NO Start
Old Sep 9, 2011 | 09:42 PM
  #91
DanS12's Avatar
DanS12
Yeah made a new one after having a hard time getting the old one out. The old one was ruined but I didn't hurt the IPR valve. I pressed in a new one I made from aluminum. I had read you can stick a screwdriver down the end of it and see if whatever is in there moves up and down freely, which it did.
Old Sep 9, 2011 | 10:12 PM
  #92
DanS12's Avatar
DanS12
Maybe I should take the other valve cover off and check the harnesses. I did ohm the injectors and glow plugs through the pigtail receptacle and the injectors all ohmed good. As I recall I had one bad glowplug on that side. I just doubt if it is that though.
Old Sep 9, 2011 | 10:37 PM
  #93
DanS12's Avatar
DanS12
I have checked the pressure off the schrader valve 2 or 3 times while cranking the engine and it is always around 50 lbs. Is it possible my engine might not be getting fuel? Again, no smoke.
Old Sep 9, 2011 | 10:53 PM
  #94
fordpride's Avatar
fordpride
Your Fuel pressure is after it has come out of the heads to the FPR
You will not get any smoke till the injectors are firing. The PCM needs to see about 500psi Of HPO before it will tell the IDM to fire the injectors
Old Sep 9, 2011 | 11:05 PM
  #95
DanS12's Avatar
DanS12
I must have a loose wire somewhere or a bad connection. Why would it start yesterday and at one point ran for about 30 seconds and now I can't even start it. Obviously, it is getting fuel and the injectors are working. Aaargh!
Old Sep 10, 2011 | 05:41 AM
  #96
bad12jr's Avatar
bad12jr
The ipr pigtail is probably loose. They tend to have problems for some reason. Ill try and get a pic is I still have the one I cut out.
Old Sep 10, 2011 | 10:30 AM
  #97
DanS12's Avatar
DanS12
I just don't understand how it could be loose, because everytime I check it I get 12 volts.
Old Sep 10, 2011 | 01:50 PM
  #98
DanS12's Avatar
DanS12
Okay, the last time the engine started I had disconnected the computer harness and loosened the other big harness next to it. So I did that again today, moved the wires around, and tried starting truck.
It started! I let it run for 10 mins and it restarted. It takes it several seconds to start, but I guess we'll see what happens.
This is a very uneasy feeling! I need to go diesel, but I don't know what the hell I did to make it run.
I did measure ICP volts through blue wire while it was running and it was 0.95 volts at idle.
Old Sep 10, 2011 | 01:58 PM
  #99
forrider's Avatar
forrider
you might have a short in the harnesses somewhere thats prob why when u moved the wires it ended up starting
Old Sep 10, 2011 | 02:00 PM
  #100
forrider's Avatar
forrider
oh yeah and its prob taking 7 seconds to start because there is still air in the fuel system or oil system driving it for awhile will solve that but be careful you never know when the truck might start acting up on ya again!
Old Sep 10, 2011 | 06:27 PM
  #101
DanS12's Avatar
DanS12
Well it continues to start, so I drove it a couple of miles around the neighborhood, and it definietely isn't running very smooth. I am hoping it still has air in the system, plus I only have about a quarter tank fuel and it has been in there for a few months.
Old Sep 10, 2011 | 08:39 PM
  #102
oldbird1965's Avatar
oldbird1965
It takes a long time to bleed them out. Diesel fuel doesn't go bad very fast at all.
Old Sep 10, 2011 | 10:46 PM
  #103
DanS12's Avatar
DanS12
Bummed! Let the truck sit for 4 hours, went to try and start it, and nothing. Crank, crank, crank! No smoke again, nothing. Since it was running bad, could the air in the system still be making it hard to start, or I wonder if my IPR is getting stuck when I shut it off.
Old Sep 11, 2011 | 11:59 AM
  #104
DanS12's Avatar
DanS12
Started right up this morning after sitting all night! Might have to search cold start versus hot start symptoms.
Old Sep 11, 2011 | 04:38 PM
  #105
DanS12's Avatar
DanS12
After all the work I've done on the truck or the last month, I start it up this morning, am sitting inside trying to figure out what the problem might have been when all of a sudden my "check engine" light comes on, the truck runs like crap, and dies. I immediately start it up again, and the check engine light is gone. The same problem I had when this whole marathon started. I plugged in another scanner to get a code, and it says, "No code"! I am going to buy a new IPR and see if that fixes it.
