ATOTO Android Head Unit Project...
Old Feb 2, 2025 | 10:43 AM
  #886
John in OkieLand's Avatar
John in OkieLand
the don't list trucks older than 2003
Old Feb 2, 2025 | 11:01 AM
  #887
Tpayne621's Avatar
Tpayne621
You just get the universal one. Then have to do your own mounts. The rest is just normal radio wiring like any other radio. They don't have a install kit for it.
Old Feb 2, 2025 | 07:39 PM
  #888
JoshHefnerX's Avatar
JoshHefnerX
Originally Posted by Tpayne621
If you got any questions just ask. I've had mine about 2 years now. I have the teyes cc3 with 2k screen option and the higher ram option. You can get almost any app you can get for a tablet on it. It's got Netflix and all. I have the favtory tailgate camera hooked to it and a dvr front facing camera that records. I didn't get theit front dvr camera I got a cheap one off aliexpress that looks exactly the same and works just fine also.
Their website is a bit confusing. They have a '2k upgrade' on there, but also sell units that are both 2k and non 2k.. If the unit ls labeled as 2k - does it not need the upgrade?
Anyone tried their 360 camera option?
Old Feb 2, 2025 | 07:46 PM
  #889
Tpayne621's Avatar
Tpayne621
You have to add the 2k upgrade into your cart with the he's unit to get the 2k screen. It's just better resolution.
I dont have the 360 camera option but there is a teyes group on Facebook and seen bunch of people have it.
I have this one. With the 10inch screen option and 6gb ram then added the 2k option in the add ons to get the 2k screen. It was around $500 to my door couple years ago when I got it.
https://www.teyes.com.au/collections...43744275136771
Old Feb 2, 2025 | 07:53 PM
  #890
Tpayne621's Avatar
Tpayne621
I'll try and make a video tomorrow after work so anybody can check it out if anybody wants to see.
Old Feb 4, 2025 | 03:03 PM
  #891
shaun.be's Avatar
shaun.be
Originally Posted by ScaldedDog
For those of you with an S8, have you had connectivity issues with yours, specifically between an OBD adapter and/or a dash cam? What I've found is that the late '23 firmware (231016 - 231120) seemed to cause that. Mine worked OK - though the dashcam connection was always wonky - before I upgraded to the late '23 FW last summer, and it never worked right after that. A couple of weeks ago I upgraded to the mid-'24 version (240527 - 240613), and both dashcam and OBD connections have been rock solid since. I hope that continues.
Mark
This is going to sound stupid.. I have an s8 and not sure how to update it... pm me with the info so maybe we can exchange numbers.. as of recently.. ok probably 6 months netflix no longer works on my s8 ultra..
Old Feb 4, 2025 | 09:59 PM
  #892
ScaldedDog's Avatar
ScaldedDog
I'll do that, but others may want to know, too, so I'll post rudimentary instructions here:
1) Go to myatoto.com and select "Online resources", then "Manuals and firmware"
2) In the boxes at the top of the screen, select Head Unit, then S8 (or whatever you have), then pick the model number from the stupid long list on the right
3) The third item down (for me, at least) is "3 Update Instruction for S8 Gen2 (7862-1024x600)". Click that.
4) The instructions will now be in front of you. To get the firmware file, click the "Download softwares" link to the upper right.
This is a process for consenting adults, so bricking, blowing up settings, etc. is a real possibility. On the other hand, mine now works better than it ever has, though wireless AA still doesn't work. Their process to get it to work was so onerous that I opted to pass.
Mark
Old Jul 16, 2025 | 11:20 AM
  #893
Hvyhaulr's Avatar
Hvyhaulr
I may have not searched well enough for an answer I put my camera plug in port 6 and it works on FCAM but nothing is triggering the reverse wire to tell the unit I’m in reverse when I have it plugged into port 2. The pink wire has 12v when in reverse. I also put 12v to it manually and that didn’t do it.
thoughts?
Old Jul 16, 2025 | 11:24 AM
  #894
Tpayne621's Avatar
Tpayne621
Do you have power at the camera also?
Old Jul 16, 2025 | 03:13 PM
  #895
Hvyhaulr's Avatar
Hvyhaulr
Yes, power to the camera and the camera works in port 6 when I open the FCAM app.
plug it into 2 and give 12v to the rear camera pink wire and nothing happens
Kate Hasse
Apr 18, 2022 03:08 PM
Kate Hasse
Jul 8, 2020 03:52 PM
tkoden
Oct 1, 2016 05:36 PM
Mattb60
Dec 12, 2015 12:26 PM
High Intentions
Mar 2, 2010 07:00 AM
