ATOTO Android Head Unit Project...
Old Apr 18, 2021 | 09:44 AM
  #301
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@dsrace I saw you ask about live data on the head unit in another post. ipzd has an ATOTO head unit, just like several others of us do. Start at post #1 above and grab a cup or mug of your favorite beverage.
All of your questions can be answered above. If not, we welcome any/all questions, thoughts and concerns.
Old Apr 18, 2021 | 02:54 PM
  #302
WinWiz's Avatar
WinWiz
Atoto Dashcam
Hello.
I recently installed an android headunit in my car, now I also want a dashcam. So I'm trying to decide what cam to purchase. But information and long term reviews of the usb cams supported by these chinese headunits are hard to find.
As far as I can tell the atoto cam (actually a rebranded Anytek x28) probably is about as good as it gets regarding picture quality.
But some users have reported that their Anytek x28 based cams failed less than a year after purchase. So I would like to know how your atoto cam is doing?
If you would also share your opinion about the cams ability at night, that would be highly appreciated.
Old Apr 18, 2021 | 03:29 PM
  #303
dsrace's Avatar
dsrace
thanks sous, will do.
Old Apr 18, 2021 | 03:30 PM
  #304
Sous's Avatar
Sous
FTE Emeritus
Originally Posted by WinWiz
Hello.
I am afraid my thoughts will be more of the same as what you have found, or not found...
I have only had the camera installed for a few months, but it performs very well and on startup. The microSD is accessible through an app on the head unit where I can view and lock footage.
I have no thoughts on nighttime driving/camera performance as I don't normally drive the truck in hours of darkness.
I am 100% happy with what I have experienced and seen thus far, but that is all I can say.
I am sorry I don't have more information for you.
Old Apr 18, 2021 | 03:40 PM
  #305
WinWiz's Avatar
WinWiz
Thank you so much for your fast reply.
I have seen cheaper versions of the Anytek x28 advertise 1920x1080 20fps. Atoto doesn't seem to specify fps. Can you verify if it does record full hd at 30fps?
Have you used the cam on cloudy/raining days where lightning is less than optimal?
Old Apr 18, 2021 | 03:46 PM
  #306
Sous's Avatar
Sous
FTE Emeritus
I have seen cheaper versions of the Anytek x28 advertise 1920x1080 20fps. Atoto doesn't seem to specify fps. Can verify if it does record full hd at 30fps?
Yes, I found the specification at one point before purchasing and remember deciding on if 30 FPS would be good enough. Clearly faster FPS is desired, but for my use 30 FPS was sufficient if I could reduce the clutter or additional devices.
Yes, the ATOTO dash camera is 30 FPS at 1080p resolution.
Another FTE'r made a comment recently about watching gauges constantly being "ludicrous". I couldn't agree more and went a step further to reduce the distractions in the cab. Hence the wireless charger in the cubby, FSL in the head unit instead of on a tablet, etc...
Old Apr 18, 2021 | 03:53 PM
  #307
Sous's Avatar
Sous
FTE Emeritus
The only low light situations I have used the dash camera in were in the garage during initial setup and positioning. I performed testing and familiarization at the dinning room table, so no need for that during setup.
The camera performed well in this low light situation, but the MPH was 0, so there is that to consider.
The only gripe I have is about the camera angle. I catch the top part of the hood in the bottom 5% of the screen because the lens only rotates up so much. Due to the steep angle of the 2000 SD windshield, it is what it is.
Although, the very top of the hood being visible adds some orientation to the recording, so it doesn't bother me much.
I am 100% honest with my reviews and decisions and anything I write on this forum I am comfortable telling someone in person looking them in the eyes.
  #308
WinWiz's Avatar
WinWiz
An FTE'r made a comment about watching gauges constantly being "ludicrous". I couldn't agree more and went a step further to reduce the distractions in the cab. Hence the wireless charger in the cubby, FSL in the head unit instead of on a tablet, etc...
Ok. I guess atoto is worth the higher price then.
If you are satisfied I think I will order it from Amazon so I will be covered if it fail prematurely.
Thanks again!
Ps: I spent a few hours today reading this fairly long thread, and you defently seem like a very decent honest man.
Old Apr 18, 2021 | 04:36 PM
  #309
Sous's Avatar
Sous
FTE Emeritus
Thanks again!
I hope I don't steer you wrong!
I am glad you enjoyed the thread and realize that even something that I am completely honest about needs to be evaluated to see if it fits your needs.
If you would be so kind as to update us with your findings on low light/night driving I am sure others like you would appreciate it.
Old Apr 19, 2021 | 08:50 AM
  #310
ponykilr's Avatar
ponykilr
I have a Android head unit and just ordered the same OBD adapter you recommended.
Will post a followup once I get it working to see data on my screen.
Old Apr 19, 2021 | 10:30 AM
  #311
SkySkiJason's Avatar
SkySkiJason
What make/model do you have?
Like it??
Old Apr 19, 2021 | 10:32 AM
  #312
Sous's Avatar
Sous
FTE Emeritus
Outstanding!
I was originally planning to use the BT OBDLink MX+, but ended up using a USB version from OBDLink, I think it was an SX... I cannot remember right now.
FORScan works great with the push of a single button. No need to constantly watch or monitor the gauges as GORScsn starts a log immediately after it connects to the PCM.
As a matter of fact, if I am using FORScan, I usually minimize the gauges and use Google Maps or just have the background visible.
If I feel I want to review the logs later, I can email them or transfer them via USB stick.
Easy, safe and extremely useful to review logs of data later if desired.
Old Apr 19, 2021 | 10:42 AM
  #313
ponykilr's Avatar
ponykilr
Like it??
It’s a Boson I believe, Chinese from eBay. I have had it about 3 years. I like it, it came with iGo navigation but I use Magic Earth. The back up cam came with it along with a GPS antenna I have in the corner of the dash. I think it was around $200. Fairly high powered with good sound on stock speakers.
Outstanding!
I downloaded Torque, Forscan and a couple of others already to try.
Old Apr 19, 2021 | 02:20 PM
  #314
Sous's Avatar
Sous
FTE Emeritus
My previous double DIN (non-android) Jensen head unit used iGo navigation. It was pretty good and I used it to travel the country many, many times. One of the big reasons why I selected an android head unit is to run live Google Maps as we were spoiled with using Google during two recent trips to ID from GA in the Subaru. We were going through WY and CO and were diverted due to poor road conditions and backed up/stopped traffic. We ended up staying the night in Jackson WY with a hot pizza that night and a great breakfast the next morning. Just at the base of the Tetons, we had to do some sightseeing...
Good on you for getting a few different options. I prefer FORScan over TorquePro, but Torque definitely looks more visually appealing when it is all set up. But, FORScan is fast, clean and works every time. I cannot even come close to saying the same for TorquePro.
Hopefully your Boson treats you well and makes having PCM/virtual gauges quick and easy as it has for me.
Old Apr 19, 2021 | 05:27 PM
  #315
ponykilr's Avatar
ponykilr
Another good thing will be the ability to read codes, my code reader does not work on the truck.
