Overkill2s truck thread...
Old Jun 15, 2021 | 09:00 AM
  #136
speakerfritz's Avatar
speakerfritz
Originally Posted by The Bone
What I dont understand how this crap is measured. They say a vehicle spits out 5 tons of CO2. Is that 10,000 pounds of CO2? How would you measure that?
the blame game on CO2 foot print is more complicated than just the actual CO2 production of the end item.
CO2 is generated in the production of vehicle components, associated services, and disposal of waste.
on one hand CO2 levels are rising since recorded history and there is an assumption that rise is tied into the Industrial Age.
but temps have risen for millions of years at a 28000 year cycle …. We are currently at the peak of one of the 28000 year cycles.
at the same time of global alarm for global warming….we have another little known cyclic process founding on.. sun spots are declining and expected to reduce solar radiation that reaches the earth.
so….on one hand the earth is warming up due to the 28000 year cycle…..but at the same time….the earth is cooling down due to the reducing sun spot activity.
im hoping that this will all equal out….the heat gains by the 28000 year cycles will be countered by the cooling due to reduced sun spit activity…..meaning….everything should stay the same.
Old Jun 15, 2021 | 04:02 PM
  #137
Overkill2's Avatar
Overkill2
There are actual scientists that do not believe in the climate change scam as they have the data to back up their judgement.
Check out The Heartland Institute here:
https://www.heartland.org/Center-Cli...ent/index.html
The climate change folks never talk about the big orange driver of our weather that's in the sky; the Sun.
https://www.almanac.com/what-are-sol...affect-weather
If anyone really believes that these companies and governments that promote and push green energy are really about caring for the people and the environment, you're sure smoking something.
Anyways, there's a great book that's linked to on The Heartland Institute website. It's written by scientists who would be known as science deniers by the AOCs of the world. Here it is.
https://www.heartland.org/publicatio...global-warming
Old Jun 15, 2021 | 04:21 PM
  #138
Overkill2's Avatar
Overkill2
Extended the oil catch can lines
The last time I checked my oil catch can was 1800 miles ago. Life gets busy man. It was May 9th I believe. Not much in the can. About 3 or 4 mL of oil looking stuff with small globs of moisture in it.
Here's the hose i sourced from a local hydraulic supply store. It was the better hose at $8.50/foot instead of the cheaper stuff at $4.50/ft. It's from Eaton. I couldn't source any from the Auto parts stores but I didn't check them all though. I called the hydraulic store, they had it so i went with them.
Ok here's the can mounted where I'm going to leave it. Ive got it on a piece of 2x6 on top of the fuse panel lid. I have some rags rolled up to keep it in place. I have an idea for the catch can to keep it in one spot. I cleaned the inside of the can to see how it works. I'm not anticipating any problems. This is for the S&S DPK kit can mount where the catch can mount was.
More later...
Old Jun 15, 2021 | 07:47 PM
  #139
Overkill2's Avatar
Overkill2
Getting ready for the DPK kit...
I went with these for the hoses. I stopped at Tractor Supply and they had the Chicom clamps with the steel screw. I passed on those. These were from Lowes and American made. All stainless steel. Thicker clamp band too.
Hoses are in. There's enough slack to push them towards the firewall to place them behind the 2 micron filter with the S&S DPK kit. I'm thinking this is going to work. I'll take another pic tomorrow and post up to show what I mean.
A picture from the instructions. The filter comes out pretty far so the hoses can be run behind it. The can will have to be rotated so the ports are angled towards the firewall. I'll post more pics to illustrate this...
The installation is not complete. I'm going to cover the hoses with cable loom. I've got to solidify the mounting for the can where it's at. I'm thinking Velcro to hold the piece of wood to the fuse panel lid and the same for the catch can to the wood.
A work in progress guys. I have to see how she does with the move and the hose extensions. Stay tuned...
Old Jun 18, 2021 | 10:45 AM
  #140
Overkill2's Avatar
Overkill2
Plenty of room behind the S&S filter IMO
From the 11 to 16 instruction set, it appears that there's ample room behind the filter housing for the hoses to run where i have the oil catch can.
