Bye Bye Front Drums
Old Dec 29, 2014 | 10:56 AM
  #181
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by ultraranger
--although mine is more closely related to the Momo Veloce steering wheel which was standard equipment in the '89 Saleen Mustangs, (as were the cruise control switches/bracket, which is what my CC bracket came off of).
'89 SALEEN? That reminds me of a Saleen poster I had years ago. It's caption read something like "Warning. Smoking rubber does not cause cancer".
Old Dec 29, 2014 | 04:03 PM
  #182
ultraranger's Avatar
ultraranger
What's that darned ol' ultraranger up to now? And why's there a light bulb dangling down on the back glass of his truck?
Hey! It lights up when he steps on the brake pedal!
Old Dec 29, 2014 | 06:56 PM
  #183
bajafishnut's Avatar
bajafishnut
Well, I like lights, as don't see well in the dark any more, but I am not sure about the practical aspects. I do see the red glow, reflected on the door, from the brake lights, so they are working too... reminds me, I have one taillight out...
Baja
Old Dec 29, 2014 | 07:02 PM
  #184
HIO Silver's Avatar
HIO Silver
Hahahahaha ! Too funny.
...'did the same the same thing about a week ago but I rigged up a mirror to the side yard gate since I work outside.
Old Dec 29, 2014 | 08:27 PM
  #185
ultraranger
Baja
The bulb hanging in the back glass is just for the purpose of testing the circuit out, I ran, to make sure the circuit goes 'hot', when I step on the brake pedal.
Since I had my instrument cluster out, to install the delay wiper switch/module and to pretty up the cluster while it was out, I decided to run a wire that would go from the brake pedal switch to the cargo light at the top, back of the cab.
There's a hole behind the instrument cluster and at the base of the A-pillar that I ran the wire up through (11' of black 14 ga. automotive primary wire).
End of wire hanging out after I fed it up through the A-pillar.
I pulled it on around and fed it out of the hole for the cargo light and put a .157" female bullet connector on the end of the wire.
I made some short jumpers with a breakout pigtail, with another .157" female bullet connector, to go between the brake light switch connector and the two terminals on the back of the brake light switch. --The breakout connector comes off the Red/Black wire. The Red wire is the constant 12v hot wire to the brake switch.
I took the cargo light (a left over from the '65 Thunderbird parts bin --it was originally a left hand backup light from the '65 T-Birds), and pulled the 1156 (single element) bulb socket out of it.
I ordered a 3-wire 3/4" metal 1157 dual element bulb socket and a white/red switchback LED and a ballast resistor. Hopefully, they'll arrive by week's end.
If the cargo light is needed, the cargo **** is pulled out and white light illuminates the bed of the truck, just like it did before.
However, when the brake pedal is stepped on, the color of the LED switches to red and the cargo light then doubles as a high mount 3rd brake light.
I had tried for a while to figure out a way to accomplish this but couldn't come up with anything I liked for a clean install. Then one day, I saw where a guy had figured out a really slick way to accomplish this. He didn't give all the specific details but, I was able to fill in the blanks to sort it out.
Credit for the following photos, and the one that originally figured out this conversion, goes to Coupe5oh.
Old Dec 29, 2014 | 09:27 PM
  #186
Texasknowhow's Avatar
Texasknowhow
Love it! Very cool.
Old Dec 30, 2014 | 08:06 AM
  #187
bajafishnut
Way nice amigo, and tricky to the max, I must admit. I like it, and may try to do the same... first I have to find a bed light... oh yeah, before that, I have to put on a bed... but that is in the works...
Baja
Old Dec 30, 2014 | 11:16 PM
  #188
ultraranger
Messin' Around
I was digging around in a box of Autometer Phantom-series gauges, I had bought years ago for my '68 Mustang, and pulled out a gauge pod I had purchased to put in the center depression, between the browse of a '67/'68 Mustang dash pad.
The gauge pod (Autometer p/n 10001) was actually designed to mount on the dash of a '94-'98 SN95 Mustang. --it was designed to replace the factory clock/pod on those models.
My '69 F-100's dash pad is pretty split up but, I set the gauge pod on the dash pad cover, over the speaker hole (I don't have a speaker mounted there) just for grins and giggles to check it out.
The gauges are 2-1/16" and could be anything a person would want accurate readings on ...volts, oil pressure, water temperature ... if you were going to be running a turbo, one of the gauges could be a Vacuum/Boost gauge. If you had a diesel engine, one gauge could be for exhaust gas temperature. The gauge faces and bezels also come in many different colors and styles that could be installed in the dash pod and isn't limited to just Autometer brand gauges.
I've never seen or heard of anyone using one of these dash pods in a Bumpside (or an older Mustang for that matter) but, it would be different and a very clean way to add extra (accurate) gauges to an old 5th generation truck.
94 Ford Mustang Clock For Sale :: Popular 2014 Toy Store
Old Dec 30, 2014 | 11:52 PM
  #189
orich's Avatar
orich
I bought one of those 3 ga pods and was going to mount over my speaker grille but did not really want punch any hole in my cherry dash pad so Shxt canned that idea. I like the manual gauges over electric one and would of put to big of hole in pad.
Orich
Old Dec 31, 2014 | 12:05 AM
  #190
ultraranger
Orich
The pod I have has a bracket that runs down the center, bottom of the pod and a small diameter screw in the center to cinch it down with. Conversely, double sided tape or velcro could be used to affix the pod to the dash without making any mounting holes in the dash pad.
