Snowseekers 6.0 experience.
Old Feb 4, 2014 | 08:25 PM
  #346
Yahiko's Avatar
Yahiko
My dad once had a client send a package from Puyallup,Wa to Spanaway,WA.
It should of taken only 2~3 days at the most. The two are less than a mile apart.
it took 2 weeks and went by way of New York.
So your package must be taking the scenic route. With long layovers.
Could weather still be holding things up? I got a few warnings from UPS
about delays that they were having out east.
Sean
Old Feb 4, 2014 | 08:26 PM
  #347
Snowseeker's Avatar
Snowseeker
Originally Posted by 9228.bobcat
Might take a trip up in canada before it gets to you.lol
Would hate for it to be the wrong part and have to return it!
Old Feb 5, 2014 | 04:59 PM
  #348
Yahiko's Avatar
Yahiko
Any luck on the parts showing up?
I got this from UPS today.
Winter Weather Impacting Deliveries in the Ohio Valley, Great Lakes, and Northeast
UPS is closely monitoring the impact of freezing rain and snow across the Ohio Valley, Great Lakes, and Northeast,
causing service delays. We have contingency plans in place to ensure the safety of our employees and to minimize
the weather’s impact on pickups and deliveries.
Check ups.com for the latest information on service delays (including a list of ZIP codes where no pickups or deliveries
are being made today) and to track the status of your packages. For impact to UPS Freight pickups and deliveries, visit UPS
Freight. As always, UPS is committed to making every effort to provide service to areas where conditions permit safe access.
Please note that the UPS Service Guarantee does not apply when transportation networks are disrupted due to conditions beyond UPS’s control.
Sean
Old Feb 5, 2014 | 05:51 PM
  #349
Snowseeker's Avatar
Snowseeker
Didn't expect the flex section today since it was in MN. So I went and ordered a new power steering line that should be here in the morning. Got 3 gallons of ford gold (in stock at my local bumper to bumper) and 3 quarts of merc 5 for the power steering/hydraboost. Since I am waiting for the flex section and power steering line I had them also order a ford oem oil filter which would be there tomorrow as well.
I come home and what is that box by the door? Why that there is a flex section! So I threw that in today!
Drill out rivets and take of nut.
Stock flex sections have a solid pipe inner liner then the outer bellows.
Mocked up and tack welded.
All welded up and shield installed. Could only use the one pop rivet location because the new flex section is a bit longer and the bottom rivet mount had to be cut off. I could have welded it back on and put the rivet in but I didn't feel the need.
Everything bolted up tight.
I'll check on the power steering hose in the morning. Hope they get it fairly early and I can get at dropping the cab!
Old Feb 5, 2014 | 06:00 PM
  #350
Yahiko's Avatar
Yahiko
If you find that you need the rivet you can also use Duct Tape.
NOT
The give away will be a rattle and a flat chunk on metal on the road.
Sean
Old Feb 5, 2014 | 06:11 PM
  #351
Snowseeker's Avatar
Snowseeker
NOT
Sean
That metal could have came from anywhere!
Old Feb 5, 2014 | 06:13 PM
  #352
Jigger2020's Avatar
Jigger2020
Good you were able to get that done today, that's progress
Old Feb 5, 2014 | 06:38 PM
  #353
MisterCMK's Avatar
MisterCMK
Sean
2-3 days? If I ship something across town via UPS it is delivered next day.
Old Feb 5, 2014 | 09:34 PM
  #354
DerbyPowerstroke's Avatar
DerbyPowerstroke
Jesus, what's taking you so long. Diesel fuel will be all used up by the time you're done.
Old Feb 6, 2014 | 05:42 AM
  #355
npccpartsman's Avatar
npccpartsman
Originally Posted by Snowseeker
Now the package is in Saint Paul, MN! WTF USPS? Only state left is MI and it would have gone full circle around my state.
Did it go UPS or USPS? FedEx is the carrier for USPS priority mail type stuff.
Old Feb 6, 2014 | 07:41 AM
  #356
Snowseeker's Avatar
Snowseeker
lol I know right. Good thing I have a half full tank of off road diesel in the 6.0! LOL
USPS, I don't know if it was a fedex truck that dropped it off or the mailman.
Old Feb 6, 2014 | 08:53 AM
  #357
npccpartsman
USPS delivers them but FedEx does the heavy lifting AFA transportation goes.
Old Feb 6, 2014 | 07:11 PM
  #358
Snowseeker's Avatar
Snowseeker
All back together again! I cranked it over only a few seconds before oil came gushing up into the filter housing. I was pretty happy about that. So I threw the new oem oil filter in with new cap oring. I filled it up with ford gold coolant and distilled water. Which by the way someone bought all the distilled water out besides one gallon at Kmart, must be a few 6.0 owners around here! I was able to dump in 1.5 quarts of power steering fluid so far. I picked up a couple quarts of SL trans fluid to replace what was lost with the coolers.
Nothing leaking out yet!
So then I crank... Using just the starter relay wire and key off I turned the motor over 5 times now for a period of around 20-25 seconds. How many times do you guys figure I should do that before attempting an actual start? I never drained the HPOP just the branch tube and both rails need to be filled.
Came in to post, eat, let the starter cool, and the batteries charge. Will go out for more cranking in a bit here.
Old Feb 6, 2014 | 07:15 PM
  #359
9228.bobcat's Avatar
9228.bobcat
Your good to go. Hook it all up and crank it up. Might take a bit but not much I wouldnt think to crank it.
Old Feb 6, 2014 | 07:35 PM
  #360
Snowseeker's Avatar
Snowseeker
btw that "wet patch" under the truck is actually ice. Snow that was on the truck melted and dripped on the floor and froze when it hit the floor.
