1978 - 1996 Big Bronco
Operation: Zebra build
Old Jul 1, 2012 | 09:27 PM
  #721
Edgethis's Avatar
Edgethis
That'd be awesome but idk if I can stuff heads and the intake into their boxes. Ill have to check their sizes.
Old Jul 1, 2012 | 10:09 PM
  #722
SideWinder4.9l's Avatar
SideWinder4.9l
They have pricing....It has a weight limit though...
Old Jul 1, 2012 | 11:43 PM
  #723
GruesomeJeans's Avatar
GruesomeJeans
Looks like he won't need them, he has the E6SE heads and after his Cam upgrade he said it's pushing 200HP. Whatever, his choice. He also decided to pick up an old Ford PS pump with the serpentine pully instead of a sag... Oh well
Old Jul 2, 2012 | 06:08 AM
  #724
Edgethis's Avatar
Edgethis
E6 heads.....lol and 200 hp. The explorer 5.0 was under-rated by Ford to promote the 4.6. They actually been shown to put out up to 275 HP without a cam!!
But thanks for asking him, Dylan!
Old Jul 2, 2012 | 06:25 PM
  #725
GruesomeJeans
He said if you were to put them on the ranger station site they would sell quick. I'm sure they would also sell quick on a mustang site. Up to you.
Old Jul 2, 2012 | 06:41 PM
  #726
Edgethis's Avatar
Edgethis
Ok thanks for the tip Dylan!
Old Jul 2, 2012 | 06:42 PM
  #727
GruesomeJeans
No problem. Good luck.
Old Jul 4, 2012 | 10:26 AM
  #728
Edgethis's Avatar
Edgethis
Well finally got a chance to work on the Bronco today. I had to get a puller as the remains of the bearing were stuck on the spindle.
I know that I'm missing a few teeth on the ABS ring, but I didn't have the sensors hooked up anyway. Prolly lucky I didn't as the ring ground into the actual sensor and ate it up real good. Prolly would've shorted something out.
http://www.flickr.com/photos/62639173@N03/7501548272/http://www.flickr.com/photos/62639173@N03/7501548272/ by http://www.flickr.com/people/62639173@N03/, on Flickr
And the spindle, I don't think it looks too bad. It really sucks because I got the wrong seal in the box when I picked it up.
http://www.flickr.com/photos/62639173@N03/7501548014/http://www.flickr.com/photos/62639173@N03/7501548014/ by http://www.flickr.com/people/62639173@N03/, on Flickr
So everything is back together and torqued. minus that wheel seal....I know, but I'll get that one soon here and fix everything again. Just didn't wanna leave the truck in pieces, plus I can safely move it now if need be.
I think what the issue was with the old bearing is that I bought all new rotor/hub assemblies with the races pre-installed. I think that possibly the pre-installed race didn't quite match the bearing I bought and that it may not have been seated all the way. it's all speculation, I should've checked when I got them anyway.
Here's to hoping it all holds together!
Old Jul 4, 2012 | 03:21 PM
  #729
Edgethis's Avatar
Edgethis
Ready to talk to a machine shop.
http://www.flickr.com/photos/62639173@N03/7503362918/http://www.flickr.com/photos/62639173@N03/7503362918/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Old Jul 5, 2012 | 08:51 AM
  #730
Edgethis's Avatar
Edgethis
Drove the truck today. GFs been driving it so of course its been neglected. There is a really bad exhaust leak. I'm gonna see if tightening everything down helps. Also has a terrible squeal, I think it may be the water pump. If so then a trip to the local advance will fix that. I think I need to replace the starter solenoid anyway.
Geez...
Old Jul 5, 2012 | 07:46 PM
  #731
Encho's Avatar
Encho
The Southernmost Mod
Do this to the starter solenoid: Unscrew it from the fender, and leave it hanging from the wires for the night. It made mine work like new... and I have no explanation other than maybe there was something stuck inside. It randomly worked, after that it worked everytime... and ever since.
Old Jul 5, 2012 | 08:34 PM
  #732
GruesomeJeans
Looks good so far brett, hopefully everything works out.
Encho, that is kind of odd. Maybe it is from something inside that grounds itself to the fender until you unbolt it?
Old Jul 6, 2012 | 01:54 AM
  #733
Encho's Avatar
Encho
No, it wasn't a bad ground, apparently my solenoid enjoyed being upside down for a night.
Old Jul 6, 2012 | 01:57 AM
  #734
SideWinder4.9l
Hmm...I was gonna ask if you shook it...To see if that was the issue, something loose inside...
Can't really imagine that'd do anymore than it absorbs in vibration from being a DD...
Maybe it's just a loco part?
Old Jul 6, 2012 | 02:05 AM
  #735
GruesomeJeans
Thats kind of weird.
