maybe marginal increase. But the acceleration, quick response to the demand of power, and the grade shifting will be significant improvement.
I personally think the extra overdrive gears will help a good deal, but we still aren't going to see anything insane like mpg's in the teens. Some folks believe we will but they're out to lunch as far as I'm concerned.
I'm very excited about Ford bringing back a big block, port injection, push rod V8. It's an encouraging sign that they are at least paying a small amount of attention to what guys want, and not necessarily what the EPA is pushing.
The 7.3L is an engine that has the potential to last a long time and be easy to repair.
That is exactly how I feel especially if you tend to keep trucks a long time.
Of course not, the dually is probably close to 2000lbs heavier than my truck and it's probably a diesel to boot. But if you had the 6.2l, then you probably could expect some improvement with the new 7.3l and the 10-speed.
Originally Posted by Alaskan_Warbird
I drive a dually and seriously doubt the 7.3L will see those kinds of mpg's in a DRW.
i had a 3v 5 speed v10 cc dually 4x4 and got mpg in the teens
Hauling/towing? I'm impressed. I can get 12-13 mpg highway, unloaded, keeping my foot out of it. Hauling the Mammoth TC (~5,600 pounds fully loaded with family and dogs) and towing the UTV to/from Valdez (through Thompson Pass), we got 8.4 mpg. That was doing 55-60 mph most of the way but a lot of the roads were rough, full of frost heaves, so lots of slowing down and speeding up.
I don't see how the 7.3 Gas is going to stack up the the 6.7 Diesel when it comes to hp & torque. I think whatever fuel saving the new 7.3 and 10 speed produces will be a wash when you hit the first hill under a load compared to the 6.7 with the 10 speed.
But this discussion is making me think about waiting till Aug to order my new F550.
However I do like the idea of less emissions and no DEF.
The 7.3 won’t compare to the 6.7L in useable torque and I’m not considering it. Yeah, it will show nice numbers for those who look at peak numbers, but the torque curve will be typical gas curves. Higher RPM, and nothing down low that would be in the same wheelhouse as a diesel.
El Paso.
The 7.3 may not be directly comparable but many of us don’t need an expensive diesel and the negatives. It’s been years since manufacturers attempted a modern gas towing motor. I’m curious what Fords engineers bring us. I remember when Ram bragged about their 600 lb. ft TQ.
