Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Jul 22, 2019 | 10:20 PM
  #1141
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by poppatello
Hey Number, I’ve been trying to find info on the trans the 65 I’m trading for. I can’t seem to find anything on it. Do u have sources on those? Here is the vin as I don’t have the trans info handy without looking at another post. Also is this a decent driveline combo? Seems different then most I’ve seen on here...
TRANS code is L = Clark model 2651-V1 or 2653-V1 5 Speed Direct.
Old Jul 23, 2019 | 02:33 PM
  #1142
poppatello's Avatar
poppatello
Hey number, what kinds of normal wear items will I have trouble getting with a 65 N600? I know when I was looking at the early 70’s C trucks I found that brake drums were no longer manufactured and conversions needed to be done.
Old Jul 23, 2019 | 04:11 PM
  #1143
NumberDummy
Brake drums are non existent, all the other brake parts are available from NAPA and etc.
All the engine/trans/rear axle mechanical parts are available from NAPA and etc auto parts stores.
The cab and door weatherstrips have been reproduced, but the repro parts sellers (Carpenter etc) only list them for F100/350's.
1961/66 F100/1100 and 1963/69 N/NT500/1100 use the same cab. The N/NT series doors are cut off at the front for clearance purposes, but all the internal parts are the same. as F100/1100.
Old Jul 23, 2019 | 05:48 PM
  #1144
poppatello's Avatar
poppatello
So what is the option if u need brake drums?
Old Jul 23, 2019 | 07:41 PM
  #1145
85e150's Avatar
85e150
Read here, or try a medium truck scrap yard.
https://www.ford-trucks.com/forums/1...e-55-c600.html
Old Jul 27, 2019 | 05:12 PM
  #1146
roKWiz's Avatar
roKWiz
76 LN8000 chassis wiring diagram
Hey Bill,
Hope your fighting fit again.
Not sure supplying a VIN would help as this is an Australian assembled truck and thought I had this diagram.
Do you have a diagram of the rear chassis wiring harness or a wiring schematics of the same rear section of chassis for a 1976 LN8000 Louisville tractor. (prime mover)
I need to remake the rear harness myself from the back of the cab as this thing is a mess of old frayed wires.
Thanks in advance if you can help and much appreciated.
Old Jul 27, 2019 | 10:10 PM
  #1147
NumberDummy
Parts catalog pics of truck wiring harnesses are just terrible, try faxonautolit.com for a electrical wiring shop manual.
LN8000 is an LN800 w/a diesel engine.
Terrible:
Old Jul 28, 2019 | 10:14 PM
  #1148
roKWiz's Avatar
roKWiz
Thanks, good on ya Bill, its so much better than the one I didn't have !
Old Jul 29, 2019 | 09:35 AM
  #1149
Maxxman23's Avatar
Maxxman23
Hey Bill,
Can you tell me what I have here?
Thank You in advance!
-Adam
Old Jul 29, 2019 | 03:10 PM
  #1150
NumberDummy
Originally Posted by Maxxman23
Hey Bill, can you tell me what I have here?
F60 = F600 2WD (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
Y22107 = 1977.
182" Wheelbase.
I = Bright Medium Blue.
F602 = F600 2WD (gas), 19200 lbs. GVWR
AA8: AA = Black Vinyl - Full Width Seat / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F3J:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
J = Ford 5,000 lbs. Capacity Front Axle with Power Steering.
19,200 lbs. Gross Vehicle Weight Rating.
588043:
58 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
8043 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Aug 12, 2019 | 08:13 PM
  #1151
Onefordtruck's Avatar
Onefordtruck
1966 F-600 firewall mounted brake booster
I have a 66 F 600, 6 cylinder, 5 speed, standard axle truck. Started life as a " Truck, Tank, Aircraft Refueler, 1200 gallon tank, w / cab. Now has a lifting flat bed on it. It has a firewall mounted brake booster and has developed a vacuum leak. I'm not able to find a shop that can
identify the booster or any replacement. Can you help?
Gene
Old Aug 12, 2019 | 08:26 PM
  #1152
85e150's Avatar
85e150
WAG but you might be able to use a later model booster from an F350, late enough to carry a dual master if you desire. IIRC, preferably a dual drum brake master.
Stand by for more answers.
Old Aug 12, 2019 | 08:30 PM
  #1153
krewat's Avatar
krewat
FTE Leadership Emeritus
I had to look up what WAG means, as I've seen it a few times in the past few days - Wild *** Guess
Old Aug 12, 2019 | 09:06 PM
  #1154
Onefordtruck
What KREWAT said !! I didn't know what it meant either. Lol.
85E 150.....yes, I had considered doing something other than original. Have done plenty of upgrades on old cars and pick ups. And a dual master is very desirable. But I feel a little out of my league here. Seems like the upgrade would need to be matched to the existing brake components to work correctly and safely. I have recently seen another 66 F600, that was using an Expedition dual master and booster. A restored truck, it was a very neat installation. To convert, it may also use the pedal assembly under the dash, and proportioning valve. But have looked around for the article and can not find it. So for now just need to go back original. Thanks for suggestion....
Old Aug 12, 2019 | 11:07 PM
  #1155
NumberDummy
C4TZ-2005-M .. P/B Booster - 11.50" diameter - Located on firewall / Midland-Ross part number C-4029-J / Obsolete
C4TZ-2309-A .. P/B Booster Repair Kit / Use with C4TZ-2005-M P/B Booster / Obsolete
1964/66 F500/600 // No Ford dealer or obsolete parts vendor has either part.
Try NAPA or independent auto parts stores. Ask big truck repair shops in your area who rebulds P/B boosters.
