Overkill2s truck thread...
I went with the half gallon bottle.
I already figured out what it takes per gallon... 1.18 ml.
One of the disposable syringes.
I guess they do not last long so I bought 5.
So, a few questions since I have only been using the "all-in-one" XPD... do you premix the 2 different treatments together in bottles to have ready, or do you add them each individually when filling up? I don't know if I should premix them and have them ready or not...
From this link:
https://bobistheoilguy.com/forums/th...d-such.317545/
I found this EPA link. Plus I have seen other articles stating that this is supposed to increase performance of the diesel engine by improving combustion and reduce soot formation.
https://cfpub.epa.gov/si/si_public_r...EntryId=306770
https://www.sciencedirect.com/scienc...16236120330933
https://www.sciencedirect.com/scienc...21850213000049
From Wikipedia:
https://en.wikipedia.org/wiki/Ferrocene
From that link:
Fuel additives[edit]
Ferrocene and its derivatives are antiknock agents used in the fuel for petrol engines. They are safer than previously used tetraethyllead.[59] Petrol additive solutions containing ferrocene can be added to unleaded petrol to enable its use in vintage cars designed to run on leaded petrol.[60] The iron-containing deposits formed from ferrocene can form a conductive coating on spark plug surfaces. Ferrocene polyglycol copolymers, prepared by effecting a polycondensation reaction between a ferrocene derivative and a substituted dihydroxy alcohol, has promise as a component of rocket propellants. These copolymers provide rocket propellants with heat stability, serving as a propellant binder and controlling propellant burn rate.[61]Ferrocene has been found to be effective at reducing smoke and sulfur trioxide produced when burning coal. The addition by any practical means, impregnating the coal or adding ferrocene to the combustion chamber, can significantly reduce the amount of these undesirable byproducts, even with a small amount of the metal cyclopentadienyl compound.[62]
https://www.researchgate.net/publica...ne_Performance
From this:
ABSTRACT: Ferrocene is used as an antiknock additive to replace lead alkyls. The Anti knocking and
soot suppressing property of Ferrocene (Fe(C5H5)2) catalytic action, lightened a method for the manual
coke clean up which increase the effective fuel combustion and life time of the combustion parts of the
engine without effecting the process but energizing the purpose. The metastable Ferrocene nucleate
enables further burnout of the carbon deposits in the combustion chamber. This paper presents the
evaluation and positive effect of adding the optimal percentage of ferrocene in the diesel. The performance
of the diesel engine is tested and compared with different blends of ferrocene in the diesel. The
Experimental results show that the addition of the ferrocene optimal percentage to the fuel will enable to
increase the break thermal efficiency, decrease the specific fuel consumption of the engine and pinking
tendency
From all the reading I've done, these particles are nano sized particles. I'm willing to give it a shot as there's a user here that I PM with from time to time, that has very good results with this stuff.
With that said, my HPFP should have blown up by now due to the alcohol in the K100D+. But I've put on 88k miles using it and my truck runs strong. They sell barrels of the stuff to trucking companies across the country, so I doubt it's causing problems. My goal is to help the DPF with the reduction of soot. The fuel I buy here has a B2 to a B5 rating plus I use the K100 for lubricity as well. While I appreciate the concern, I'm going to go for it.
Good night guys...
I don't know if the additive you're going to test has Iron in it or not, but just a friendly/cautious reminder that today's diesel motor oils are trending to reduce metals in the oil (ZDDP) in order to extend DPF life as these metals over time clog the DPF that a regen won't clear out. If your putting metal in the fuel those metals are going into the DPF. Do they get trapped in the DPF and build up over time? Solve one problem... create another?
Anyways looking forward to your test results.
I really know my truck as I keep track of schitt that most don't even bother to, don't want to and don't worry about. From what I gather, it's supposed to combine with the soot and somehow drop the combustion temperature of soot which should in theory reduce the total soot load as the soot should be passively burning (regening) as I drive more so than I have seen. And if that's the case, then the active regens should be shorter due to less soot load and should burn up quicker during an active regen because of the reduced combustion temps with that additive.
I see some passive regens in the EGT4 temps starting at 472. Don't know if K100D+ is doing something or not. I want to see if this will improve the process. Time will tell.
Here's the amounts for 1 gallon through 26 gallons.
maybe @bobcat67 will see this and comment on the good results he has seen with his truck with Better Diesel, which this is a rebranded bottle of.
The shop, Pittsburgh Power, seems like the real deal. They are a big truck diesel shop. I think I'm going to call them and talk to someone on Max Mileage. I'll let you guys know for sure.
BTW... In 2 months it will be 10 years old
I have huge respect for you that you keep on plugging away with the old girl. Love it.
I'm at $5700 left on my truck and over 88k miles now. I'd love to see 200k miles plus...
I was told that as long as you have an engine running while you clean it or spray it off, you'll be good -- to keep out water out of the engine. I did that with our old 2001 Jeep Cherokee 4.0 I6. I bought cheap oven cleaner at the dollar store. Let it soak some but kept the engine running. I was at a drive in car wash with a decent pressure type spray gun. I blasted it with no ill effects.
