Official NCFTE Works Thread
Old Oct 12, 2016 | 08:21 PM
  #481
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
power steering pump, pulley puller
Say that real fast three times.
Old Oct 13, 2016 | 02:43 AM
  #482
Cracker289's Avatar
Cracker289
You can get that power steering pulley removal tool through the Autozone use a tool program. You pay the fee for the tool, use it and bring it back, and they refund it to you. So you're basically getting to use it for free as long as you bring it back. I've used the power steering pulley removal tool three times from them, works pretty well, easy enough to understand once you get it all out.
Old Oct 13, 2016 | 07:02 AM
  #483
FordTruckfan89's Avatar
FordTruckfan89
Originally Posted by ubereal2
You need a power steering pump, pulley puller to remove it, and to press it back on.
Rent the puller, press off, press on new pump, atleast that's how it was on my idi.
Old Oct 13, 2016 | 07:28 AM
  #484
Benztechnc's Avatar
Benztechnc
So. Got the A\C compressor mounted, accumulator and new orifice tube (which was built into the line from the evap to the condenser) and the service port on the new line had a mangled spring in it, so when I went to pull the gauges off the line, it didn't seal. ran around trying to find a new schrader valve for the line, and used my Jeep. The left front caliper started dragging bad. Advance on 10-10 has new calipers for around 25 per side. However, I never did finish my brake pressure bleeder project.
So tonight I will be.
Installing a new Shrader valve.
Patching the wiring on the big trailer.
Replacing brake calipers on the TJ
Finishing my brake bleeder build, or manually bleeding, or vacuum bleeding the brakes.
Bob has offered to come out and give a hand, along with Dusty from the group. and a couple other guys that I know.
I swear, I'll not continue to leave things to the last minute after this...
Update 1: Hit the store this morning. Scored the calipers (unloaded) and the hardware for the brake bleeder. For the bleeder project I currently have:
1. Pressure spray tank from Home Depot.
2. NPT fitting and brass nut to mount the cap
3. JEEP cap (that fits)
4. various lines with a shutoff valve
Last piece I may need is a 1\4 in to 1\4 in hose barb. IF this works, then I'll have to make adapters for the Fords and probably Mary's Honda.
Old Oct 13, 2016 | 09:11 AM
  #485
FordTruckfan89
How do you seal the fitting to the cap, jb weld?
Old Oct 13, 2016 | 09:55 AM
  #486
Benztechnc's Avatar
Benztechnc
I don't have any JB Weld but I may try to use silicone Or RTV.
Old Oct 13, 2016 | 03:07 PM
  #487
Cracker289's Avatar
Cracker289
What kind of redneck are ya, then?!
Old Oct 13, 2016 | 09:21 PM
  #488
Benztechnc's Avatar
Benztechnc
Ummm.... John... I'm not a redneck... I'm a brick.... British Hick... Sorry.... when I took the test, I did not know the 17th Vice Presidents Dog's name and guessing Bosephus didn't work... so they denied my citizenship... :/
Old Oct 13, 2016 | 09:31 PM
  #489
ubereal2's Avatar
ubereal2
I have JB Weld, and Duct Tape
Old Oct 13, 2016 | 10:36 PM
  #490
FordTruckfan89
Glad we got the calipers taken care of. I got to show Josh my expert engine stalling driving skills.
Old Oct 13, 2016 | 10:38 PM
  #491
FordTruckfan89
Need WD40 and toothpicks to be a "genuine redneck makanick"
Old Oct 14, 2016 | 04:54 AM
  #492
77mud's Avatar
77mud
I have JB weld, Duct tape, Zip ties, super glue, and PB blaster.... do I qualify?
Old Oct 14, 2016 | 05:14 AM
  #493
fuzzy1626's Avatar
fuzzy1626
I've got all that plus wire coat hangers to tie stuff up or together...
Old Oct 14, 2016 | 06:39 AM
  #494
ubereal2's Avatar
ubereal2
No toothpicks here. But I do have PB Blaster, WD-40, Zip Ties, Electrical Tape, Wooden Clothes Pins, and an original jar of "Blinker Fluid"
Old Oct 14, 2016 | 08:00 AM
  #495
77mud's Avatar
77mud
I got those holding my exhuast up on my 97....
