AE class is in session!
Old Mar 24, 2013 | 06:04 PM
  #181
truck7575's Avatar
truck7575
is marginal voltage the problem on the last graph?
Old Mar 24, 2013 | 06:20 PM
  #182
Nsaan's Avatar
Nsaan
Originally Posted by Tugly
I see the confusion from the graph. More IPR is more pressure... you have it right. The oil was warming up, making it heavier... so the IPR has to rise to keep the ICP from falling on its face.
I believe you got that part backward, warmer oil is thinner, not thicker...
Now back to your regularly scheduled lecture... Which I am enjoying actually.
Old Mar 24, 2013 | 06:33 PM
  #183
CampSpringsJohn's Avatar
CampSpringsJohn
I'm a sleeper on this thread mainly because I don't have an AE, and quite frankly, I'm not very knowledgeable with anything computer related. But, I do have a question, If the IDM doesn't have the voltage to fire the injectors, will you still get a pulse width reading?
Old Mar 24, 2013 | 07:10 PM
  #184
Tugly's Avatar
Tugly
We are both correct.
Single-weight oil [LINK]: "viscosity varies inversely with temperature"
Excerpt from Blackstone [LINK]:The difference between multi-grade and straight-weight oil is simply the addition of a viscosity improving (VI) additive. The most common grade of automotive oil in use today is the 5W/30, which is a mineral oil refined with VI additives that leave it reading as an SAE 5W viscosity when cold, yet an SAE 30W when hot (210F).
Old Mar 24, 2013 | 07:17 PM
  #185
Tugly's Avatar
Tugly
The IDM takes the vehicle 12V and "generates" the 115 volts needed to fire the injectors. If the IDM has no power, I'm pretty sure the PCM will freak out and flop around like a carp on the beach when it can't B.S. with his buddy. If the power is there, but the high-power outputs are toasted, the IDM will whine and snivel to the PCM and the PCM will say "Fine. You don't have to fire the damn sticks." and report a very narrow pulse width (under minimum) on the OBDII. This just happened this week. What blew the IDM? Both UVCHs bad... power had nowhere to go but up in smoke.
Old Mar 24, 2013 | 07:28 PM
  #186
Tugly's Avatar
Tugly
Naw... low voltage wouldn't allow the pulse width to climb. Basically, the last one says it should run, but it's not running. Now we need to visit all the other engine requirements to troubleshoot this one.
  • Good fuel?
  • Fuel pressure?
  • Good air?
  • Timing (CPS)? We see the CPS working because we have an RPM signal. There's a DP in there, so I recommended yanking that long enough to get the truck running again.
  • Compression? It just had glowplugs replaced... unsure if they were tighteed down properly.
  • Glow Plug system? GPR recently replaced, GP LED works, all GPS ohmed out.
  • UVCH? All injectors ohmed out. Open circuits trigger a code and there is no code on the truck.
No resolution yet, but we have a checklist.
*EDIT* It was later discovered the cause of the no-start was the oil. His oil had gone an extended time without change (15-40) and doing a fresh change got the truck started, but with great effort and the truck needed to be plugged in. The Driver then switched to 5-40 Synthetic and he expressed amazement at how fast the engine cranks and how easy it was to start. The conlusion is his injectors are on the way out, and the synthetic oil is just loaning him some time until he can save up for new sticks.
Old Mar 24, 2013 | 10:10 PM
  #187
CampSpringsJohn
  • Good fuel?
  • Fuel pressure?
  • Good air?
If there is possible compression lost through the GP's, could you notice that with the oil cap off while cranking? White smoke should be visible through the oil filler tube with the cap off if that's the case. Possible?
Old Mar 25, 2013 | 01:49 AM
  #188
Tugly's Avatar
Tugly
That makes sense to me. I'd be surprised is if this was the root cause of the problem, one would think there would be some serious noise associated with it. I can't rule it out either. The good continuity test implies all is well there.
Old Mar 25, 2013 | 06:43 AM
  #189
tommyl's Avatar
tommyl
How would you have compression loss through the GP's?
Old Mar 25, 2013 | 06:55 AM
  #190
Tugly's Avatar
Tugly
If they're loose. I was amazed at how much compression I lost with just a loose injector that was still in place.
Old Mar 25, 2013 | 10:52 AM
  #191
caverjoe's Avatar
caverjoe
Alright to cold to work today so I finally did my homework. Now I just need to figure out how to get it transfered for a look. My graph looked a little diffrent.
Hopefully this works
https://www.ford-trucks.com/forums/i...attach/doc.gif
Well that didnt work. Can someone help me out.
Old Mar 25, 2013 | 11:12 AM
  #192
Tugly's Avatar
Tugly
No prob. Copy the file to your desktop to play with. It has a filenam like Ford-PowerStroke 7.3L-1999-March 24 2013.csv or with a ".xml" in place of the ".csv". The three letters to the right of the dot are jamming you from attaching it - that's called a filename extention. If you right-click on the file and select "Rename", you can cange that ".csv" or ".xml" to a ".doc". Once that is done, you can attach the file in a post with no problem. PM me if you find yourself saying "What dot? Where are the last three letters?"
Old Mar 25, 2013 | 04:21 PM
  #193
caverjoe's Avatar
caverjoe
"C:\Documents and Settings\Joe Hankins\My Documents\My Pictures\7.3 diesel\AE Class\AE Homework.doc"
Still trying damn it. Oh well
Old Mar 25, 2013 | 05:17 PM
  #194
Tugly's Avatar
Tugly
OK... you can download this, but you need to rename the last three letters of the file name from TXT to CSV. I boogered the data up (on purpose). I set the bottom limit of the pressure at the altitude pressure. I'll explain:
caverjoe is a few hundred feet above sea level and his absolute air pressure is about 14 PSI (remember... the International Space Station is at zero PSI absolute pressure). So... I set the minimum pressure at 14 PSI. Any rise on the graph will then become "Indicated Pressure", like having a boost gauge and a backpressure gauge.
File Type: txt
Old Mar 25, 2013 | 06:11 PM
  #195
caverjoe's Avatar
caverjoe
Yep GPS shows around 850' above sea level
