AE class is in session!
Old Mar 5, 2013 | 01:42 PM
  #76
Skip1970's Avatar
Skip1970
Wow this should help me allot
Old Mar 5, 2013 | 02:31 PM
  #77
01PS's Avatar
01PS
Originally Posted by Tugly
C'mon guys, nobody cracked open their AE and was curious if their fuel economy/performance could be easily improved? This is one of those things that's very basic, inexpensive, and important.
Will do this when I get home tonight for the sake of learning more. I have to re-read the whole thread, but did you mention how you wanted the data posted? Then you have to teach me how to post something other than a photo or screenshot!
Old Mar 5, 2013 | 03:52 PM
  #78
cjgray1974's Avatar
cjgray1974
I recorded data today tho it's with infinity not AE. don't know how to do a screen shot. I'm using logworks to view the file. If someone can tell me how to post the data I will.
Thanks for doing this thread, I'm learning a lot although I don't use AE
Old Mar 5, 2013 | 04:33 PM
  #79
Tugly's Avatar
Tugly
Enough posts to attach files? Attach the *.CSV file you recorded to your post.
Too few posts to attach? Open your *.CSV file with Notepad (all MS operating systems have this). Select all text and copy. Reply here with no text and just paste into your reply.
Old Mar 5, 2013 | 04:35 PM
  #80
Tugly's Avatar
Tugly
I don't know what format Infinity uses when it records, but I can convert a lot of formats... all I need is the file or the text.
Old Mar 5, 2013 | 04:58 PM
  #81
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Anybody know how the AE compares to DP's infinity. just got my first diesel "that's mine to play with" a couple months ago. got an infinity but wondered if I should get an AE too, or if it would be a waste of money. Thanks
No need for the AE once you have the Infinity.
Originally Posted by Rishsd
The infinity and the AE are the same thing.
Infinity pros:
No laptop needed
Always running
Easy to use
Infinity Cons:
Does not change speed for larger tires
Lie-o-meter (MPG calc) will not work
At this time you can only add one sensor. At this time the Infinity can add two additional sensors. Once the CEI-HUB is released it will be able to have 8 sensors. (DP is working on this)
AE pros:
Allows for speed change for larger tires
AE cons:
Have to have laptop
You will never be able to add sensors
Harder to use in comparison to Infinity
Originally Posted by robbragiel
I dont know any thing about the infinity but can you take the infinity out and diagnosis other Ford, Lincoln, Mercury, Chrysler, Ram, GM, Dodge, etc etc vehicles without messing up the tunes or is it vehicle specific?
You can tune a vehicle and then remove the Infinity to scan other vehicles and you will do no harm. That is one of the benefits of it.
Yes and no. You can test any ford obd2 vehicles, I would imagine that you could test Lincoln made by ford. The others you can test but you cannot get all the values. Just like AE you would have to buy the bundles from DashDAQ. I hooked it up to my 2003 honda accord and it worked but I could not get all of the sensors. I have also hooked it up to a ford explorer and I got all the values that my AE gave me.
Correct. The VIN license we offer will only enable you to get advanced/enhanced diagnostics on Ford vehicles. However, it will monitor generic values on all other vehicles.
In order to monitor enhanced data on other makes of vehicles, you would have to purchase that brands enhanced license.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Mar 5, 2013 | 09:46 PM
  #82
truck7575's Avatar
truck7575
Can I use my AE to recalibrate my speedo and odo for my 2003 7.3 that i have 35" tires on?
Old Mar 5, 2013 | 10:22 PM
  #83
Rishsd's Avatar
Rishsd
Yes you can.
Old Mar 5, 2013 | 10:34 PM
  #84
Reckless's Avatar
Reckless
So I can use the AE to read other OBDII vehicles? Do i use the donlge for all makes?
Old Mar 6, 2013 | 01:25 AM
  #85
cjgray1974's Avatar
cjgray1974
I have it in DIF format. I can't post attachments. I can send you the file by e-mail if you want. PM me. or I can try and post with notepad altho its kinda long. It recorded a lot more than the three you specified.
Old Mar 6, 2013 | 07:03 AM
  #86
Tugly's Avatar
Tugly
PM sent to you.
Old Mar 6, 2013 | 08:36 AM
  #87
01PS's Avatar
01PS
So I didn't get to this last night but will for sure tonight. A quick question though.... does it matter what tune I'm in? I'm glad I read your note about not powering the laptop from the cig lighter. I've been having the dreaded "plugged in, not charging" issues with my laptop lately so I'll have to figure something out.
Old Mar 6, 2013 | 08:44 AM
  #88
trekbasso's Avatar
trekbasso
Sooo late but scribing anyway.
Old Mar 6, 2013 | 08:48 AM
  #89
tappit01's Avatar
tappit01
somebody correct me if i'm wrong but, i think you can safely use a power inverter "12v to 115" from the truck to power your laptop with a regular plug.
Old Mar 6, 2013 | 08:54 AM
  #90
Pitcrw6's Avatar
Pitcrw6
You can but I read on here that it can cause interference with the program. I dont know how true it is, maybe someone will chime in and confirm if it does or not.
