Remote Access and additional Vehicle security kit!
Old Jul 5, 2017 | 02:03 PM
  #271
mrpickles's Avatar
mrpickles
Originally Posted by toroz06
Does any of this modules lock the doors for you when you leave the truck parked and off?
Not automatically, but you can open the app on an iPhone and lock the doors or unlock the doors.
Old Jul 15, 2017 | 08:53 AM
  #272
Sleepyguy's Avatar
Sleepyguy
I just learned maybe I am slow that there is a fordpass and a ford remote access app. I thought they where the same. Is there any reason one can't have one or the other? Fordpass website si ply says you need sync 3. I would assume with remote access it would be possible.
Only reason I ask is it would be cool to have the car location by gps of the pass app.
Old Jul 15, 2017 | 08:58 AM
  #273
Tricon's Avatar
Tricon
Ford Pass doesn't work with our trucks.
Old Jul 15, 2017 | 09:00 AM
  #274
Pocket's Avatar
Pocket
Ford Pass and Remote Access are both two completely different things.
Ford Pass is only available on certain vehicles, and only if the option was built into the vehicle at production. If your vehicle was not Ford Pass compatible equipped from production, you cannot add the hardware to make it work.
On the other hand, Remote Access is not at all available as a production option. It is only available as an add-on later. This is the option to use for vehicles that do not come equipped with Ford Pass capability.
Old Jul 17, 2017 | 03:40 PM
  #275
LiquidSteam's Avatar
LiquidSteam
What does this mean?
Old Jul 17, 2017 | 04:03 PM
  #276
Tricon's Avatar
Tricon
The remote start module goes to sleep after a while of inactivity in order to not kill your batteries. It's a long time though.
Old Jul 17, 2017 | 08:31 PM
  #277
Pocket's Avatar
Pocket
^^^^ WHS
Usually after 3 days or so of the vehicle not being started, the RMU module will go into low power mode.
You can go into the settings and schedule a wake-up date. This is useful if you're say doing long-term parking and will want to remote start the truck when you get back (ie. airport parking).
Old Jul 18, 2017 | 06:27 AM
  #278
CaptJaC's Avatar
CaptJaC
Originally Posted by Pocket
^^^^ WHS
Thanks I had the same question.
Old Jul 28, 2017 | 09:43 AM
  #279
Sleepyguy's Avatar
Sleepyguy
I should almost start selling the remote security model to you mericans as it's $130 CAD here which works out to roughly $100 USD. Online it also states on fords website $31 install.
Old Oct 27, 2017 | 09:00 AM
  #280
triniexr's Avatar
triniexr
Where did you see $31 for install? I am trying to find that and I don't see it.
Old Oct 27, 2017 | 09:36 AM
  #281
Brother_Bluto's Avatar
Brother_Bluto
I don't think Ford can dictate the dealer installation price. Maybe that was from a dealer's website?
I recently had the Perimiter+ Remote (cell phone) access done as part of my purchase. Only two part numbers are needed and a very easy install that can be done yourself in under 30min (likely 10min). This thread gives a fairly good sense of what it takes to install... the hardest part is wire-tying the RMU and the VSS under your dash (a bit tight for big folks like me, but still very doable). Just make sure you purchase from a dealer who will activate the SIM for you.
My unit is accessible to change the sensitivity by pulling the dash side plate when the driver door is open. In my case they also installed the Long Distance Remote Start & Antennae (which I didn't want or need) that connects to this unit. I have already unplugged and removed the antennae since I will never use it (redundant option since my FOB already has remote start and can do on the cell phone). I also want to put a dash cam in the spot they mounted the antennae so off it came. Still need to pull the (now not being used) antennae wire out of the headliner, but its not an issue for now - out of site, out of mind.
Old Oct 27, 2017 | 10:41 AM
  #282
triniexr's Avatar
triniexr
My dealer has never done one before and they are telling me its 2 hours labour at $124/hour. I've seen on some american sites the dealer has a special right now for the 2 parts and install for $399.
Old Oct 27, 2017 | 11:17 AM
  #283
bushpilot's Avatar
bushpilot
neither had i....and I did it in far less than 1 hour.
Ill do it for you for 100 bucks...and be done in 15 minutes
Old Oct 27, 2017 | 01:52 PM
  #284
hinsong's Avatar
hinsong
Does anyone know if it can be moved to another truck after it's been activated?
Old Oct 27, 2017 | 02:15 PM
  #285
bushpilot's Avatar
bushpilot
I don't see why not, since the SIM card is serialized to the box/hardware, NOT the truck.
