Bye Bye Front Drums
Old Jan 26, 2015 | 07:58 PM
  #286
BobbyFord's Avatar
BobbyFord
This be the bearing that you need---> http://www.summitracing.com/parts/bca-rub1580ebfr
Pricey.
I get mine from a local bearing supplier for a bit less.
Old Jan 26, 2015 | 08:04 PM
  #287
bajafishnut's Avatar
bajafishnut
I know the feeling about getting out for some windshield time, quality windshield time, where you have nowhere to go, nothing to do, and plenty of scenery to see, while the motor purrs, and the tires sing. Fore sure, my truck is my therapy couch. Troubles & cares just go out the open window.
Take a ride amigo,
baja
Old Jan 26, 2015 | 08:07 PM
  #288
ultraranger's Avatar
ultraranger
Pricey.
Thanks, Bobby.
Hmmm. ....ebfr. I think the number on the bearings I currently have end in, ebFUBAR.
I'll have to check into those you mentioned, to find the dimensions on them BEFORE I buy anything (else).
Old Jan 26, 2015 | 08:11 PM
  #289
BobbyFord's Avatar
BobbyFord
Originally Posted by ultraranger
Thanks, Bobby.
Funny stuff!
Old Jan 26, 2015 | 08:18 PM
  #290
BobbyFord's Avatar
BobbyFord
Hmm......maybe that number I gave you is exactly what you already have.
*edit* damn link is bogus. Federal Mogul website has the RUB-1580 EBFR specs...
These are the bearings I used for my 31 spline axles. (9-3/8")
Old Jan 26, 2015 | 08:44 PM
  #291
ultraranger
Funny stuff!
Hey, if you can't laugh at your own ignorance from time to time then you're just not a very good sport.
When you're taking parts from one vehicle and adapting/installing them in another --especially if there's little or no information on the net about what you're trying to do, it's just an inherent risk you take of it working or not working. Simple as that. Its all a part of the essence that makes a gear head a gear head.
Same story with the '79 Bronco rear sway bar I installed. I generally try and thoroughly research things BEFORE I just jump into them. Sometimes things get over looked and sometimes you just don't know what you don't know until you start to put something on. In the case of the rear bar, I couldn't find any information/photos of its use in a Bumpside truck.
I don't know (yet) if it's going to work but, me being able to at least get it fitted up is 50% of the task. If it does work, that'll complete the other 50% that my gamble in putting it on actually worked.
While a failure isn't fun and is a (temporary) setback, I did learn some valuable information out of this and, anyone reading this will have learned something too. (Just at MY expense).
It wasn't a total loss though.
Old Jan 26, 2015 | 08:49 PM
  #292
BobbyFord's Avatar
BobbyFord
While a failure isn't fun and is a (temporary) setback, I did learn some valuable information out this and, anyone reading this will have learned something too. (Just at MY expense).
I hear ya. Done the same thing myself, many times. These are the ones that make you do research. You gain knowledge and you never forget what you learned
Old Jan 27, 2015 | 09:05 AM
  #293
bajafishnut
Hola amigos,
Just wondering, since Ultra & Insta are posting on this forum, have you guys, or any others out there, heard of anybody installing one of those fold-out-down steps, on a 'Bump' tailgate? I'm thinking that my highboy could really use one, and if it has already been invented, why reinvent the wheel? Its not that I need another project, when I am still mid stream on the flatbed/stock bed restore. Sometimes I just think over the horizon, further than I can see.
Baja
Old Jan 27, 2015 | 11:36 AM
  #294
JEFFFAFA's Avatar
JEFFFAFA
I put my caliper on the O.D. of the axle bearing journal and then I put the caliper on the I.D. of the bearing and the caliper said, "The I.D. of the bearing is exactly too damn big."
The 31-spline axle journal is about 1-17/32" (1.5313"). The I.D. of the bearing is about 1-5/8" (1.6250").
--I say, "ABOUT" because the battery in my calipers seems to have given up the ghost. I just had to put the caliper on the items and then measure the distance of the caliper points on a tape measure.
There seems to be forces in the universe conspiring against me at this particular moment in my existence, in keeping me from reaching completion of the tasks at hand on my truck. --I may have lost this particular battle but, the war ain't over yet.
D0TZ1225A.....1 3/8" I.D....3 9/64" O.D.
