Snowseekers 6.0 experience.
Old Dec 29, 2013 | 06:13 AM
  #211
npccpartsman's Avatar
npccpartsman
Originally Posted by Snowseeker
Oh yeah, apparently this lifter is used in V6's, V8's, fords, chevies, chryslers, all sorts of motors.
The list is extensive. I have quite a few crossovers for it besides the $32 each from Ford--LOL
Old Dec 29, 2013 | 06:25 AM
  #212
zrt600guy's Avatar
zrt600guy
I ran dyed diesel for over a year and a half and 15k miles; no problems whatsoever. My fuel was coming from generator setups that required us to change fuel once a year or were converting to an alternative fuel. The price was right, and I'd run it again.
Old Dec 29, 2013 | 08:33 AM
  #213
Fulthrotl's Avatar
Fulthrotl
Originally Posted by MisterCMK
You would be surprised where you might get dipped. They dipped my tank and I live in the suburbs. I don't even know where I would find farm fuel near me.
Why would they have to be reflashed? What makes an on road pickup different than off road machinery? They both require clean fuel. The off road fuel killing trucks is a lot of urban legend if your ask me.
as far as red tank damaging anything in a diesel, it won't.
in calif. it's #2 ULSD, the exact same product sold from the on
road pump. it comes from the same fuel manifold, and when they
load the fuel bowser, they meter in dye.
the ONLY difference is that there aren't any road taxes paid on the
fuel, and that is why it's dyed. it won't destroy o rings, set engine
codes, cause global warming, or give your grandparents indigestion.
it doesn't take much in the tank to color the whole tank red. if you
get caught on road with a red tank, the fine is about $5,000 in calif.
usually urban areas don't have people checking on the fuel with a
dipstick, with one exception... heavy equipment operators with
a bed tank and a pump for fueling will sometimes be targeted, as
they sometimes will fuel their road vehicle with red tank.
if you have red tank in your tank, the best way to get rid of it, is
simply to run the tank as low as you can, and fill up with #2 diesel.
do it a second time, and you should be able to pass a dip test nicely.
fuel systems that have a regulated return are a problem, as the fuel
in the system will keep returning to the tank and staining the new
fuel... takes quite a few more tanks to dilute the dye.
i used to work as a project manager for a road building and sewer
construction company, and the field guys would sometimes top off
their tanks from the 10K fuel bowser on the job that was used for
fueling the scrapers and track hoes.
until one day, everyone leaving the job got pulled over at the gate as
soon as their wheels hit pavement, and dipped. over a dozen company
vehicles were cited, at $5k a pop.
so yes, using red tank can cause severe damage.
to the wallet.
Old Dec 29, 2013 | 09:12 AM
  #214
Snowseeker's Avatar
Snowseeker
Great info and quite the story! You would think as one got pulled as they left the work area they would have radioed back for the rest to stop and not leave.
I am not to worried about the dyed diesel. I was just a bit worried about it from the beginning because I knew years ago it was different.
Old Jan 6, 2014 | 06:47 PM
  #215
HT32BSX115's Avatar
HT32BSX115
Originally Posted by run6.0run
Reminds me of a phrase,, "why is there never enough time or money to do it right the first time,, But always enough time to do it again?"
You must hang out on the iboats.com forum!!
There was probably someone there that DIDN'T put that fuel in their truck and then maybe "ratted"?
Up here in Wa, they pull fuel in truck stops, and large farms etc. I don't think very many people with diesel LT trucks and passenger cars ever get "checked"..........
How's that rebuild coming?
Old Jan 6, 2014 | 07:54 PM
  #216
Snowseeker's Avatar
Snowseeker
I am on the iboat forum!
The rebuild is just sitting around till parts start coming in. I have some other work to catch up on anyhow.
Old Jan 6, 2014 | 08:04 PM
  #217
MisterCMK's Avatar
MisterCMK
I've been checked. I live in the suburbs...
Sent from my HTC6500LVW using IB AutoGroup
Old Jan 6, 2014 | 08:18 PM
  #218
Tofan's Avatar
Tofan
But you also live in MN and not in WA
Great tear down Snow, and looking forward to seeing you put it back together.
Old Jan 6, 2014 | 11:17 PM
  #219
HT32BSX115's Avatar
HT32BSX115
How did they do it? Did they just pull you over on a random check or do you live on a farm or work at a place that uses un-taxed fuel?
I would be kind of reluctant to allow them to do it without an actual warrant.
I also wouldn't run the stuff either. You'd be in evading BOTH state AND Federal taxes.
After the state got through with you the Feds would go to work!
"why is there never enough time or money to do it right the first time, But always enough time to do it again?"
Yeah. It was really a bummer about the Mod that had that quote in his "signature" who passed away.......
Old Jan 8, 2014 | 07:04 PM
  #220
Snowseeker's Avatar
Snowseeker
Ready to spend all my money...
Beside the oil pump, water pump, and front cover gasket anything engine wise I am missing here? I am hoping I don't have to do the nipple o-rings but I will wiggle them and see how they feel. Hope its big enough to see.
Old Jan 8, 2014 | 07:12 PM
  #221
HT32BSX115's Avatar
HT32BSX115
You decided to do the ARP studs & head gaskets? I would probably be very tempted to do that if I was into it that far.....
Old Jan 8, 2014 | 07:25 PM
  #222
Snowseeker's Avatar
Snowseeker
Yeah, I have both heads pulled to install lifters.
Old Jan 8, 2014 | 08:08 PM
  #223
MisterCMK's Avatar
MisterCMK
I would look at Tousley for your OEM parts. www.touselyfordparts.com
They are cheaper on all of the OEM stuff.
Old Jan 9, 2014 | 07:35 AM
  #224
run6.0run's Avatar
run6.0run
I can't remember if you were doing push tubes. I'd get the 6.4 tubes, iirc, Ford superceded the 6.0's with the 6.4 ones.
Old Jan 9, 2014 | 07:37 AM
  #225
run6.0run's Avatar
run6.0run
You aren't alone Chris on your sig "avid winter hater"!!! I'm a hater too
