AE class is in session!
Old Sep 24, 2013 | 11:13 PM
  #451
TKegs763's Avatar
TKegs763
I ran some cylinder percentages tonight, as I am still chasing a miss, jerk, chug, or harmonic whatever. Checked for codes and there were none. I still love my truck, so I will win eventually thanks to you guys.
Here are my percentages and what do they mean?
#1) 0.0
#2) .2 - .6
#3) .7 - 1.3
#4) 2.0 - 2.6
#5) .2 - .4
#6) 0.0
#7) 0.0
#8) 4.7 - 5.6
Old Sep 25, 2013 | 03:19 AM
  #452
Tugly's Avatar
Tugly
Originally Posted by finnad
Ok I will ask, can you tell the above issues ( cracked cup and 2 loose injectors) from the AE or was this recorded prior to tear down?
I had no clue what was going on (too may symptoms and causes at the same time), but I knew it was injector related and it was getting worse. Tear down revealed the specific issues.
Originally Posted by TKegs763
...I am still chasing a miss, jerk, chug, or harmonic whatever...
#4) 2.0 - 2.6
#8) 4.7 - 5.6
That #8 is a small blip on the radar, it could be a fast bird or it could be an armed stealth helicopter. Chances are it's just a gray CPS (bird). #4 looks OK. Not excellent, but OK.
Miss, jerk, or chug.... I forgot, have you done anything to your injectors recently? Is the "jerk" one of those things where you're accelerating and you feel a "burst" and a couple of small jerks?
Old Sep 25, 2013 | 08:09 AM
  #453
TKegs763's Avatar
TKegs763
It's more like a consistent jerk while at cruising speeds, and it's very consistent. The chug feels like a huge exhaust leak, but I can't find one and it sounds like its coming from inside the engine. Yes, Jeffreyt and I changed my #4 injector orings since I had it out from breaking a hold down bolt off. I did plug the red line going to the waste gate, was I supposed to unhook some type of sensor when I did that? What next? Any homework? I am supposed to leave for West Monroe next week with my camper, but I don't want to pull it running like this. With my luck I'll end up stuck on the side of the road at midnight with some guy like Shelby from 'Axe Men'. I don't have a grey CPS, I have the one towards the bottom of my sig. It's more of a dark charcoal color or even a dark shade of blue maybe.
Old Sep 25, 2013 | 11:45 AM
  #454
Tugly's Avatar
Tugly
OK... I missed a thread, or they're all rattling around in my head - I vote the latter. Here's a guess - you torqued the injector bolts and got a bit gorilla-ish on one?
Whatever the case, it sounds like you're missing a nozzle washer, it's installed backwards, or an injector bolt worked loose somewhere. Looking at the profile of the washer, there is a bump side and a cave side. The cave side should face the injector. Did you notice this detail when installing O-rings?
Old Sep 25, 2013 | 01:41 PM
  #455
TKegs763's Avatar
TKegs763
Absolutely! And as a matter-of-fact you held my hand through that one too. I will pull the valve covers off tonight and fire it up to see if all of the injectors are spitting oil. I will also check all of the Bolts. I am really down to the point that it is probably just the injectors themselves. They are the original sticks and have well over 300,000 miles on them. I guess I'm just in denial.
Old Oct 4, 2013 | 10:43 AM
  #456
schlepprock250's Avatar
schlepprock250
Hey guys. I'm still trying to figure out why my AE won't read FIPW or my vehicle speed. I contacted AE support and he issued me a fresh copy,11.0.1.,but said there was no known issues with AE and either issue I was experiencing. My speedometer works,but only shows as like .024 on AE, and the vehicle speed status(can't remember exact wording) just shows .0. Anyone have any thoughts on this?..Thanks..Phil
Old Oct 4, 2013 | 10:16 PM
  #457
Tugly's Avatar
Tugly
I cry fowl. I could hand these guys a 1/2 dozen different owners that can't get the FIPW to show the correct value without putting in a multiplier of 10, and about 4 guys that can't get speed readings. Maybe I should call them when I'm not remodeling my house, buying a DD, or working on Stinky.
Old Oct 4, 2013 | 11:28 PM
  #458
jhand124's Avatar
jhand124
Mine is the same, FIPW is off and MPH doesn't read. I contacted them about the MPH earlier today and they have no idea, sent me a the latest version too, but mine was 11.2.2.
Old Oct 5, 2013 | 07:56 AM
  #459
jhand124's Avatar
jhand124
My CC test didn't work either, but I'm thinking my oil may have been borderline on temp.
Old Nov 1, 2013 | 10:50 AM
  #460
Mowing Man's Avatar
Mowing Man
Know this thread is getting old, so sorry. I'm trying to figure out what value to select on AE to check my injector perdels. Getting ready to change o rings on my flatbed, 223k, but wanted to check that my perdels were good. Did the CC test and everything looked good. If someone could post what selection I need to make under the live data grid, I'd sure appreciate it! Thanks
Old Nov 1, 2013 | 11:27 AM
  #461
Mowing Man's Avatar
Mowing Man
Never mind, found it on Wood n things website. Didn't realize it was an idle test and that EOT had to be above 125 ish.
Old Dec 5, 2013 | 11:47 AM
  #462
bkuuz1's Avatar
bkuuz1
I know I'm late to this class sessions but I'm trying to get caught up.
Here is my data I just took with AE. My truck has not been ran for the last several days and is just sitting in the garage.
I live just outside of Denver with an elevation of 4,984 FT.
The data is KOEO.
Exhaust back pressure sensor is jumping around and spiking at 16.04.
What do you guys think? In case this doesn't show up as a photo here is the data
Exhaust Back Pressure- 15.9
Manifold Absolute Pressure- 11.9
Barometric Pressure- 3.75
/Users/bkuzanek/Pictures/iPhoto Library/Originals/2013/Dec 5, 2013/Truck 2001 F250 7.3 AE class I.jpg
Old Dec 5, 2013 | 12:18 PM
  #463
Tugly's Avatar
Tugly
The last two numbers are good, but your EBP is off-the-chart bad with the jumping around and that number for a diesel submarine's altitude. You can try to clean it, but mine wouldn't snap out of it when it got that bad.
Old Dec 5, 2013 | 02:24 PM
  #464
bkuuz1's Avatar
bkuuz1
Thanks for the quick reply Tugly,
I will have to try and clean up the sensor and recheck. Hopefully I worn have to replace it.
Old Mar 5, 2014 | 08:24 PM
  #465
Snowseeker's Avatar
Snowseeker
Did everyone leave school?
I finally have AE on the way and am doing some reading. I have both a 7.3 and 6.0 to play around on.
