1978 - 1996 Big Bronco
Operation: Zebra build
Old Aug 30, 2012 | 06:24 PM
  #811
GruesomeJeans's Avatar
GruesomeJeans
Yeah i have heard form a lot of others that FSB has "ruder"(probably not a word) members. thats why i stick with FTE, just about everyone here is friendly and willing to answer even the really nooby questions.
thanks TGM is my pride and joy.. And my daily driver/project.. Slow and steady.
Old Aug 31, 2012 | 06:03 AM
  #812
mpc07005's Avatar
mpc07005
If you do run seafoam/blow some smoke at it remember to remove/disconnect your fan. Just watch your temps!
-Mike
Old Aug 31, 2012 | 06:00 PM
  #813
GruesomeJeans
-Mike
I could see a fan being an issue haha
Old Aug 31, 2012 | 09:34 PM
  #814
Jigger2020's Avatar
Jigger2020
I wondered if that Seafoam was any good??
Old Aug 31, 2012 | 09:57 PM
  #815
GruesomeJeans
I hope so... I wonder if i could run seafoam through my carb.. Idk
Old Aug 31, 2012 | 10:03 PM
  #816
1_ton_bronco's Avatar
1_ton_bronco
You can... you gotta run it thru your carb while its running.. you cant stall it either
Old Aug 31, 2012 | 10:24 PM
  #817
Edgethis's Avatar
Edgethis
Haven't tried the seafoam in the Bronci yet. Been working on the coupe.
You can run seafoam through the brake boosters vacuum line. Ive done it a few times on the coupe eventually with no issies. Just have to hold it just right so it only gets a bit at once. The cars vacuum practically does it for you.
Old Aug 31, 2012 | 10:49 PM
  #818
GruesomeJeans
Yeah we used the brake booster vac on my 88 ranger. I figured pouring it into the carb would be easier to control the amount and the throttle.
Old Sep 1, 2012 | 08:20 AM
  #819
Jigger2020's Avatar
Jigger2020
Thats a great Idea, thank you Dylan
Old Sep 1, 2012 | 09:20 AM
  #820
1_ton_bronco
Yup it basically does it for you if you have a booster for power brakes..
Idk if that 78 tgm has it?
Old Sep 1, 2012 | 01:18 PM
  #821
GruesomeJeans
no problem Gigger and yes TGM happens to have power brakes and I can use the booster line. I bet it would certainly help clean up a little of the gunk in there.
Old Sep 1, 2012 | 02:01 PM
  #822
1_ton_bronco
Oh ok.. so you wouldn't have to put it straight in the carb..
Old Sep 1, 2012 | 02:25 PM
  #823
Edgethis's Avatar
Edgethis
But it wouldnt actually help clean the carb out at all. Seafoam makes a special spray can for carbs I believe.
Here's what I've been working on (new valve covers), I think it looks pretty sweet.. I know its not the Bronco, but you guys can imagine it is.
http://www.flickr.com/photos/62639173@N03/7908231856/http://www.flickr.com/photos/62639173@N03/7908231856/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Old Sep 1, 2012 | 02:39 PM
  #824
1_ton_bronco
Damn I wanted to put a 408 in my bronco..
I know thts your 68.. lol
Old Sep 1, 2012 | 02:43 PM
  #825
Jigger2020's Avatar
Jigger2020
Lookin good there Brett , nice touch...........
