AE class is in session!
Old Mar 6, 2013 | 09:34 AM
  #91
tappit01's Avatar
tappit01
Originally Posted by robbragiel
You can but I read on here that it can cause interference with the program. I dont know how true it is, maybe someone will chime in and confirm if it does or not.
i heard it only causes interference when its straight from the 12v to the puter, but putting the invertor inbetween eleminates that. thats what i've been told anyway.
Old Mar 6, 2013 | 10:06 AM
  #92
Pitcrw6's Avatar
Pitcrw6
Gotcha and that makes sense. Well time for me to buy an inverter.
Old Mar 6, 2013 | 10:14 AM
  #93
cjgray1974's Avatar
cjgray1974
Originally Posted by Tugly
PM sent to you.
Email sent
Old Mar 6, 2013 | 10:19 AM
  #94
truck7575's Avatar
truck7575
Is this the procedure for changing the tire size mentioned earlier
KOEO
Connect to ODB port
Start AE
enter year and engine
it pulls all the codes
select "Change System"
select "Anti-lock Brake System"
it reads codes, view codes
select "Tire Size Calibration"
select "Initate"
Use ">" to get to tire size
Click "Done"
Does KOEO mean key on engine on or key on engine off or what?
Old Mar 6, 2013 | 10:28 AM
  #95
eyyu's Avatar
eyyu
KOEO
Connect to ODB port
Start AE
select "Initate"
Click "Done"
Key on engine off. KOER mean key on engine running
Old Mar 6, 2013 | 11:59 AM
  #96
MauleOne's Avatar
MauleOne
AE Class
Be home in a few days for my 4 week break and will try my AE
Will post results.
Old Mar 6, 2013 | 12:29 PM
  #97
Edogsf350's Avatar
Edogsf350
power inverter !!!!
if you read AE's web site the strongly recommend against using a 12 volt power inverter to power a lap top while plugged in to the OBD port.
it creates a ground loop and can cause bad thing to happen !!!!!!
they have posted pics of what has happend....
my opinion is have a extension cord handy for both the lap top and a battery charger for the vehicle.
Old Mar 6, 2013 | 01:26 PM
  #98
Pitcrw6's Avatar
Pitcrw6
Well I guess I wont buy one then. I haven't been on there website but im glad you posted that.
Old Mar 6, 2013 | 02:01 PM
  #99
tappit01's Avatar
tappit01
dang, you cant believe anything ya hear anymore. guess i wont be doing it ether.
Old Mar 6, 2013 | 02:19 PM
  #100
tappit01's Avatar
tappit01
i just called a/e , they said do not take any power from the vehical in any way to supply your laptop. good catch edog
Old Mar 6, 2013 | 02:27 PM
  #101
Pitcrw6's Avatar
Pitcrw6
Yes, great catch.
Old Mar 6, 2013 | 02:33 PM
  #102
Tugly's Avatar
Tugly
I've been powering up from the cigarette lighter for over a year now... but I have a netbook that uses low power and an inexpensive inverter to keep it going indefinitely. That being said, look at the big red letters on the first post in this thread, and a few posts later.
AE is powerful for troubleshooting/maintenance, but it makes a lousy gauge set while on the road. Your call, but you'll crave these capabilities if you ever get a no-start or if fuel economy goes to hell.
Old Mar 6, 2013 | 03:06 PM
  #103
truck7575's Avatar
truck7575
So if i use my AE to change my tire size with this change affect a DP F6 installed chip
Old Mar 6, 2013 | 03:31 PM
  #104
Edogsf350's Avatar
Edogsf350
Not trying to be a bummer....but better to be safe than sorry....
I have done data logging while driving and will do it again as I have home work to do for this class. I just make sure my lap top battery is fully charged.
I wonder what AE has to say about a DC plug in made for the computer?
Old Mar 6, 2013 | 05:37 PM
  #105
Tugly's Avatar
Tugly
I wouldn't want the computer and the interface to share a ground - that sounds like trouble. My inverter "floats", meaning no ground. I was careful when I set my system up, but few know how to do this properly and AE will just say "Don't do it."
