NO Start
Old Sep 20, 2011 | 12:42 AM
  #136
bad12jr's Avatar
bad12jr
I would try to find someone with an AE close or bite the bullet and get it to a ford scanner
Old Sep 21, 2011 | 07:15 PM
  #137
DanS12's Avatar
DanS12
I replaced the IPR pigtail, and still having problems, so today I pulled the other valve cover(what a bear) and I am replacing another glowplug.
I think I am going to replace the whole IPR harness, the IPR wires are really soft, but they do have continuity. When I took off the harness I unplugged two connectors from the fuel bowl and fPR, but there was another loose one, with a farily big connector and only one big pin. what is it for?
Old Sep 21, 2011 | 08:33 PM
  #138
427 fordman's Avatar
427 fordman
Does that help you out?
Old Sep 21, 2011 | 09:29 PM
  #139
DanS12's Avatar
DanS12
Yeah, that helps, but there is one more single plug. I know the water in fuel sensor and the heater are part of this harness, plus the 2 wires for the IPR. What is the other wire for?
Old Sep 22, 2011 | 06:00 AM
  #140
427 fordman
Is it the fuel filter restriction sensor wire?
Old Sep 22, 2011 | 08:15 AM
  #141
DanS12's Avatar
DanS12
Would that throw off a CEL and make the truck run bad when the CEL is on, if the wire was loose or bad or the sensor bad?
Can I just get rid of it along with the Heater?
Old Sep 22, 2011 | 08:27 AM
  #142
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I agree with Darin, and till I know no CEL. Surely PO put a plug in the place of the fuel restriction sensor and left loose the wire as I did. and no more leaks there.
Old Sep 22, 2011 | 12:25 PM
  #143
DanS12's Avatar
DanS12
Looks like PO did remove the fuel filter restrictor sensor. I don't see a plug in the hole, but obviously something is in there. I'll have to take a better look.
Old Sep 22, 2011 | 01:38 PM
  #144
DanS12's Avatar
DanS12
Since the fuel restrictor sensor is gone, and you don't really need the fuel heater, can I also get rid of the water detector. That way, I can make a two pin harness just for the IPR.
Old Sep 22, 2011 | 02:43 PM
  #145
427 fordman
Ya, you can get rid of it, just remember to drain the water from the fuel bowl, that's all it does is warn you to do that.
Old Sep 22, 2011 | 03:02 PM
  #146
DanS12's Avatar
DanS12
Thanks, that will save me from buying a new $100 harness for all that stuff.
Old Sep 22, 2011 | 07:13 PM
  #147
DanS12's Avatar
DanS12
I was messing with my IPR harness and now don't know which pin of the IPR should be 12 volts. I can't find the information anywhere. Sometimes I am a dunce.
Old Sep 23, 2011 | 03:37 PM
  #148
DanS12's Avatar
DanS12
Okay, so if you are looking directly into the IPR receptable where the pigtail goes which pin does the red wire (12 volt) hook to?
Old Sep 23, 2011 | 07:19 PM
  #149
DanS12's Avatar
DanS12
All I have to do is hook up my IPR and I can fire up the truck, but I don't want it hooked up backwards. I know someone can tell me what pin the red wire goes to in the IPR receptacle.
Old Sep 23, 2011 | 08:27 PM
  #150
427 fordman
I'm not close to my truck or I'd look for ya. Bump you up top if nothing else..
