I guess I stand corrected. I would trust Rich more than me anyway. However, Rich, those numbers aren't horrible are they. If he had SS sticks it might hang on there. But like you said if there is air in the fuel or something else that could cause problems.
Does anyone else think think that 23psi is low with the new RR wheel?
at 23is psi with the
I saw 22-23 with mine towing a few days ago, but that is 1st Gen wheel. And I know I have some leakage.From what I have read I would expect more.
Remember that this is an e99 truck so I have a smaller turbo an intake. I did a 2nd quick run. I just put my regulator on my map line and it looked like I gained 1 or 2 psi on my boost gauge. In comparison to my anti surge wheel, my gauge shows about a 3 to 4 psi gain with the new wheel. Again this is a stock tune and I believe that a performance tune would show higher gains from what I have read.
My Exhaust Back Pressure hit a high of 49.48 and was running around 16.2 at idle. Manifold Absolute Pressure peaked at 34.4 and was 13.4 at idle. Keep in mind though that that is with the regulator installed so the peak number may not be completely true.
As far as comments about what could be wrong like air in the fuel and things like that, what indicates that there could be an issue like that from the chart I posted? From what I have read, my numbers are right inline with a stock e99 truck. I appreciate all the comments and just trying to learn how to read the data and determine what if any issues there are.
What other indicators can I look for to figure out if I have an air issue or anything like that?
I did the Hutch mod because I was getting paranoid of the foot falling off. Once I got into the mod, I was dumbstruck as to what a poor design the fuel system was... and the added clear inline fuel strainer was a bubble machine, until I yanked the QDs. If you want to troubleshoot the fuel system, or tune your truck... a fuel pressure gauge is a must. I did a thread called "Chip Chasers" that covers all of this.
The boost is fine for stock, but your ICP/IPR indicates you will have issues with tuning [*EDIT - error here, explained in post #278] and your EBP is a lying liarface. Your EBP either needs cleaning or replacement, but it should match the MAP with KOEO.
My original HPOP with a stock tune was able to make 2800 PSI at 40% IPR, but fell flat with a big tune. The T500 gave me a huge jump in ICP with the big tunes, and I never saw 100% IPR again.
QDs? Does that stand for "quick disconnect's" Tug? I did the hutch mod on my truck already but are there any other connections besides the ones on the tank a person needs to worry about? I also used the wix inline filter but I've noticed I get one really big bubble in my filter that I just can't seem to get rid of.
Trying to keep this on topic and not just about tuning my truck, here are some questions/comments that may be helpful to better understand how to read the data. Sorry for asking so many questions and clarifications but this is a class right?
Originally Posted by Tugly
Originally Posted by matt9923
Finally got out and recorded some data, ICP never went over 2500 even at WOT and went up to 48 duty cycle. Anyone see anything bad here? I get the injector pressure high/low sometimes and it runs rough. Ran great today...
stock 7.3
Great job on the scaling on your graph! That's utilizing the power of AE. Your IPR is a little high for that ICP. You could have tired sticks, an inaccurate ICP, a tired HPOP, leaky injector O-rings, air in fuel, or a few other possibilities. Any time I see an ICP/IPR mismatch on a stock truck, my first inclination is to look for air in fuel. You can do this test with the tank at 1/4 tank (or lower) and again at full tank - that can hint at air in fuel.
So what should the relationship between ICP/IPR be? How can we tell if one value is out of range compared to the other value? Is it a certain percentage that it should be?
With due respect to my friend JT250, your HPOP is doomed with a tuner. A tuner is going to ask for 2800-3000 PSI, with a wider pulse width than stock, and at higher RPMS than the stock tune can get you to (with defueling). You will end up with 1500-1800 ICP and the truck will be slower, s**tier, and hotter than what you have now... but the lower part of the RPM band will rock on. Sorry.
You are already having issues with the stock tune (75% IPR is OK, but it doesn't scream "bring it on"). It could be a weak HPOP, but it could also be air in fuel, leaky O-rings, tired injectors, bad ICP or IPR, oil leak, or a couple of other things.
I have very limited net access where I'm at... so even a screen refresh may kick me. I don't know what hardware you have on your truck right now, but it looks like it may take a little effort and/or money to get your truck to 100%
So again, like example one, how do we determine the 75% IPR? My duty cycle only got up to 40% so I assume you came up with 75% from the relationship of the ICP/IPR? Also based on this taken from your link, it looks like my numbers are right inline with what they should be. Both my idle and Hard Acceleration numbers fall right within the guidelines below. I am on the lower side of ICP and the high side of IPR but still within specs.
1999-2003
IDLE WOT in neutral HARD ACCELERATION
ICP 475-490 1100-1200** 2450-2750 PSI
IPR 9-11% 18-21% 35-40%
Originally Posted by Chipworkz
I haven't had a lot of time to play with it but here is my first graph. I was planning on buying a T500 since everyone talks about the e99 HPOP being weak. I did a couple of WOT runs and and peaked out at 2515 PSI and a 37.89 % duty cycle. Those are ok numbers for a stock tune truck isn't it? I was also defueling maybe since the new RR billet wheel was pushing my boost up around 23 PSI and my needle was bouncing. I haven't had a chance to put my regulator on it. SO do I need a T500 with these numbers or am I ok until I get some tunes?
