NO Start
Old Sep 24, 2011 | 01:03 PM
  #151
DanS12's Avatar
DanS12
I found a diagram, it was the left pin.
Ever since I put on the new IPR, now my HPOP resevoir drains down a few inches overnight. I wonder if the new IPR is defective, or is it normal for it to drain down some?
Old Sep 24, 2011 | 02:00 PM
  #152
427 fordman's Avatar
427 fordman
It should not drain down. It never did before the ipr change? That was the only change you did and the resevoir is now draining down? How far? I may not be able to answer why for sure but get a few more questions answered for others to help out hopefully.
Old Sep 24, 2011 | 07:47 PM
  #153
DanS12's Avatar
DanS12
The only thing I have changed recently was the IPR, and then I noticed the resevoir draining down. One night it was down 6 inches. Last night only about 2 inches.
Today I took it out for a spin and after about 5 mins of driving I was going about 40 mph and all of a sudden CEL light comes on, truck barely runs, after 10 seconds CEL goes off and truck runs fine.
The saga continues.
Old Sep 24, 2011 | 08:06 PM
  #154
427 fordman
I don't remember, have you gotten the codes read?
Old Sep 24, 2011 | 08:19 PM
  #155
mq1shooter's Avatar
mq1shooter
If the truck starts.pop the hood and grab onto the PCM harness and wiggle the bundle and see if you can kill or make it hiccup.....seriously...
Old Sep 24, 2011 | 11:08 PM
  #156
DanS12's Avatar
DanS12
Wiggle the harness at the connector, or all over?
I haven't been able to read any codes yet. A friend of mine said he would come over this weekend, but haven't heard from him yet. I have tried three different scanners.
I'll check HPOP resevoir again tomorrow and see if it drained down.
Old Sep 25, 2011 | 08:18 AM
  #157
mq1shooter's Avatar
mq1shooter
This post...
Originally Posted by DanS12
Okay, the last time the engine started I had disconnected the computer harness and loosened the other big harness next to it. So I did that again today, moved the wires around, and tried starting truck.
It started! I let it run for 10 mins and it restarted. It takes it several seconds to start, but I guess we'll see what happens.
This is a very uneasy feeling! I need to go diesel, but I don't know what the hell I did to make it run.
I did measure ICP volts through blue wire while it was running and it was 0.95 volts at idle.
the beginning of this post...this seems odd, Loose / intermittent wire? Connector to PCM pin(s)...?
Also, you might check here and other Diesel websites for members that #1) Have a AE scanner and #2) may be geographically close to you...
...My "no Start" thread from last year.. https://www.ford-trucks.com/forums/9...ml#post9401888
Old Sep 25, 2011 | 11:26 AM
  #158
DanS12's Avatar
DanS12
Going backwards!
HPOP resevoir down this morning 6 inches, so I crank truck until it is full, but no start.
Today I notice the Tach is not moving while I crank.
I put a new CPS on about a month ago from Oreilly auto parts.
Old Sep 25, 2011 | 12:13 PM
  #159
427 fordman
You need to get a ford or ih cps in there, those parts store ones aren't reliable at all.
Have you recently changed the oil and possibly lost the bypass in the filter housing?
Old Sep 25, 2011 | 12:31 PM
  #160
DanS12's Avatar
DanS12
No, haven't changed the oil in awhile. I did check the oil this morning though and it is about 2 quarts low. I thought I lost quite a bit when I forgot to put the HPOP res plug back in. It has started before when 2 quarts low. I doubt that would have anything to do with the tach not moving now though.
I don't remember seeing anything in the bottom of my oil filter the last time I changed it.
Old Sep 25, 2011 | 12:36 PM
  #161
DanS12's Avatar
DanS12
I just tried to start it again, after wiggling around the harness where the wires from the CPS go into it. Now my tach is reading rpm's again. Still won't start though. I have oil pressure on the gauge too. Guess I need to go get a couple quarts of oil, and make sure that isn't the problem right now.
Old Sep 25, 2011 | 06:44 PM
  #162
oldbird1965's Avatar
oldbird1965
Two quarts low is not going to make a difference. TJ said he has seen some trucks brought into his shop six quarts low.
Old Sep 26, 2011 | 12:37 PM
  #163
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
The saga continues.
There are a spring and check ball in the front of the block that control the flow to the hpop reservoir, maybe its bad or failing.
Old Sep 27, 2011 | 04:56 PM
  #164
DanS12's Avatar
DanS12
Well, thought I had found the problem. Truck would not start so I checked voltage at IPR 5 prong connector and there wasn't any, so I wiggled the wires and got voltage. I thought it was the connector. I got the truck running and I shook the connector and the truck died. Okay, I checked the voltage and the 12 volt signal was steady, but the 0.3 volt signal was all over the place, so I got rid of the connector and just soldered the wires together. Then the volts were nice and steady on the 12volt side and the 0.3 volt side. I take it for a spin, come back and it kept dying. WTF!
I go back and check the voltage again and now both wires are 12 volts plus. I wonder if this is a PCM problem or do I need to go back further into the harness. I guess I need to figure out where that voltage originates and check it there first before tearing up more harness. Does it come from the IDM or the PCM?
Old Sep 27, 2011 | 07:08 PM
  #165
DanS12's Avatar
DanS12
Well, I measured the volts after taking the pigtail loose from the IPR and the hot wire was 12 plus and the return wire was 1.3volts. I seem to remember it being 0.35 with KOEO. Is there any significance to this?
I appreciate everyones help.
