Bye Bye Front Drums
http://www.fordification.com/images/...ht-install.jpg
The cargo light installed on the Bumps was actually borrowed from the '64/'65 T-Bird parts bin. It was originally a left side backup light on the T-Birds. In the original T-Bird installation, the backup light was installed in this orientation, in the following link (the orientation shown on the truck there is wrong. The taper of the light bezel should face upward on the truck).
http://www.fordification.com/images/...nterchange.jpg
Notice the orientation of the cargo light for the Bumpsides in this Ford illustrated diagram (taper of bezel is facing upward).
http://www.fordification.com/tech/im...cargolight.jpg
The T-Bird cargo light did not directly fit up to the contour on the back of the Bumpside cabs. This is why Ford used the thick rubber seal, between the cargo light bezel and the back of the cab, to take up the gap between the two.
It was also stocked up with can & dry goods just needed to add beer & steaks gun, and family oh and the little 90Lb. dog it weighted more then my kids at the time.
My brothers Camper special had the cargo light good for when out fishing or just tailgating at a park BBQ..
I'm now to old to need or having a use for a cargo.
Orich
The white/red switchback LED I installed in my cargo light is a 60 LED 1157 bulb.
The LED 1157 bulbs in my tail/signal lights are 20 LEDs each.
But then, I noticed my right front blinker light not working. So ordered another pair of 1157 LED's. Well upon installing them, I notice both in cab blinker lights lite up and not blinking. So thought one may be in wrong that was causing this.
Nope no problem install ok. So, I seem to remember one time hearing about a diode inline to stop the feed back. Any Ideas of size and placement. ?
I'm thinking at both the dash blinker lights themselves power leads ?
Orich
Tridon EL12 Flasher
I would like to run LED headlights as well (trucklite), but can't spend the $166 per headlight. But that sure would light the load on the charging system, especially combined with all of the running lights changed.
Orich
Tridon EL12 Flasher
To the flasher, it senses this low current draw as a bulb being burned out. The rapid flashing (under normal circumstances) tells you you have an incandescent bulb or bulbs that are out --only, if the bulbs in the circuit are actually LEDs and not incandescent, there's no problem.
There are external ballast resistors designed to be spliced into the circuit to put a load on the flashers for the LEDs, to regulate the on/off cycle of the lights at a normal blink rate. It seems much simpler and more logical to me to simply unplug and change out the conventional signal and warning flashers for ones that are LED compatible, rather than splice/wire in some bulky ballast load resistors.
Tridon EL12 Flasher
For now kind of busy putting together a extra Dodge NV4500 short tail shaft setup ford a ford NV4500 5sp tranny that, I'll soon flip.
I don't have any storage place any more other then the bed of my truck.
I was going to keep it but those want pay for a storage unit then don't need to.
I'm slowing trying to empty out my truck bed so may I can get the truck painted this yr.
I look into Blinker unit for an LED that will fit into my flasher socket.
Thanks for the info both you guys
Orich
I wrapped some kraft paper around the rear bar to keep the finish from getting banged up while I got the bar lifted into place.
This evening, I got back on the project and got the rear sway bar assembly fully installed.
I backed the truck out of the shop and headed outside the city limits onto a narrow paved, two-lane curvy, bumpy road. The truck handled really flat around the curves and I took some of the curves much faster than I would have previously, before the front and rear bars were put on.
I had to go over two railroad tracks during my venture and I don't normally charge over RR tracks but, I figured this was a good chance to really compress the suspension, to see if the suspension would clash with the endlinks or the endlink bolts. I flew over one of the tracks at 40 MPH. it was a pretty good jolt but, there were no clangs or bangs as a result.
I got back to my shop, crawled around on a creeper under the rear, looking for any witness marks from the leaf springs on the endlinks or on the endlink bolts but, there were none.
This was only one brief outing but, it looks like this may have been a successful component installation that's going to work without interference.
Welp, time to put the green machine to bed.
I will either be switching to a fuel injected 5.0L H.O. engine from a '90 Mustang GT that I have or, I'll fuel inject an early '70s 351W that I have.
Which ever way I go with the engine, the stock '69 C-4 3-spd. non-overdriven automatic will be replaced with a '98 Ford 4R70W 4-spd. overdrive automatic.
Still thinking... Perhaps, oval led's, from a truck stop, might work out cleaner, with just a cut out, in the uprights of the gantry. I might be on to something there....
baja
She finally got off from work at a normal hour yesterday and I got the truck up to the alignment shop and dropped it off. They said it would be Thursday before they could get to it. They called me this afternoon and said it was ready (a day early). Yeah!
Unfortunately, it started pouring down rain on the way to the alignment shop, to pick the truck up, and I had to drive it home in the rain but I did get to use the 'new' intermittent wipers.
Now, I can FINALLY get some quality drive time in on it!
I'm going to visit my dad and my uncle this weekend to show them what I've gotten done on the truck. My uncle has a two-tone blue long bed '71 Ranger XLT that's straight as a pin.
This is the (red & white) truck my dad had bought from my uncle back in the early '70s. It's the first vehicle I learned to drive. (originally a '68 Ranger. My uncle had changed out all the '68 Ranger interior and exterior trim for '70 model Ranger trim, before my dad had bought the truck --these pictures from 1988).
And of course, my old hoopty '69 back from the rainy trip from the alignment shop.
