F250 Project
Old Nov 12, 2020 | 08:48 PM
  #451
Red60's Avatar
Red60
Originally Posted by spurredon
Man, that stinks. What brand it is? Looks like a decent bead across the bottom so someone knew what they were doing! I just replaced the one in my '93 yesterday. Not my favorite job. 500 miles since I put the engine back into it and now it needed a radiator! What is going on? After putting the radiator in I pulled out of the shop and the right rear tire was down close to the rim! Filled it up and ran up to my buddy's place and he pulled a 1 1/2 inch brand new sheet metal screw out of it! When it rains it pours but we still have a great life!
That is absolutely true! Not a bad life at all.
Old Nov 14, 2020 | 06:11 PM
  #452
Red60's Avatar
Red60
Praise God no rust under the window seals!! The doors, fenders, bed and cab corners is enough!
Old Nov 14, 2020 | 06:45 PM
  #453
spurredon's Avatar
spurredon
That will save some time. Now you need to take it down the road with a pair of goggles on! lol
Old Nov 14, 2020 | 08:46 PM
  #454
Red60's Avatar
Red60
Not!
Its way past the point of no return so I can only drive it again when its done! I massaged the majority of dings out of the roof tonight. I have 8 holes in the passenger step, three in the cab roof above the driver (maybe vintage CB antenna mount), and aftermarket radio antenna hole on passengers cowling to weld up.
Old Nov 15, 2020 | 04:00 PM
  #455
Red60's Avatar
Red60
Warning Cab Welding Ahead
There are lots of holes to weld up. Over the years it looks like a lot of accessories have been mounted in/on this cab. At least that tells you it was used and appreciated but now is the time to delete the unused holes...
Old Nov 15, 2020 | 04:14 PM
  #456
JohnNewb's Avatar
JohnNewb
I have holes in my step wells too. Can't imagine what they mounted there. Also fire extinguisher bracket holes in door but it started life as a city maintenance vehicle.
Old Nov 18, 2020 | 07:27 PM
  #457
Red60's Avatar
Red60
Got 16 holes welded up and cleaned up today. Antenna hole is a little low and will need filler.
Old Nov 18, 2020 | 07:33 PM
  #458
spurredon's Avatar
spurredon
There certainly isn't any grass growing in that garage!
Old Nov 18, 2020 | 10:09 PM
  #459
Red60's Avatar
Red60
From my perspective progress is slow. For example, I need to change reducers because 116 urethane reducer temperature range is for warmer ambience... When I’m using the booth, the Outside air temperature drops the shop temperature due to all of that laminar exhaust already this fall. I feel as if my paint window is closing rapidly!
Old Nov 21, 2020 | 12:06 PM
  #460
Red60's Avatar
Red60
More weld now for cleanup
Old Nov 21, 2020 | 08:44 PM
  #461
Red60's Avatar
Red60
Old Nov 21, 2020 | 08:47 PM
  #462
JohnNewb's Avatar
JohnNewb
Are you using flap disks? If so, what grit?
Old Nov 21, 2020 | 10:34 PM
  #463
Red60's Avatar
Red60
4” grinder wheel until almost flush then 120 flapdisk to smooth out the grind marks. Feels slow but I know I am making headway!
Step wells, antenna hole, holes in the cab roof, and above dash mounting are all welded up and ground flush. Next is cab corners both front and back.
Old Nov 21, 2020 | 11:39 PM
  #464
JohnNewb's Avatar
JohnNewb
Thanks. Have not welded sheet metal yet.
Old Nov 22, 2020 | 10:02 AM
  #465
Red60's Avatar
Red60
practice on a scrap fender or something because it takes a little finesse. Main problem I find is if I set the heat too low I cant get it to lay metal down without boogers. Set it minimally higher and it lays metal down but burns through easily. My setup has 0.035 wire so that plays into it too. If I was doing sheetmetal a lot I would have a dedicated “thin metal” setup and my standard. As it is, I just grind off the extra and call it good.