Thanks again, looking forward to the next lesson Tugly!
My original question was based on my stock tuned truck. I would for sure put a T500 on when I get a tuner but that was not the point of my question. The point was, do I currently have a problem with these numbers on a stock truck? Am I currently seeing any performance issues with those numbers.
By standing on my head at the hotel room door, and typing with my toes, I was able to get one more bar of signal. I see you have the Hutch and a prefilter. I had a prefilter, then I noticed my sticks pulled more than it could deliver. I replaced my fuel prefilter with a simple WIX disel fuel inline strainer.
I have wondered if the canister style prefilter put any extra load on the pump so how do you tell if the fuel system isn't delivering enough to the injectors? Is that were a fuel pressure gauge comes in?
The boost is fine for stock, but your ICP/IPR indicates you will have issues with tuning and your EBP is a lying liarface. Your EBP either needs cleaning or replacement, but it should match the MAP with KOEO.
As I mentioned earlier in the thread, my EBP sensor is acting up and I have a new one with tube ordered from Clay. But to your comment, are you saying that my number of 49.48 is to high or to low? With the MAP being 34.4, subtracting my ambient MAP value of 13.4 from each, my EBP is 36 and my actual boost is 21. That is the way to figure it right? We are wanting these numbers to be as close to 1 to 1 as possible correct? With a flaky EBP sensor, I am just using my numbers for an example and the relationship between the two may be actually different with my new sensor.
I screwed up and I need to go back and correct the posts I made... and apologize to my good friend JT250. My wireless wrestle over the weekend landed me getting the two charts mixed up - one with a very high IPR waveform on a 50% scale and another with a normal IPR waveform on the 100% scale.
ICP Duty Cycle is AE's expression of our IPR... they are equal. 40% Duty Cycle is 40% IPR.
My stock truck with a stock tune gave me up to 2800 PSI ICP with 40% IPR... which are the ideal readings for stock. It should have worked well with tuning, but many factors were at play at the time and I can't be sure which of my actions solved the problem (if not all of them combined). I can say for sure that a T500 made up for a lot of shortcomings with the truck/tune combination.
Every truck is a little different... almost organic after all these years and miles. There is no "these are the two correct numbers."
I'll fix this mess a little later, I'm still unpacking. In the mean time, fuel pressure gauge answers many questions. I had a pre-pump water separator... until I had a fuel pressure gauge. The filter worked fine on stock tune with stage II sticks, but the elevated tunes had the needle flagging me down.
Thanks Tugly, I thought I had an idea of what things should be but then you comments had me all confused.
You did very well. One thing I like to preach here is to listen to no one person... because we all make mistakes, and others are not there to get the whole picture. You did your homework, it conflicted with what I was saying, and you called me on it. Great job!
An EBP of 16 and a MAP of 13 at idle screams bad EBP in the mountains or bad MAP on the coast. They need to be the same with the engine not running, and idle does not make a big separation in readings.
I guess this still applies to the class so I will post it here. For my first question, is it normal for the coolant temp to be all whacked out? When I start the truck, it shows 320 then after some time drops to 3.20 then looks like it goes to a normal range in the 220 to 250 range. Is my sensor bad or is this a normal thing?
Second question is in regards to my MAP and getting the P1249 code. I am still showing that I am overboosting and kicking the code. I have installed the Overboost Annihilator so I think I need to adjust it down a bit. My MAP reading hit a max of 35.5 with a KOEO value of 13.4 So subtracting the 13.4 from the 35.5 gives me a value of 22.1 which appears to be kicking the code. My boost gauge is peaking at 23 so it looks like I just need to adjust the regulator and I should be good. Does this sound right to you guys?
UPDATE on my EBP sensor. My max value on the bad sensor hit 49.48 and was reading around 2.5 higher that my MAP value of 13.4 with KOEO.
The new sensor now shows a max value of 46.47 and .1 less than my MAP value of 13.4 with KOEO. So this shows that it was off by a fairly consistent value across the board. I will be taking a trip this weekend so we will see if it makes any difference in my fuel mileage.
I guess this still applies to the class so I will post it here. For my first question, is is normal for the coolant temp to be all whacked out? When I start the truck, it shows 320 then after some time drops to 3.20 then looks like it goes to a normal range in the 220 to 250 range. Is my sensor bad or is this a normal thing?
There is no coolant temp on the 7.3L OBDII system. AE "guesses" at it from the oil temp, but AE is for gas and diesel... so it guesses very wrong. The only coolant temp indicator you have is the one on the dash.
You're on it. Good work sussing out the boost alarm.
Please let us know what performance/shift differences you notice.
