NO Start
Old Nov 2, 2011 | 06:22 PM
  #271
DanS12's Avatar
DanS12
Okay, maybe someone knows the answer to this. My signal wire (red/yellow) at the IPR connector is always above 0.25 volts, normally around 0.36.
Out of the 42 pin connector it measures 0.36 also.
But I stabbed the wire with a pin today where it comes out of PCM and it is over 12 volts. I think I am goofy.
Old Nov 3, 2011 | 09:23 AM
  #272
DanS12's Avatar
DanS12
PCM grounding problem? I checked continuity on all the PCM grounds.
Old Nov 3, 2011 | 10:28 AM
  #273
Hussler's Avatar
Hussler
1. Signal wire is yellow/red .. guess it was a typo?
2. You poked the wrong wire?
Old Nov 4, 2011 | 10:35 AM
  #274
DanS12's Avatar
DanS12
I poked them both Jim. Both were over 12 volts. I was kind of shocked.
Old Nov 4, 2011 | 10:41 AM
  #275
DanS12's Avatar
DanS12
I actually read somewhere that the volts at the coil with KOEO should be 1.3 or so. For a time that is what I was getting. But it wouldn't start. Once I got the volts down to around 0.36 the truck would start. Maybe something else going on.
My codes sure point to the IPR/ICP interaction.
Old Nov 4, 2011 | 12:59 PM
  #276
DIYMechanic's Avatar
DIYMechanic
Just to confirm, you're attaching one lead of your meter to that wire and the other wire to the NEGATIVE battery terminal or a good ground?
Old Nov 4, 2011 | 01:20 PM
  #277
DanS12's Avatar
DanS12
Yes, I attach one lead to the neg battery post and then measure volts with other lead.
For instance at the IPR connector the signal wire is now measuring around 0.36 volts and coming out of the 42 pin it measures the same.
But the voltage coming out of the PCM was measuring over 12 volts when I pricked it with a pin and measured the volts.
This is driving me insane.
Old Nov 4, 2011 | 02:02 PM
  #278
DIYMechanic
Sounds to me like there must be an issue between the 42 pin connector and the PCM if you're absolutely sure it is the same wire. If you have verified that the color code is the same, I would either open the wiring harness and inspect the wire from PCM to the 42 pin connector, or just install a new wire and test it again. Just as a test you could use some of those insulation cutting splice connectors (solderless splices) to see whether it works. I would only do this: 1 as a very temporary test as those connectors don't seem to hold up very well in an environment like the engine compartment (or any environment for that matter) and 2 after you have double, triple checked that it is the same wire. If you cross that IPR wire with another 12V supply, you run the risk of damaging either the PCM or the IPR. For a long-term solution you're really best off to run a new wire and solder it in place then seal things up with some heat shrink tubing.
Old Nov 4, 2011 | 02:20 PM
  #279
DanS12's Avatar
DanS12
I'll check it again today and if it is still 12 volts, I'll splice into the wire. The last time I had the harness apart, I put another wire in there, just in case.
Old Nov 4, 2011 | 04:16 PM
  #280
Hussler's Avatar
Hussler
If you had the PCM connector unplugged when testing then it would be 12 volts (battery). PCM is what pulls the line low. Otherwise it's just a wire so if your sure it's the same wire at both ends (do a resistance check) and you get different readings at each end then .... must be the wire.
Old Nov 4, 2011 | 05:03 PM
  #281
DanS12's Avatar
DanS12
I was pricking the wire with a pin and measuring the voltage with the PCM connector connected.
I measured the voltage today(PCM connector connected) and it was the same(0.36) before and after the 42 pin connector. That is with the IPR connector disconnected.
I am thinking that maybe the other day when I measured it and the voltage was 12 plus, I didn't have the IPR connector disconnected and the 12 volt hot leg was cycling through the IPR itself and going back to the PCM. I will have a new ICP in the truck tomorrow and see if that helps.
I have a question about the PCM. Can you get the chip out without removing the PCM? Is the chip what you see looking straight at the PCM? I wiggled it and it moves around, is that okay?
Old Nov 4, 2011 | 08:11 PM
  #282
Hussler's Avatar
Hussler
Dan, after 19 pages of conversation how did I miss the PCM was chipped ...
I would not get to caught up on the volt meter thing reading 0.36 ( or whatever it was) instead of lower, it's probably just the meter. Try another one and compare the results.
Old Nov 4, 2011 | 10:18 PM
  #283
DanS12's Avatar
DanS12
I don't know if the PCM is chipped or not. I don't think it is, I have had it since 96 and I don't think the PO did anything to it. I was just trying to figure out how to get it out of the truck. I thought all PCM's had some kind of a chip in them. Man, I know very little about lots of this stuff.
Old Nov 5, 2011 | 06:13 AM
  #284
427 fordman's Avatar
427 fordman
If you pull the 3 nuts holding the emergency brake off you can see if there is a chip and pull it off if there is. Pull the keys if you do mess with a chip.
Old Nov 5, 2011 | 09:04 AM
  #285
DIYMechanic
I think what you're looking at is the rubber plug that goes in the PCM to cover the edge connector where you would plug a chip in if you had one.
