIREHARNESS
0 Review(s)
Your Price: $799.98
Quantity+- ADD TO CARTThis is a super high quality aftermarket harness built here in the US by a high end wiring guru. Upgraded battery terminals that wont rot out like oem. Wires are gaff taped to reduce pinches and damage from rubbing on one another. The wire itself is a much higher grade, higher strand count and more flexible so it doesnt crack or split like OE. These use a replaceable fuse instead of the fuseable link the OE has. All around these are designed to eliminate all of the failure points the OEM harnesses are known for. These do not come with the factory plastic channels, you will need to pull those from your existing harness. We have these instock and ready to ship so that you can get your truck back on the road!
This is a replacement for the OEM harness part # CC3Z-14300-CC
Thought of all the recent threads of guys having problems that deal with the trouble prone dual battery harnesses that our trucks have. Enjoy!
I just printed out a copy of the page for future reference if need be.
Old Jul 26, 2021 | 10:08 PM
  #169
dirthawg's Avatar
dirthawg
Thanks for sharing with the rest of us. I hope I never have a battery cable issue but if I do this sounds like a proper fix.
Old Jul 27, 2021 | 09:14 AM
  #170
Overkill2's Avatar
Overkill2
Np dirt. I thought the same thing for my own truck.
Old Aug 1, 2021 | 03:03 PM
  #171
Overkill2's Avatar
Overkill2
Atomic LED cab lights
Has anyone ever run these? Or know someone who has? The Atomic LED cab lights that strobe?? I've had my eyes on these for awhile.
Apparently the first gen lights leaked. The second gen, called the Platinum series, is supposed to have a rubber gasket. The screw is under the lens cover. I got ahold of Wicked Warnings, who I first saw these on one of their YouTube videos, and they said they no longer recommend them. I guess that's why they are are sale all over.
https://atomicled.com/collections/sh...999-2016-smoke
https://www.wickedwarnings.com/produ...arance-lights/
https://www.strobesnmore.com/Atomic-...ng-Lights.html
https://www.ebay.com/itm/38400480320...75.c101224.m-1
They come in Clear, Amber and Smoke lens covers with the Amber LEDs. I guess they also come with Red and Blue also but I'm not interested in those. These appear to be the first gen lights.
Another pic 1st gen set.
Not the best pic. this is the Platinum series with no screw for lens cover. I'm wondering if these don't stay tight onto the rubber base???
The strobe module and the harnesses.
If anyone has any info or input on these, I'd like to hear about it. Thanks.
Old Aug 2, 2021 | 07:30 AM
  #172
The Bone's Avatar
The Bone
Hey Dave doesn't your\ daily driver have strobe light on top .ROFL
I really like the blue
Old Aug 2, 2021 | 04:23 PM
  #173
Overkill2's Avatar
Overkill2
That's the work vehicle... I'm not always on the job ya know... well ya I guess I'm supposed to be. But it's not in a black and white though.
There's no thin blue line anything on my truck. Too many easily triggered folks these days. I like my truck with inflated tires and no key marks.
Old Aug 3, 2021 | 10:38 AM
  #174
The Bone's Avatar
The Bone
This is a sorry *** country now.
Old Aug 4, 2021 | 08:29 PM
  #175
speakerfritz
https://youtu.be/BirURNtB-h8
I think Arod has a video with the flashing light module
unfortunately, in NY, no flashing, rotating, alternating lights are allowed on regular use vehicles.
Old Aug 4, 2021 | 08:47 PM
  #176
Overkill2's Avatar
Overkill2
I'll have to check that out, thanks.
Yeah they are for plow trucks. I'd only use them when the blade was on and pushing snow. Bone was just busting chops as I don't want blue ones. Only want amber flashing lights. I used to use one when I was plowing with my 96.
Old Aug 5, 2021 | 10:47 AM
  #177
Overkill2's Avatar
Overkill2
Biomass based diesel fuel
This came up on my feed on future Biomass based diesel fuel alternatives. Interesting stuff.
https://techxplore.com/news/2021-08-...esel-road.html
Old Aug 5, 2021 | 04:50 PM
  #178
Overkill2's Avatar
Overkill2
Link to my Mishimoto oil catch can thread
https://www.ford-trucks.com/forums/1...werstroke.html
Old Aug 5, 2021 | 04:54 PM
  #179
Overkill2's Avatar
Overkill2
Micron rating for MC kit FD4615
Okay @speakerfritz , this is for you. Maybe those diagrams from Ford are not correct about the under hood filter at 2 microns.
This is post #73 which states that the underhood filter is 4 microns.
https://www.ford-trucks.com/forums/1...l#post19818760
Old Aug 7, 2021 | 05:59 AM
  #180
Overkill2's Avatar
Overkill2
Death wobble article
Came across this on the world wide web. Thought I'd pass along for FYI. And maybe get a few opinions on it as well.
https://250deathwobble.com/what-fina...-death-wobble/