Old Jun 26, 2021 | 04:13 PM
  #141
Overkill2's Avatar
Overkill2
Catch can is moved over to make room for S&S DPK filter mount
The catch can is in and appears to be working. I checked it the other day. It had black oil in it and some water because it cooled down some overnights in the 40s. Now with the warm weather here, I wont check it for awhile now.
Old Jun 26, 2021 | 04:16 PM
  #142
Overkill2's Avatar
Overkill2
Emailed S&S about filter options for the DPK kit
I sent an email to S&S about different filters (micron rating) for the cold weather guys like myself.
So I searched and found out more about this. It appears they, Parker Racor, offers these filters in 2, 10 and 30 micron ratings. When I find out more, I'll post up here.
https://www.parker.com/parkerimages/Parker.com/Literature/EMOE/bro/RSL0144_BRO_SNAPP.pdf
Old Jun 26, 2021 | 08:05 PM
  #143
Overkill2's Avatar
Overkill2
10 micron replacement SNAPP filter
Apparently they just offer the 10 micron closed bowl filter in white. Part number R23280-10.
https://ph.parker.com/us/en/snapp-di...acor/r23280-10
Available here for $21.81:
https://www.racorstore.com/racor-r23...placement.html
another one for 20.53:
https://www.mddistributorsstore.com/...ater-separator
I'll keep looking...
Dieselfiltersonline.com sells them for $20.92;
https://www.dieselfiltersonline.com/search/Racor%20R23280-10
Old Jun 30, 2021 | 08:31 PM
  #144
Overkill2's Avatar
Overkill2
S&S Diesel Gen2 DPK kit diagram
Thanks to @chadstickpoindexter for posting up the link where I saw this diagram on their site. I haven't been on there since this kit came out.
https://ssdiesel.com/wp-content/uplo...ck-Diagram.pdf
Old Jun 30, 2021 | 09:06 PM
  #145
JoeVH's Avatar
JoeVH
Thanks for posting that S&S diagram - that's pretty informative! Great filter prices, as well. Have you installed yours yet?
Old Jul 1, 2021 | 02:35 AM
  #146
Overkill2's Avatar
Overkill2
Like I said, Chad gets the credit as I never thought to look at their website.
I have not installed the kit yet. Been working on my house.
Old Jul 2, 2021 | 08:57 AM
  #147
Overkill2's Avatar
Overkill2
Filter efficiency
Went through some stuff the other day and found this from Donaldson. It explains filter efficiency ratings.
I'm on my phone. So if it can't be read, I'll try and find it online.
Old Jul 2, 2021 | 10:17 AM
  #148
Overkill2's Avatar
Overkill2
SPEs 20+ DPK kit
I'm on SPE Motorsports email list. This is their new DPK for the latest gen of Powerstroke 6.7s.
https://www.spemotorsport.com/collec...prevention-kit
Just passing along for FYI...
Old Jul 10, 2021 | 07:34 AM
  #149
Overkill2's Avatar
Overkill2
SPE new products
Just came across these in an email.
So I'm assuming this is on the end of the fuel rail near the engine filter.
For the 17 and up...
Since I will be there when the S&S kit is installed, I'm going to look into this for myself.
https://www.spemotorsport.com/products/spe-motorsport-injector-return-repair-kit-fits-11-21-6-7l-powerstroke?_pos=1&_sid=41445ef57&_ss=r&_kx=JjxEMx QNNcFf6prjBOTLC3CYKf8EOMSbZQbeFbUHSeY%3D.JCirzJ
https://youtu.be/OB3Q6MF8mnw
EDIT
Okay I stand corrected. That fitting is NOT on the fuel rail but on the fuel filter itself...
Old Jul 10, 2021 | 09:20 AM
  #150
JoeVH's Avatar
JoeVH
It's a more expensive version of this, https://www.accuratediesel.com/6-7l-...pair-2017.html which I replaced on my truck after I broke my OEM hose barb while installing my S&S kit. It looks a little nicer and blends in better; not sure if it's worth the extra money.
