The 7.3 may not be directly comparable but many of us don’t need an expensive diesel and the negatives. It’s been years since manufacturers attempted a modern gas towing motor. I’m curious what Fords engineers bring us. I remember when Ram bragged about their 600 lb. ft TQ.
I get that.
But, since the 7.3L will be an option, I wonder what the actual cost difference between it, and the more expensive diesel? I also think it’s very safe to assume the mileage will suck.
Either way, gas will never compare to diesels low end, useable towing power.
For whatever the cost savings, it will reflect in resale.
I don't see how the 7.3 Gas is going to stack up the the 6.7 Diesel when it comes to hp & torque. I think whatever fuel saving the new 7.3 and 10 speed produces will be a wash when you hit the first hill under a load compared to the 6.7 with the 10 speed.
But this discussion is making me think about waiting till Aug to order my new F550.
However I do like the idea of less emissions and no DEF.
You looking at the f600 at all? I’ve seen you talking about getting a f550 so curious to hear your thoughts.
Hauling/towing? I'm impressed. I can get 12-13 mpg highway, unloaded, keeping my foot out of it. Hauling the Mammoth TC (~5,600 pounds fully loaded with family and dogs) and towing the UTV to/from Valdez (through Thompson Pass), we got 8.4 mpg. That was doing 55-60 mph most of the way but a lot of the roads were rough, full of frost heaves, so lots of slowing down and speeding up.
i think the bigger more powerful v10 dosent have to work as hard as the 6.2. it would have been nice if they left the 3v v10 an option in the pickups from 2011 to now.
I get that.
I would expect this to split the difference right down the middle so expect this is going to be a $4k-5k option. I would expect, based on what I've heard, that this is going to be closer to the PSD mileage than it is to the 6.2l mileage. This is a ground up build optimized for two things 1) low end torque and 2) optimal fuel usage.
The whole reason this engine was designed and built was for fleets. Fleets are feeling the pain of either 1) maintaining the new diesels or ) poor performance and fuel mileage of the 6.2L. Ford designed this for fleets that need low end torque, but don't necessarily need a diesel, want cheaper and consistent maintenance across their fleet (those that have some gas and some diesel now can move to all gas), and want a vehicle that doesn't need a tanker following it.
My guess is that once this comes out, there are going to be a whole lot of us diesel owners thinking, Hmmmmm. that may be my next rig. Just a hunch.
I get that.
You're underselling the gasser and overselling the diesel. That 7.3 will be more than enough for most Super Duty customers, but we tell ourselves we need so much torque that we need to avoid any downshifting ever, even while towing, that we're willing to overlook the additional $10,000 purchase price, having to plug diesels in for the winter, longer warm-up times, and higher maintenance costs.
If that 7.3 and 10 speed were available today, I'd be taking a serious look at it instead of the diesel. As for mileage, when you crunch the numbers and include the fuel price difference, diesel isn't as advantageous as people think, even when pulling heavy loads. From a business perspective, purchasing a diesel will ensure your fixed costs are about 20% higher, whereas your variable costs increase only marginally (if at all).
So unless you're towing something in excess of the limits of the gasser but within the limits of the diesel, the 7.3 may be the better investment. Don't even bring the resale thing into it, depreciation is written off as an expense, and you may recoup the difference you spend, but you will never get more than the $10k difference over a used gasser. Also any business owner "invests" unnecessarily more in their depreciating assets on the hopes of better resale, instead of investing in marketing and growing their business, they are a complete idiot.
The 7.3 option will go over well for those that work and play above 5,000 ft. elevation. The ~18% larger displacement over the current 6.2 should more than make up for the power loss of 3-4% per 1,000 ft. elevation. One of the main reasons that I went diesel though was to overcome the loss of power for high mountain excursions (not nearly as significant as a gasser). In retrospect, I would have given the 7.3 a good hard look if it was an option at the time of my purchase. Nevertheless, I love this diesel and can't complain about the power or the price for that matter.
Probably right. Agreed on the v10. Such a great engine.
Originally Posted by someday
i thought current diesel mileage isnt that spectacular to begin with?
True. A buddy drove up the Alcan last summer hauling the exact model/year TC that I have. He has a 2015 F350 with the 6.7L. They got 11.3 mpg average on the trip up to the point we met up. We get 8.4 - 9.1 mpg with almost the exact same load.
Over simplified since gasoline and diesel are different commodities, but yeah. The price is 26% higher for diesel fuel. So just in fueling costs, they’re pretty close.
I get that.
No more CP4 issues to worry for, no more warranty denial fears. If the big block gas motor can pull my 5th wheel count me in.
