2020 revealed!
#302
I prefer the look of the current version. This seems a little less intimidating in someone's rearview mirror.
#303
The current model has those large 2 bars that restrict air flow. This looks a little more cooler for the motor in hot climates. Ford also takes air directly from the grille to feed the motor, looks like Ford is improving their design.
#306
It appears the engineers won over the marketing dept this time. I think the billet type (all one piece of aluminum/chrome) in the upper trims looks OK, it reminds me of older gens. If the lower trims are all plastic and have that design I think they will really dissapoint.
#310
But those 2 large bars (specifically the part in between the C) make the C light design pop big time, and the C light design is an optical illusion of sorts and makes everything look big/aggressive. I think the C lights are the main driver behind the look of this gens SD. The 2020 version just blurs and looks like a big grill instead of focusing your attention on the headlights.
#311
I’m betting on big numbers from Ford. More HP usually means more heat , I’m curious how they’ll keep it cool. Could we see 500 HP?
#312
Do you have, or know the location of, larger sized images of the modified truck in your avatar?
Is it just me or does anyone else want to see a bigger pic also?
#313
The new design rocks.
I was not a fan of the17’-19’ C clamp LED piping. I much prefer the 20’. It just doesn’t flow..
The Grille? I like the 17’-19’ better.
I definitely do not like the Non DRW grille. The new Limited has the best looking grille and definitely the best looking interior of the bunch.
#314
You could just buy this Grill for Ultimate flow. 2017 f250 in AZ!
