Sponsored by: Real Truck
Monte's 04 Build Thread
Old Sep 29, 2016 | 08:12 AM
  #1921
wizkid00104's Avatar
wizkid00104
Hmmmmm.... that is interesting. But the bump stops haven't changes. They are cast onto the knuckle. Maybe it is the box.... like the shaft was not installed in the proper rotation.... so in theory it could turn more alft than right because of the pitman arm not being centered.
Old Sep 29, 2016 | 08:24 AM
  #1922
xmontex4's Avatar
xmontex4
Yeah i noticed one day when i was back ing into a spot at work and i heard metal on metal rubbing and i got out and saw my pitman arm was contacting the spring. My turning radius does seem to be any different right or left but when i was comparing with Dennis (Drey04) he has the same setup and no issues. the steering box is all i can think of that is different.
Old Sep 29, 2016 | 08:29 AM
  #1923
wizkid00104
Is it a drop pitman arm or the standard one?
Old Sep 29, 2016 | 08:58 AM
  #1924
drey04's Avatar
drey04
did someone say my name? yep no clearance issues with my skyjacker drop pitman arm.
Old Sep 29, 2016 | 09:04 AM
  #1925
xmontex4's Avatar
xmontex4
Hey! haven't heard form you in a while lol.
Its a drop pitman arm so in theory its the same as standard springs and a regular arm.
now that i think of it Dennis and i were going back and forth and Dennis you have lift springs right? i have add-a-leafs in the front so i have less or an arch in my springs, i remember we talked about this lol.
Old Sep 29, 2016 | 09:08 AM
  #1926
drey04's Avatar
drey04
lol yeah life went crazy for a while and is still crazy... but I still lurk around on the forums. Yes I have lift springs in the front... 4" skyjackers, which have sagged over time and are probably for more like 3" now haha
Old Sep 29, 2016 | 09:12 AM
  #1927
wizkid00104
So Drey has lift springs and you have add-a-leaf. Is that what you think the problem is?
Old Sep 29, 2016 | 09:15 AM
  #1928
xmontex4's Avatar
xmontex4
Yeah I have more physical leafs now than Dennis does so the thicker leaf pack might be my problem with the lift. Mine is like 3" now as well after sagging and will likely be 2" once the cummins goes in lol.
Life's been getting crazy for me as well, its starting to settle down though so i can finally stop lurking and start working again lol.
Old Sep 29, 2016 | 09:21 AM
  #1929
drey04's Avatar
drey04
yeah your thicker springs may be the issue...
and your truck is looking good btw. making progress
Old Sep 29, 2016 | 09:23 AM
  #1930
xmontex4's Avatar
xmontex4
Yeah, maybe ill wait on the steering box until i get the 4" springs in once i move to the front axle.
Thanks! I'm hoping to test fit the Cummins this weekend to see how she sits in there and where i have room for Turbos and if i can fit the SAE3 adapter or if i need a Destroked Trans adapter.
Old Sep 29, 2016 | 09:33 AM
  #1931
Toyman's Avatar
Toyman
Hey Dennis, haven't seen much of you around the threads lately. Glad you are still here
Sorry Monte, had to say hi. Now back to your regular scheduled truck build
Old Sep 29, 2016 | 09:39 AM
  #1932
xmontex4's Avatar
xmontex4
Don't be sorry, I'm glad we didn't lose him as well lol.
Old Sep 29, 2016 | 09:40 AM
  #1933
drey04's Avatar
drey04
hey rich yep still alive
haha thanks!
Old Sep 29, 2016 | 11:28 AM
  #1934
lwarrior1016's Avatar
lwarrior1016
Im a little late to the party but good job getting the 5.4 out of there! Also, for those egr tubes, hit the flat side of the nut with an air hammer and spray some pb blaster down in them. They come right off after the air hammer. Also, with that egr manifold, you can cap the egr port off and use it as a plain manifold.
Old Sep 29, 2016 | 12:48 PM
  #1935
xmontex4's Avatar
xmontex4
Thanks, If i end up keeping the motor that is my plan but for now i am going to fix the EGR tube that bent slightly when removing the motor and get her back together and tied down to a dolly.
