AE class is in session!
Old Apr 22, 2013 | 05:51 PM
  #256
caverjoe's Avatar
caverjoe
YIKEEEEEEES>>>>>>>
Old Apr 23, 2013 | 10:43 AM
  #257
matt9923's Avatar
matt9923
Originally Posted by cjgray1974
I'll have to see if I can find it again, but was reading thru either my Ford shop manual or the Ford powertrain control/emissions diagnosis manual, and there are several test where you need to run the engine at WOT for 3 min before taking a reading.
You'll want to do this in stock setting as some tuners disable the rev limiter.
yes there are a couple test that require a 3 min WOT run in park/neutral. Modis does it, think to see contribution, don't remember.
Old Apr 23, 2013 | 10:52 AM
  #258
matt9923's Avatar
matt9923
Finally got out and recorded some data, ICP never went over 2500 even at WOT and went up to 48 duty cycle. Anyone see anything bad here? I get the injector pressure high/low sometimes and it runs rough. Ran great today...
stock 7.3
Old Apr 24, 2013 | 10:29 AM
  #259
Tugly's Avatar
Tugly
Yes... there are a number of tests to conduct with WOT in the driveway, and a chipped/modified truck can bring undesirable results - even if in "stock" mode. I choose not to use this procedure and count on other methods.
stock 7.3
Great job on the scaling on your graph! That's utilizing the power of AE. Your IPR is a little high for that ICP. You could have tired sticks, an inaccurate ICP, a tired HPOP, leaky injector O-rings, air in fuel, or a few other possibilities. Any time I see an ICP/IPR mismatch on a stock truck, my first inclination is to look for air in fuel. You can do this test with the tank at 1/4 tank (or lower) and again at full tank - that can hint at air in fuel.
One other thing I've noticed with AE data I recieve: Many people will use all three MAP readings, two throttle readings (% and volts), two ICP readings (PSI and volts), and various other duplications of sensor readings. The PSI, %, temps, and other readings are derived from the voltage... so multiple instances of the same reading just hogs sampling time and data space. If you suspect one particular sensor, you can get this detailed for testing. If you want to see the overall performance of the vehicle, you should do everything you can to pare down unnecessary readings.
Old Apr 25, 2013 | 05:58 PM
  #260
Chipworkz's Avatar
Chipworkz
I got my AE in the mail today. My EBP is 2.5 psi higher than my MAP so I guess it is time for a new sensor. My MAP and Intake Manifold Absolute reading are the same so it looks like the EBP is bad. I have checked it withing the last 5k miles or so and I had no soot build up at all so I don't think it is just dirty.
My mileage kind of sucks and I pull heavy with it normally so I think it is better if I get a new sensor than just run with this one. What do you guys think?
Old Apr 25, 2013 | 11:12 PM
  #261
Tugly's Avatar
Tugly
Some live with it high, and others fix it. I know what happens when the tube is open, and it has been documented that a high reading will harm MPG... but I haven't yet heard reports of improvement after the swap (other than my own experience). Mine was about 4 high. I don't recall if you clicked those last two links in my signature.
Old Apr 25, 2013 | 11:37 PM
  #262
Chipworkz's Avatar
Chipworkz
Yes I have the docs from both links saved already. Lots of great info in there. As far as the sensor, I pulled it off the tube and had the same results so I know it is the sensor and not a clogged tube. I am placing an order with Clay tonight. I want everything to be 100% before doing a chip or anything else. With only 114K on this truck, I am keeping it for a long time so I look at keeping everything up like it should be as an investment.
Old Apr 26, 2013 | 08:34 AM
  #263
matt9923's Avatar
matt9923
I looked at % vs Voltage and it seemed pretty close on the ICP, how close should they mesh? i rebuilt the IPR, o-rings, not sure what else could go bad on it? I will do a full tank test and get back to you. I think injector o-rings are going to get done soon, although I have herd the newer ones rarely go bad but it does have 190k
Old Apr 26, 2013 | 08:51 AM
  #264
Tugly's Avatar
Tugly
The % is derived from the volts. You are taking two readings of the exact same thing, but there is time between each reading... so you will see small differences. This is aking to double-checking the ICP before it has a chance to change very much.
At 190K, you might be able to extend the life of the injectors with O-rings... or maybe not. It is an inexpensive (but labor-intensive) gamble. Many have had big gains by doing this, and at least you'd have tended to/inspected everything under the valve covers. UVCH, glow plugs, and O-rings can all be replaced while you're in there. Some will say do the 50-cent mod. I say that's cheap... by every definition of the word.
Old Apr 26, 2013 | 02:34 PM
  #265
Chipworkz's Avatar
Chipworkz
I haven't had a lot of time to play with it but here is my first graph. I was planning on buying a T500 since everyone talks about the e99 HPOP being weak. I did a couple of WOT runs and and peaked out at 2515 PSI and a 37.89 % duty cycle. Those are ok numbers for a stock tune truck isn't it? I was also defueling maybe since the new RR billet wheel was pushing my boost up around 23 PSI and my needle was bouncing. I haven't had a chance to put my regulator on it. SO do I need a T500 with these numbers or am I ok until I get some tunes?
Thanks again, looking forward to the next lesson Tugly!
Old Apr 26, 2013 | 04:39 PM
  #266
JT250's Avatar
JT250
I don't think I would waste money on a T5 with those numbers. I have one and didn't notice much of a change even before I.had new sticks.
Old Apr 26, 2013 | 10:09 PM
  #267
welove2drive's Avatar
welove2drive
Subscription please.
Old Apr 27, 2013 | 09:35 AM
  #268
Tugly's Avatar
Tugly
With due respect to my friend JT250, your HPOP is doomed with a tuner[*EDIT - error here, explained in post #278]. A tuner is going to ask for 2800-3000 PSI, with a wider pulse width than stock, and at higher RPMS than the stock tune can get you to (with defueling). You will end up with 1500-1800 ICP and the truck will be slower, s**tier, and hotter than what you have now... but the lower part of the RPM band will rock on. Sorry.
You are already having issues with the stock tune (75% IPR is OK, but it doesn't scream "bring it on"). It could be a weak HPOP, but it could also be air in fuel, leaky O-rings, tired injectors, bad ICP or IPR, oil leak, or a couple of other things.
I have very limited net access where I'm at... so even a screen refresh may kick me. I don't know what hardware you have on your truck right now, but it looks like it may take a little effort and/or money to get your truck to 100%
Old Apr 27, 2013 | 09:39 AM
  #269
Tugly's Avatar
Tugly
By standing on my head at the hotel room door, and typing with my toes, I was able to get one more bar of signal. I see you have the Hutch and a prefilter. I had a prefilter, then I noticed my sticks pulled more than it could deliver. I replaced my fuel prefilter with a simple WIX disel fuel inline strainer.
Old Apr 27, 2013 | 10:05 AM
  #270
Chipworkz's Avatar
Chipworkz
Thanks Tugly, if there are signs that the HPOP isn't putting out what it should, I would assume it is the HPOP (e99 15* pump) and not one of the many things you listed. Or at least I hope so since the truck only has 114K and runs just fine. I will be doing some more testing and runs this Sunday so if there is anything specific you would like me to show for an example, let me know and we can do some more learning.
