2011 fuel system issues
Old Jan 23, 2012 | 05:20 PM
  #136
kper05's Avatar
kper05
You make it sound like vloney designed this pump...
Old Jan 23, 2012 | 05:24 PM
  #137
ljutic ss's Avatar
ljutic ss
Originally Posted by NinerBikes
Let's rephrase that correctly... it's Bosch's pump... you (Ford) subcontracted to them for a Diesel fuel injection system for your 6.7 motor... It has never been VW's, GMC's, or Ford's or Audi's High Pressure Fuel Pump.
NHTSA smells something bigger than just Ford, hence the Peer Review analysis. Everybody that makes diesel is getting the same treatment. Almost all mfg's listed there run on Bosch pump models, in one form, family model, or another. NHTSA is going to see which Family of pumps have the highest failure ratio. This is only the beginning of the discovery process, IMHO.
If there just investigating just vehicles with Bosch pumps, why would they want records on a Ford 2007 MY when there fuel pump is 65 PSI? or the 2008 Ford MY that uses a Seimens built HPFP?
Old Jan 23, 2012 | 05:32 PM
  #138
NinerBikes's Avatar
NinerBikes
Statistical reasons? Baseline values? Failure rates of other brands? Probably has something to do with all of the above, or to eliminate the claim that it's fuel issues, or the other pumps have adequate design. Or it could be something as simple as the others at least giving the operator an indication that it is about to fail, for safety purposes.
Old Jan 23, 2012 | 05:33 PM
  #139
senix's Avatar
senix
Common cause accross the board is water and lack of lubrication, regardless of manufactor.
Old Jan 23, 2012 | 05:43 PM
  #140
NinerBikes's Avatar
NinerBikes
s
While that could be true, the mode of failure, and how dangerous it could be, is different. Metal debris in contaminated fuel could jam an injector nozzle open at all times, which is a real problem when you have a common rail loaded with a bunch of fuel at high pressure, spraying into a chamber at all times, constantly, during the various strok cycles on a four stroke motor. Now you are talking about leak down, and burning a hole in a piston, massive failure of the whole block, etc.
Old Jan 23, 2012 | 05:55 PM
  #141
huntindog's Avatar
huntindog
Originally Posted by srkr
I believe there is a documentation stating a aux tank is not recommended by ford,. Because of possible fuel contamination. WHY risk it..on a newly designed engine? if there is a possibility of contaminated fuel...why would ford cover it??
Just like chips....be smart people...stay stock!!
Also, if you think about it,....if bad lubricity is the cause...why should Ford cover that?
Some people don't get it....you get bad fuel....someone has to pay...just not Ford!!
Shane
I think I remember reading that Ford has programing to allow the fuel gauge to read accuratly with aftermarket/aux, tanks.
If that is correct, then it would seem that Ford has given tacit approval of these tanks
Old Jan 23, 2012 | 06:00 PM
  #142
srkr's Avatar
srkr
To each their own....." I'm going by the book"
I'm not going to give Ford a reason for any DENIAL.
live how you wanna live.
Shane
Old Jan 23, 2012 | 06:21 PM
  #143
rickatic's Avatar
rickatic
...and you would be correct. In fact, the sizes allowed in the current IDS programming are exactly the sizes of the various Titan Tanks available for the 2011/2012 Ford F Series pickups. Carte Blanche tank sizes are not available in the Ford programming.
This effort was spring boarded by members on this site and pushed through the programmers at FOMOCO by Paul Bruckner. He was a design engineer for the 6.7 diesel engine. He was a contributor here until he was promoted to a position in the Lincoln Division of FOMOCO. He also forwarded his opinion that my HPFP failure should be covered under warranty to the upper levels of FOMOCO management.
Fear of loss of warranty coverage should not be something anyone should have to worry about when they spend $50,000 plus on a new truck. Ford's shameful behavior has certainly changed that dynamic...way to go Ford...
Shame on Ford
Peace
Old Jan 23, 2012 | 06:49 PM
  #144
jim48's Avatar
jim48
I would have ordered my chassis cab with the dual tank setup, but not available on Lariat. No one knows why but evidently Ford has no problem building an XLT with dual tanks. So is the second tank an auxillary, optional main or some other name.
Jim
Old Jan 23, 2012 | 06:50 PM
  #145
cirrus365's Avatar
cirrus365
Where is that dead horse smilie?
Old Jan 23, 2012 | 06:57 PM
  #146
srkr's Avatar
srkr
Shame on Ford
Peace
Keep on trucking.....
SHane
Old Jan 23, 2012 | 07:31 PM
  #147
lexustbs's Avatar
lexustbs
Is it possible that fuel is mixing with coolant at the fuel cooler? Or would that be a huge mix of fluids with a for sure disaster?
Old Jan 23, 2012 | 08:06 PM
  #148
Hdslider's Avatar
Hdslider
Just one way to try and cover my butt.
Old Jan 23, 2012 | 09:09 PM
  #149
B HOOFED's Avatar
B HOOFED
Originally Posted by Dim Sum
I find it interesting that there are soo many VW tdi systems that have failures. They are much less likely to use fuel from farm supplies or contractor supplies. I do know that their filter replacement intervals are longer than ours and their filter system is not as easily accessible to the owner. Even when we combine 6.4 and 6.7 failures, our list is far smaller with far more Superduties sold.
My dad has an 09 TDI....
One difference between the VW TDI and the power stroke is that the TDI fuel filter housing has no drain. The fuel filter housing is basically a paint can. Any water that gets in there stays in the can until the fuel filter is changed at 20,000 miles. There's also no warning light for water in fuel. Its possible if enough water accumulated in the housing it would eventually seep through the filter and get into the pump.
I found an article in Popular Mechanics where they did a 12-month test drive on a Jetta TDI. They got some "bad fuel" on a road trip and had to have the entire fuel system replaced, under warranty of course. The writer dismissed it as if it were an everyday occurrence, to be expected with a diesel.
Year-Long Review of the VW Jetta TDI Loyal Edition - Popular Mechanics
Old Jan 23, 2012 | 09:22 PM
  #150
Tom's Avatar
Tom
(sigh)
I feel like I've been wearing out my keyboard typing this out over the past few months: This isn't about Volkswagens, nor is it a VW forum.