The wires of the gauges I have are very thin and would thread right through the existing speaker hole perforations in the center of the dash pad.
(More accurate than stock) mechanical aftermarket gauges could also be installed in the pod.
The pod could also be flipped upside down and mounted to the ceiling in front of the windshield, between the inner gaps of the visors.
Old Dec 31, 2014 | 01:17 AM
  #191
ultraranger
Some time back, when I started working on the various modifications to my truck, I wasn't sure if my stock '69 C-4 gear selector linkage rod was going to work with my 'new' column (changed from fixed '69 manual steering column to a '78 tilt column for power steering).
I initially thought I might have to take some 3/8" rod, thread both ends and install either Heim or ball joint rod ends on it, to connect from the lever on the end of the steering column to the lever on the side of the transmission.
As it turns out, my stock linkage rod connected up with no problem.
Now, the remaining issue goes back to the stock '69 C-4 lever on the side of the transmission and mounting a neutral safety switch there.
The threaded bosses are cast onto the side of the transmission to mount a NSS there but, the lever itself isn't designed to actuate a transmission-mounted NSS.
I had found a later model (wrecking yard) C-4 transmission selector lever arm that's compatible with the transmission-mounted NSS but, the arm is shorter in length than the current stock one on my transmission. --the donor lever was from a transmission that was in a passenger car.
Donor transmission lever (and trans mounted NSS).
I could take a piece of 1/8" flat steel and weld it to the tip of the donor lever to extend it but, I took my calipers and measured the shoulder diameter of the donor lever (where the NSS would slide up on it) and compared it to the shoulder diameter of my existing transmission lever. The diameters measure the same. The only difference there is the addition of the two slots (180-degrees apart) machined into the shoulders of the donor lever, where my current lever has no slots in it.
Since I would have to remove my existing lever from the transmission anyway, to swap the donor lever in, I think it would be better to just take my existing lever out, take it and the donor lever to the machine shop and let them use the donor lever as a pattern to get the measurements of the donor lever's slots, and their placement, and just have my existing lever slotted to match it.
Old Jan 7, 2015 | 04:41 PM
  #192
ultraranger
Seems the little brown truck paid a visit today while I was at work. This was waiting for me on the carport when I got home --31-spline axle from a '71 F-100 that had a 9-3/8" rear end.
31-spline axle fitted up to the 31-spline 4-pinion Traction-Lok differential of my factory Daytona 9-inch N case 3rd member.--I had pulled the N case out of a '75 F-150 four wheel drive truck back in the late '90s/early 2000s.
The other '71 F-100 31-spline axle should be here next Monday or Tuesday.
Gotta get this axle into the 20-ton press and pop the bearing off. It's a little rough. The axle will take a trip through my bead blast cabinet, before I press a new bearing on it.
The O.D. of this bearing matches the I.D. of the bearing socket on the end of the axle housing tube on my '69 F-100. I'm sure I'll have to change the axle seals to match the larger journal of the 31-spline axles, which kinda sucks since I just replaced the axle seals less than four years ago.
Oh well. Worth the minor inconvenience and the long wait in the search for a pair of 31-splines, and to have finally found a set.
Old Jan 7, 2015 | 05:14 PM
  #193
trozei's Avatar
trozei
Is it actually worth it to upgrade to a 31 spline? I know they're stronger but is the 28 weak?
Old Jan 7, 2015 | 05:47 PM
  #194
ultraranger
"Worth it" is purely subjective to the individual's perspective.
Depends on what you do, or plan to do, to the truck. Currently, I just have the stock, tired 240. The 240 is little threat to the regular C7AW single vertical rib 9-inch 3rd member case and is little threat to the stock 28-spline axles.
Eventually, I plan to install a much stronger fuel injected 5.0L H.O. engine from a '90 Mustang GT. Even at that, it's probably not a threat to my current 9-inch 3rd member or the 28-spline axles.
However, who knows what the future holds? Somewhere down the road, I may decide to get a wild hair and install a 460 based 514 stroker. The addition of the 31-splines and an N-case now just means I don't have to keep beefing up drive line components later or, as I go.
Even if I don't install a big-block stroker, I already had the N-case and the axles only set me back $165.00 dollars (not including shipping). I've probably thrown away $165.00 (or much more) on a lot stupider and much more worthless things in my past.
I have half a dozen or more 31-spline Traction-Lok 9-inch 3rd members --two of which are factory N -cases. I haven't had a 28-spline Traction-Lok 9-inch 3rd member in 10 or 11 years. I wanted a Traction-Lok to replace my single track differential with. For me, buying the 31-spline axles was cheaper than buying a 28-spline Traction-Lok differential to swap in. The 31-spline axles also happen to be about 30-percent stronger so, it was a simple choice for me to make.
Do I 'need' 31-spline axles or an N-case? Probably not any more than I 'need' a '69 F-100 but, need or not, I wanted them, found them and I have them.
Old Jan 7, 2015 | 06:30 PM
  #195
ultraranger
The 31-spline axle on the left is the 'Daytona' axle I pulled from the '75 F-150 4x4 the 9-inch N-case came from.
Notice the very large tapered Timken roller bearing, compared to the bearing on the 31-spline axle from the '71 F-100 and the VERY thick bearing retainer.
