AE class is in session!
Old Mar 6, 2013 | 06:16 PM
  #106
Pitcrw6's Avatar
Pitcrw6
Originally Posted by Tugly
I wouldn't want the computer and the interface to share a ground - that sounds like trouble. My inverter "floats", meaning no ground. I was careful when I set my system up, but few know how to do this properly and AE will just say "Don't do it."
Well do tell on how to set it up.
Old Mar 6, 2013 | 08:10 PM
  #107
Tugly's Avatar
Tugly
So, does everybody promise not to...
  1. ...blow up their computer?
  2. Blame me if they do?
I can't recommend it (I don't want to declare it "SAFE"), but this is what I've used since long before I had AE:
CyberPower CPS-150BI [LINK]
I've found it anywhere from $50 to $10, and I have many, many hours and sessions with this unit.
Old Mar 7, 2013 | 06:51 AM
  #108
koski19's Avatar
koski19
I never even considered an issue when using my power converter in my trucks. I use a Lind Automobile Adapter Model #DE2045-1320 FA
Paid about $125.00 several years back to power my laptop before I bought the AE software. I bought my software (AE) a month ago and have used the diagnostics 4 times on 3 different trucks without an incident.
Here's the specs:
Designed for the Dell laptop D800, Ispiron. Input 11-16 Vdc 10 Amp Max
Output 20 Vdc 4.5 A Replace fuse with 15A 32v mini fuse. Assembled USA.
Here's a link for Ebay:
New Lind DE2045 1320 Automobile Adapter Dell Lattitude Inspirion Laptops | eBay
$59.99
Jeff
Old Mar 7, 2013 | 07:37 AM
  #109
bigb56's Avatar
bigb56
hmmm,
My early version of AE does not say I cannot power the PC from the vehicle, it just says to use an isolated ground inverter. Not knowing if my inverter was IG I tried it and all that happened is that AE would shut down immediately. Then I got the inverter that Tugly uses and all is well now.
Old Mar 7, 2013 | 01:27 PM
  #110
Skip1970's Avatar
Skip1970
Ive used mine on a cheap partstore invertor guess i better not do that again it was less then20 min tho
Old Mar 7, 2013 | 08:57 PM
  #111
Tugly's Avatar
Tugly
Thanks to cjgray1974, I have a large sampling of data. I need to convert it from Infinity to AE for graphing, as soon as I get more than 15 minutes here and there. I can say his data showed EBP, BARO, and MAP all at 14.2 PSI with KOEO - perfect for a truck at 1000 feet elevation. That truck gets a seal of approval for having a good reference for everything that follows... unless cjgray1974 lives in Denver.
Does the truck have a name?
Old Mar 7, 2013 | 11:03 PM
  #112
cjgray1974's Avatar
cjgray1974
I live at 1000 feet. As far as a name I named it Black Beauty when I added it to my garage but not sure if its gonna stick. I just bought the truck in December.
Old Mar 8, 2013 | 05:21 AM
  #113
Tugly's Avatar
Tugly
I think Pegasus fits better... it has wings.
Old Mar 8, 2013 | 02:06 PM
  #114
01PS's Avatar
01PS
I want to cry. I can't find my OBDII/USB thingie anywhere. This sucks. I need coors light and crown now.
Old Mar 9, 2013 | 10:11 AM
  #115
Tugly's Avatar
Tugly
AAGGHH!! I'm within a gnat's breath of getting the Infinity data formatted to be read by AE, and that timestamp is setting the whole project on fire. The timestamps on Infinity are a completely different format and the sampling rate is too fast for AE to digest, and there is no way to fix that other than put a fake time in there that is compatible with AE.
AE reads the volts on the BARO sensor and that's it, nothing else. Infinity converts the BARO volts to actual PSI.
While Infinity has 15 times the data reporting of AE, much of the reporting is the same data being repeated. In actuality, Infinity is roughly 4 times faster than AE, which is still pretty respectable... but I don't like all the repeat data that I had to sift through.
Looking at the data, I can see cjgray1974 has issues to resolve and this was a perfect data set (so much of it) to really show something interesting... but it's advanced stuff and we're not to that point yet. We need to understand the AE alphabet before we can read its stories.
Somebody please throw me a lifeline and give me some AE data (other than my own truck), using the instructions I gave about 1 or 2 pages back. I want to get over this hump quicker... as I'm sure some of you do too.
Old Mar 9, 2013 | 01:15 PM
  #116
MisterCMK's Avatar
MisterCMK
Are you trying to open the data from infinity with ae? Have you tried eec analyzer or something similar?
Old Mar 9, 2013 | 01:55 PM
  #117
Christof13T's Avatar
Christof13T
Pegasus are white/silver
Fire Mares are black...
Old Mar 10, 2013 | 07:34 PM
  #118
Tugly's Avatar
Tugly
Opening with AE would never work... the files are about as different as they get for being text files. I'm organizing the data, using AE rules of "grammer" so that I can open the files with AE... but the time stamp is the challenge. I tried organizing the time from Infinity in AE format, but the sampling rate is too high for AE to recognize. I can see the data and graph it, but I want to show an AE screen with stock data... which I don't have. I had to get on with my life, so I set it aside for now.
I recorded data, using my "homework" criteria... but I have a 38R, 4" exhaust, big sticks, and a boost fooler. MAP and EBP will not compare with a stock truck. The BARO data is pretty cool, I drove over a mountain pass with AE recording. I'll post that part when I get a few minutes more than I have now.
Old Mar 11, 2013 | 11:01 AM
  #119
akaFrankCastle's Avatar
akaFrankCastle
Give me two hours and I'll get you some data. Have to put the Toughbook on charge and reflash the PCM to stock tunes.
How long of a run do you want?
Old Mar 11, 2013 | 01:05 PM
  #120
akaFrankCastle
Gotta download Open Office real quick. Don't have MS Office on any of my systems and FTE won't take .csv files.
