Bye Bye Front Drums
Old May 18, 2019 | 12:29 AM
  #616
Jim Lovell's Avatar
Jim Lovell
I got all the parts together off a 77 F150 to swap onto my 68. Where should I drill holes for the disc brake brackets? Is there a specific measurement (i.e. so many inches from the coil tower rivets) or just eyeball it?
Old May 18, 2019 | 01:23 AM
  #617
GaryKip's Avatar
GaryKip
Didn't you get the entire assembly?
Old May 18, 2019 | 10:08 AM
  #618
Jim Lovell's Avatar
Jim Lovell
Whoops. Missed quoting a picture of the disc brake hose brackets. I have everything I need. But don't you have to relocate the hose brackets?
It was pouring rain in the junkyard when I pulled my assembly so I left without measuring where the brackets go.
Old May 19, 2019 | 02:38 AM
  #619
Cracker289's Avatar
Cracker289
I just jury-rigged an L-bracket to move mine into a better position.
Old May 20, 2019 | 12:43 AM
  #620
GaryKip's Avatar
GaryKip
Looks good to me. I'll keep that fix in mind when I do my drum to disk swap.
Old May 20, 2019 | 09:33 PM
  #621
ultraranger's Avatar
ultraranger
I just used the existing bolt hole that held the original small frame bracket on and made a second hole above it to attach the larger hardline-to-flexible caliper hose brackets.
This was on a '65 F100 I had worked on but I did the same thing with my own '69 F100.
Old May 22, 2019 | 03:04 PM
  #622
EJP Bumpside's Avatar
EJP Bumpside
Bracket Placement
I am in the same process, taking all from a '78 F150 and putting onto my '70 f100. 1.875" measurement is from the spring tower. Top of brackets are roughly flush with top of frame. Ultraranger's location looks The same.
Old May 22, 2019 | 05:09 PM
  #623
bajafishnut's Avatar
bajafishnut
You guys, with 2WD's have it way easier than those of us with 4x4's, and the old closed knuckle hubs. Not wanting to loose my HD 12 bolt hubs, and the 3500 lb rating, it is not an easy swap to disc brakes for me. At least I do not know of an easy way to do it with the closed knuckles...
Baja
Old May 23, 2019 | 02:10 AM
  #624
GaryKip's Avatar
GaryKip
Baja
That would be a challenge indeed. Has anyone ever figured it out?
Old May 23, 2019 | 10:11 AM
  #625
bajafishnut
Not to my knowledge??
Baja
LACzar
24
Sep 13, 2017 06:51 PM
Dr.J
Aug 10, 2016 03:37 AM
Shanep
19
Jun 7, 2015 06:17 PM
hillcountryflt
16
Dec 17, 2014 06:43 AM
