NO Start
Old Sep 27, 2011 | 09:30 PM
  #166
maverick1701's Avatar
maverick1701
Originally Posted by DanS12
Well, I measured the volts after taking the pigtail loose from the IPR and the hot wire was 12 plus and the return wire was 1.3volts. I seem to remember it being 0.35 with KOEO. Is there any significance to this?
I appreciate everyones help.
dang! I just read all 12 pages of this thread and I feel for ya...what a saga.
But dont give up and sell your truck.
I did and I regret it everyday...best truck I ever owned.
Im trying to get back in an OBS.
Old Sep 28, 2011 | 07:51 AM
  #167
DanS12's Avatar
DanS12
I'm an idiot! When I asked earlier about which pin the red(12 volt) wire went to in the IPR, I found a diagram and I posted it was the left pin. I hooked it up that way, and last night I looked at the diagram again, and I was wrong. Today, I'll change it and see what happens.
Old Sep 28, 2011 | 08:06 AM
  #168
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Im crossing my fingers. good luck.
Old Sep 28, 2011 | 05:20 PM
  #169
DanS12's Avatar
DanS12
Switched the wires around and still won't start. I think I am done, till I can get a code reader. Not worth it anymore.
Old Sep 28, 2011 | 05:40 PM
  #170
rk29801's Avatar
rk29801
What is ICP, IDM, IPR & FPR
Old Sep 28, 2011 | 06:09 PM
  #171
DanS12's Avatar
DanS12
Why is my signal voltage going to the IPR 1.3. The red wire has 12 volts. Would this be the cause of my truck not starting now?
I ohmed the connector and the ohms with key off are greater than 5 on both pins to ground. So, why would I have 1.3 volts? Ever since I started getting the 1.3 volts my truck won't even think about firing.
Old Sep 28, 2011 | 06:53 PM
  #172
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Welcome aboard
This is for you
https://www.ford-trucks.com/forums/1...finitions.html
Old Sep 28, 2011 | 07:09 PM
  #173
DanS12's Avatar
DanS12
Okay, I thought both pins should have a resistance of >5 ohms, so Initially I had my meter set really low. When I check the signal wire, it has a reading of 800 ohms, so I guess that is a problem.
Old Sep 28, 2011 | 07:12 PM
  #174
427 fordman's Avatar
427 fordman
I'm electrically challenged for the most part or I'd have jumped back in here to help..
Old Sep 28, 2011 | 08:12 PM
  #175
DanS12's Avatar
DanS12
HELP! Somone!
Old Sep 28, 2011 | 08:45 PM
  #176
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
Me too, sorry, this is only a bump for you.
Old Sep 28, 2011 | 10:50 PM
  #177
oldbird1965's Avatar
oldbird1965
Me three, sorry.
Old Sep 29, 2011 | 09:31 AM
  #178
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I suggest you to make a summary of the issues you have had and what have you done, because to read 178+ posts its complicated, or send a PM to Jim (Hussler), because I think he is an expertise in electronics. JMHO.
Old Sep 29, 2011 | 09:40 AM
  #179
rk29801's Avatar
rk29801
How do you test the pressure from the HPOP?
Old Sep 29, 2011 | 10:52 AM
  #180
Hussler's Avatar
Hussler
IPR connector unplugged - Key Off
Red wire > 1000 ohms - use battery negative for meter ground
Yellow wire > 1000 ohms - use battery negative for meter ground
IPR connector unplugged - Key ON
Red wire Battery (12 volts) - use battery negative for meter ground
Yellow wire 0 - .25 volts - use battery negative for meter ground
IPR connector plugged in - Key OFF
(Measuring across Red - Yellow wires) 5-20 ohms
Report back on your readings.
I'll read the entire thread in a bit .. got some meetings I have to attend.
