Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Sep 21, 2019 | 10:36 PM
  #1201
Mikeiby's Avatar
Mikeiby
Thanks, I will check that out,
Old Sep 21, 2019 | 11:17 PM
  #1202
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Hillbillysuv
Thank you Sir!
8002 // 8290
B8TZ-8002-A .. Tube-Radiator Supply Tank to Engine - 1.50" diameter / Obsolete
1958/72 C800/1100 & CT850/950 with 401/477/534 engines.
B9TT-8290-A .. Radiator Hose Extension Pipe-Upper - 2 1/4" I.D. x 9 1/2" long / Obsolete
1959/72 C/CT850/1100 with 401/477/534 engines.
No Ford dealer or obsolete parts vendor has either part, none on ebay.
Old Sep 22, 2019 | 05:53 AM
  #1203
Hillbillysuv's Avatar
Hillbillysuv
I more than half expected that.
Thank you for looking them up Sir.
Old Sep 22, 2019 | 07:23 AM
  #1204
Umpire PC's Avatar
Umpire PC
Source for LH Thread Lug Nuts. Flat Wheels P400 Olson Step Van
Hi Bill,
Vin # P40BV533779.
I have a 1973 Ford P400 Chassis Olson Step Van. The Driver Side Rear Dual Wheel has LH Thread Studs and Lug Nuts. The original wheels were 16.5 and "coined". I have switched to 16" flat face wheels due to
Found and Rescued. Brought back to life
the availability of tires. The "Coined" wheel lug nuts won't work on the new flat face wheels. I need to know if there are LH Thread Lug Nuts with a washer available to fasten the wheels to the existing studs?
Thank you,
Patrick Cassidy / Williamsport, PA
Old Sep 22, 2019 | 07:57 AM
  #1205
Hillbillysuv
Good looking step van.
I don't have any idea about those lug nuts but thought I'd throw this out there.
I used to have a Chevy based Grumman Olson. If you're looking for anything related to the body rather than the chassis/drive line I had decent luck with Mill Supply. I looked all over creation for a rear door hinge and rollers for the sliding door before stumbling across them. I haven't bought from them since about 2012 but they used to be fairly reasonable.
There might be better options now but at least it is a starting point.
Last edited by Hillbillysuv; Sep 22, 2019 at 08:00 AM. Reason: left out something.
Old Sep 22, 2019 | 10:14 AM
  #1206
NumberDummy
Originally Posted by Umpire PC
Hi Bill,
Vin # P40BV533779.
Thank you,
Same L/Rear lug bolts/nuts w/left hand threads as F350.
As original:
DOTZ-1119-A .. Left Rear Lug Bolt / Obsolete
NOS PARTS LTD in Waxahachie TX has 14 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 198 = 800-543-4959.
C7TZ-1121-A .. Left Rear Lug Nut-Use with DRW (Dual Rear Wheels) / Obsolete
OBSOLETE RELIABLE PARTS in Nashville GA has 6 = 229-686-5101.
NOS PARTS LTD has 16.
GREEN SALES CO. has 404.
Old Sep 28, 2019 | 12:31 AM
  #1207
elpound's Avatar
elpound
1981 f700 info
Hey Number Dummy! I just purchased a 81 F700 bucket truck. I have not seen the truck in person yet but my buddy sent me the title. He wasn't sure what motor it had. I was wondering about its info if you can go by the vin.
It's similar to the 81 fire truck I h
ad in that it has the marmon herrington Conversion.
1FDWF70HXBVJ05392
Old Sep 28, 2019 | 01:42 AM
  #1208
NumberDummy
I was wondering about its info if you can go by the VIN
It's similar to the 81 fire truck I have. It has the Marmon-Herrington Conversion.
1FDWF70HXBVJ05392
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
W = Class 6 - Air Brakes // 19,501-26,000 lbs. Gross Vehicle Weight Rating.
F70 = F700 (gas).
H = 370 2V or 4V (6.1L).
X = Check digit, FoMoCo use only.
B = 1981.
V = Kentucky Truck Assembly Plant.
J05392 = 1981 Numerical Sequence of Assembly, the trucks specific serial number.
Old Sep 28, 2019 | 02:23 AM
  #1209
elpound's Avatar
elpound
Thanks Number Dummy!
Old Oct 3, 2019 | 02:40 PM
  #1210
mercdiesel's Avatar
mercdiesel
VIN decode
Please decode this Serial number on a cabover
C50CVJ00583
WB 135
Model C504
Body A28
Trans A
Axle F2L
GVW 20000
HP 164
NPM??? 3800
DSO B48029
Thankyou
Old Oct 4, 2019 | 04:15 AM
  #1211
NumberDummy
Originally Posted by mercdiesel
Please decode this VIN and Warranty Plate codes on a cab over.
C50CVJ00583 // WB 135 / COLOR: Blank * / Model C504 / Body A28 / Trans A / Axle F2L / GVW 20000 / Cert net HP 164 / RPM 3800 / DSO B48029
C50 = C500 Tilt Cab (gas).
C = 330 2V Medium Duty FT engine.
J00583 = 1970.
135" Wheelbase.
COLOR: Blank.*
C504 = C500 Tilt Cab (gas), 20000 lbs. GVWR
A28: A2 = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 8 = 91B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F2L:
F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity.
L = Ford 6,000 lbs. Capacity Front Axle with Power Steering.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3800 RPM
B48029:
B4 = Ford Motor Co. of Canada Ltd., Midwestern Ford Division, where the original selling dealer ordered the truck from.
8029 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order. This makes the truck a Domestic Special Order.
Old Oct 11, 2019 | 08:04 AM
  #1212
Tenwheeler's Avatar
Tenwheeler
Mr Bill or anyone else have a lead on a pitman arm for a1993 L9000 ser# RVA20183. Number on arm is FOHZ-3590Z. I am told the Ford part number is FOHZ-3590C.
Old Oct 11, 2019 | 04:29 PM
  #1213
NumberDummy
Originally Posted by Tenwheeler
Mr Bill or anyone else have a lead on a pitman arm for a 1993 L9000 ser# RVA20183. Number on arm is FOHZ-3590Z.
R = 1994 / V = Kentucky Truck Assembly Plant / Last 6 digits of the VIN: A20183 is the Numerical Sequence of Assembly, the trucks specific serial number.
I am told the Ford part number is FOHZ-3590-C
No Ford dealer or obsolete parts vendor has any, none on ebay.
Old Oct 12, 2019 | 05:27 PM
  #1214
Tenwheeler's Avatar
Tenwheeler
Thanks for looking into that for me. I really appreciate that.
If anyone out there has a used one we would be very interested.
Old Oct 12, 2019 | 09:19 PM
  #1215
Destroked 450's Avatar
Destroked 450
What happened to the pitman arm?
Number Dummy what all years and models does it fit.
