Snowseekers 6.0 experience.
Old Jan 16, 2014 | 11:10 PM
  #241
Unrealo4's Avatar
Unrealo4
So im planning on doing headgaskets and arps in the next few months. While im in there ive thought about doing a few things. One is changing out the push rods to the newer shorter style. Im curious my motor is a 03 version with 210k on it. Im planning on 350k+ at least. But does it hurt anything to swap the push rods now? Or is that somthing you do on a rebuild. Thanks
Old Jan 17, 2014 | 05:32 AM
  #242
npccpartsman's Avatar
npccpartsman
Here are the files you need and the push tube part number is 8c3z-6565-b
File Type: pdf
File Type: pdf
Old Jan 17, 2014 | 07:39 AM
  #243
Snowseeker's Avatar
Snowseeker
If you are doing studs, gaskets, and push rods I would want to do the lifters as well. Mainly because with the shorter push rods the lifters will be wearing in a new spot and I can see that causing trouble a few months or years down the road and it is not a job you want to do twice.
Old Jan 17, 2014 | 10:21 AM
  #244
Unrealo4's Avatar
Unrealo4
Didnt mean to hijack the thread. But I read a discussion on the shorter pushrods a page or so back. And I didnt know if you could change the rods or if it was wise. Kinda like not changing horses mid stream. Thanks for the answers.
Old Jan 17, 2014 | 02:26 PM
  #245
Snowseeker's Avatar
Snowseeker
New head gaskets came with stand pipes AND dumby plugs!
Also new front cover gasket came with water pump o-ring, some thick little o-ring, and a new front seal!
By golly I think I may have everything I need!
Old Jan 17, 2014 | 02:33 PM
  #246
npccpartsman
The small o-ring may be for the lpop relief valve or possibly the heater hose tube....that's all I can think of.
Old Jan 17, 2014 | 05:45 PM
  #247
Snowseeker's Avatar
Snowseeker
I think it is for a heater hose. When I lifted up and flipped over the front cover an old one just like it fell to the floor. Came from a spot near the thermostat I think.
Did some stuff today because I just wanted to do something with it.
New lifters lubed up and installed.
Branch tube installed.
Rear cover installed.
HPOP cover installed.
Daughter poses.
Waiting for yellow tape now.
Old Jan 17, 2014 | 05:48 PM
  #248
Snowseeker's Avatar
Snowseeker
Oh yeah, the new lifters fit the boxes tighter than the old ones did.
Old Jan 17, 2014 | 07:03 PM
  #249
Snowseeker's Avatar
Snowseeker
IPR oring kit anywhere? Can't find just the IPR orings.
Old Jan 17, 2014 | 08:03 PM
  #250
MisterCMK's Avatar
MisterCMK
I think the ipr screen and o rings come with the updated stc kit.
Sent from my Telegraph using IB AutoGroup
Old Jan 17, 2014 | 08:31 PM
  #251
Jigger2020's Avatar
Jigger2020
Snow the pic with your daughter is precious man, good luck with the build
Old Jan 18, 2014 | 07:59 AM
  #252
npccpartsman
Is that a good thing or a bad thing?
Old Jan 18, 2014 | 10:11 AM
  #253
Snowseeker's Avatar
Snowseeker
Must just be machined a tad larger on the box end. Not so tight that I worry about it, just an observation.
On the branch tube and fitting, how come when searching for STC fitting and branch tube I only see that bolt together fitting everywhere and never see any talk or mention of the type of branch tube I have?
Looks like the 6.0 IPR is almost exactly the same as the 7.3 IPR. I think I will order 7.3 IPR orings and see if they fit.
Old Jan 18, 2014 | 10:15 AM
  #254
npccpartsman
Because that type of branch tube rarely fails and usually only due to it rubbing on the cover, which has an updated "groove" machined into it. Kind of pricey though......
I do have a part # for just the IPR screen: IPR Valve Screen 3C3Z-9H529-A Not sure if it has the O-rings included though.
Old Jan 18, 2014 | 10:29 AM
  #255
Snowseeker's Avatar
Snowseeker
Yeah I saw that part number on the IPR kit on ebay. But it was something like $36 for 3 orings and the screen. I believe the 7.3 IPR kit was around $15. I will be checking into it more here in a few minutes.
My IPR screen and main oring are in good shape and I wouldn't hesitate to use it like it is but the smaller green o-ring has been stressed and is the one I would like to replace.
I was mistaken on the dumby plugs earlier. The head gaskets came with stand tubes and their top counterpart that screws in the holds them in place. No dumby plugs. They are cheap so when I make up another "missing parts" order I will throw them in there.
Expected yellow tape is the 22nd.