C9AZ1225A.....1 17/32" I.D....3 9/64" O.D.
C9AZ1225A replaced by D8AZ1225A.
D8AZ1225A replaced by D8AZ1225B "OR" D8AZ1225C.
D8AZ1225B includes D8AZ1225A,D3TZ1180A collar,C9AZ1177A seal.
D8AZ1225C includes D8AZ1225A,C9AZ1180A collar,C9AZ1177A seal.
D3TZ1180A is 1 1/2" I.D and 2 3/8" O.D. (from memory rather wide)
C9AZ1180A is 1 1/2" I.D. and 2 7/16" O.D. (from memory rather narrow)
NOTE. The car slide shows 1 1/2" I.D on them but the Truck slides show them at 1 17/32".
Old Jan 27, 2015 | 04:51 PM
  #295
ultraranger
Hmmm.... Something doesn't seem to jive here (??). The D0TZ1225A bearing should have a much larger I.D. than the C9AZ1225A bearing. Actually, it should have the largest I.D. of all the bearings listed.
17/32" (.5313") is one 'tick' larger than a half inch (.500") and is larger than 3/8" (.3750").
The DOTZ bearing I.D. is roughly 1-5/8" in diameter (~1.6250") and would be ~1/4" (.250") larger than the 1-3/8" (1.375") diameter listed.
I'm not certain if there's a misprint from your information source or, if it was just simply an accidental case of fat-fingering the keyboard? --it happens.
The I.D. of these DOTZ bearings comes out at around 1-5/8" so, it's definitely greater than either 1-3/8" or 1-17/32" for sure.
Steve
Old Jan 27, 2015 | 05:02 PM
  #296
qman's Avatar
qman
sure seems like a lot of work to get rid of front drums.
Old Jan 27, 2015 | 05:07 PM
  #297
ultraranger
The front drums were replaced with discs several months back.
I'm working on the rear end of the truck now. --still retaining drums in the rear.
Old Jan 27, 2015 | 05:35 PM
  #298
JEFFFAFA's Avatar
JEFFFAFA
Steve
Ahh. You are correct O' wise one. This time I looked in JAN 1975 final issue section 12,page 17 (under 1225) and it lists the I.D. of D0TZ1225A at 1 5/8" and including C1VY1180A collar.
Earlier I was looking in JAN 1975 final issue section 40.3,pages 1 & 2. This is where the axle tag numbers tell me which style axle bearings are used. I took your part number D0TZ1225A,checked that it did indeed fit 9 3/8" R/G with 4 pinion Traction Loks and tags WFF-A,-B,-C. These tags show axle bearing style "ER" on page two. On page one style ER is listed as ER....D0TZ1225A....1 3/8" I.D....3 9/64" O.D.
Hey Bill, if you're out there can you post these pages for me please?
Old Jan 27, 2015 | 06:56 PM
  #299
ultraranger
Supposedly, my 31-spline axles came from 9-3/8" rear ends. --not that I know everything but, I don't know of any regular '68-'72 F100 9-inch rears (non 9 3/8") that had 31-spline axles in them.
Now, I didn't physically pull these 31-spline axles myself. One came from Hope, Arkansas and the other came from somewhere in Arizona.
If the 9-3/8" rear ends came out in the '68-'72 model F100s (and they did), the evidence, based on the axle bearing dimensions and the change in part numbers, would seem to suggest that there was also a change in the axles themselves between the 1969 and 1970 model years. --axle journal diameters of the 9-3/8" axles increased in size between 1969 to 1970 (?).
The DOTZ bearing is obviously way too large for the 31-spline axles I have, yet, the axle bearing I pulled off one of the 31-spline axles is larger than the journal of the 28-spline axles I just pulled out of my '69 F100.
The bearing journal of my stock 28-spline axle is right at 1.500". The bearing journal on my 31-spline axle(s) is 1-17/32" or, 1/32" larger in this area than on my 28-spline axles.
This is the only logical explanation I can think of. Until hard evidence can be presented of what the facts really are, I suppose it may just remain one of the great mysteries of the universe.
Old Jan 27, 2015 | 09:02 PM
  #300
Trail_Rider's Avatar
Trail_Rider
It looks like you're doing a pretty thorough job, just don't forget you'll need a brake proportioning valve from a disk brake truck.
