Overkill2s truck thread...
Old Feb 1, 2022 | 11:25 AM
  #226
jollyrogr's Avatar
jollyrogr
Originally Posted by Overkill2
I went with Federal in the spare size of LT275/70R18. For $575 with tax for all four, like I said, couldn't beat 'em with a stick. So it's only an inch difference in height.
I must add that I believe with those Centramatic's on the hubs, my truck has NEVER ridden smoother IMO.
Do the centramatics make any noise?
Old Feb 1, 2022 | 06:21 PM
  #227
Overkill2's Avatar
Overkill2
Absolutely none Jolly. The new tires were balanced prior to because my friend, who's shop I go to, wasn't sold on them. I'm going to have him take my truck for a ride one day and see for himself.
I think my truck has never driven smoother... as smooth as a one ton truck can ride. I'm sold on them.
Old Feb 1, 2022 | 06:53 PM
  #228
speakerfritz's Avatar
speakerfritz
with the windows open, at slow speeds, they make a sloshing sound
Old Feb 1, 2022 | 07:42 PM
  #229
KodiakF250's Avatar
KodiakF250
Balancing your wheels is a good idea anyways. I've read some users claim that Centramatic's says to not balance the tires because that will interfere with the Centramatic balancers, but that is poppycock. I even mentioned this to Centramatic's when I had them on the phone discussing a problem I was having with Discount Tire, and the rep confirmed my stance. Balancing the wheels just puts the wheel close to being balanced, and that leaves all the bead weight in the Centramatic balancers to distribute themselves as a fine tuning to the balance. Then later on if you pick up rocks or throw a wheel weight, the Centramatics will compensate. In other words, why not balance the wheels to allow the full capacity of the centramatic balancers to offset rocks, mud, snow, or loss of wheel weights and not immediately make them compensate for a wheel a few ounces out of balance?
I've heard them swish when I held the centramatic in my hand and rotated it, but I've never heard them even with the windows open and driving slow. Engine and tire noise seem louder than what I detected when I held them. You must have exceptional hearing!
Old Feb 1, 2022 | 07:46 PM
  #230
Overkill2's Avatar
Overkill2
I'd have to say I'd agree with that!
Old Feb 1, 2022 | 08:25 PM
  #231
Overkill2's Avatar
Overkill2
Originally Posted by The Bone
Whats that white stuff on your tires? Never seen that before ROIFL
You gotta go to a ski resort in the mountains where you are to see this stuff...
It's magic white stuff that falls from the sky. But when it hits you, it won't kill you like the freeway above your head during an earthquake.
Old Feb 1, 2022 | 10:21 PM
  #232
jollyrogr's Avatar
jollyrogr
Damnit now I need a set.
Old Feb 2, 2022 | 11:40 AM
  #233
Overkill2's Avatar
Overkill2
I've got say, if they make noise. I sure as **** cannot hear it. I usually have the radio on. I've slowed down a lot with the cost of fuel but I'm not driving slow.
I don't think you'll be disappointed Jolly, believe me.
Old Feb 2, 2022 | 11:42 AM
  #234
Overkill2's Avatar
Overkill2
Two days, today and yesterday, a literal heat wave here with it being in the 40s. Lot of melt off yesterday with the sun being out.
Old Feb 2, 2022 | 07:03 PM
  #235
jollyrogr's Avatar
jollyrogr
That good eh? I was going to do a cold side pipe next but maybe these can be first.
Old Feb 2, 2022 | 08:01 PM
  #236
Overkill2's Avatar
Overkill2
If you're satisfied with the way your truck rides now, I'd do the cold pipe first. Which brand you going with?
I know what the rear end wheel hop feels like. I experienced it when I first got my truck with the Michelins on. I took it back to the dealer and all they did was throw more weight at each wheel. It didn't solve it.
Then I had a friend who broke the bead on the wheels, rotate the tires 180 degrees, remount and rebalance with a lot less weight. It rode way better.
At one point, I bought cheap Nankangs All terrains that were severe winter rated. But it had the rear wheel hop as well. Cheap Chicom made tires with great tread but rode like crap. I sold them. I bet the Centramatic balancers would have solved the problem.
I know how my truck has rode before but I don't think it ever felt as smooth as now IMO. But I think you should do you CAC cold pipe first brother, especially if you are not having ride issues now.
Old Feb 2, 2022 | 09:26 PM
  #237
jollyrogr's Avatar
jollyrogr
Thanks Dave. My truck has the Goodyear wranglers that it came with. They seem to ride ok but tread life will be an issue. When they're done I'll replace them with something that's not Goodyear.
For the cold side pipe I've looked at S&B, H&S, Sinister, and Pusher and planning to go with H&S.
Old Feb 3, 2022 | 07:06 AM
  #238
The Bone's Avatar
The Bone
Lots of guys went with https://rudysdiesel.com/c-1389339-ac...ler-pipes.html
Old Feb 3, 2022 | 07:36 AM
  #239
Overkill2's Avatar
Overkill2
No problem.
If I had to do it again, I'd go with the SPE. I like that it has ports in the piece that goes on the throttle body if I ever decided to go with a methanol injection system. .
https://www.spemotorsport.com/collec...cold-side-pipe
Old Feb 3, 2022 | 10:14 AM
  #240
jollyrogr's Avatar
jollyrogr
Rudy's is just a reseller for the S&B and H&S pipes.
