Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Sep 19, 2019 | 06:59 AM
  #1186
fyn409's Avatar
fyn409
I do not recall seeing anything there, but will check again tonight, thanks.
Old Sep 19, 2019 | 08:57 PM
  #1187
fyn409's Avatar
fyn409
Looked again tonight, all around the carrier and I am not seeing any other numbers.......
Old Sep 19, 2019 | 09:23 PM
  #1188
85e150's Avatar
85e150
Driver side axle tube inboard of spring? Can you see the Eaton PDF I linked to?
Old Sep 19, 2019 | 09:24 PM
  #1189
72rustwarrior's Avatar
72rustwarrior
Originally Posted by fyn409
Any thoughts on this rear? I need to replace the front seal and I would like to identify the seal number I need before tearing into it.
Thanks,
Ryan
I have used this site to help identify diffs:
https://www.differentials.com/techni...dentification/
maybe they can help you
Old Sep 19, 2019 | 09:26 PM
  #1190
85e150's Avatar
85e150
That appears to be all light duty stuff from Toyotas, F150s, maybe up to F350.
Old Sep 19, 2019 | 09:41 PM
  #1191
fyn409's Avatar
fyn409
I can see the PDF, I have looked it over and none of the number I am finding match up. I looked on the axle tubes front and back and cannot see any numbers.
Old Sep 19, 2019 | 09:43 PM
  #1192
85e150's Avatar
85e150
Serving suggestion: Pull the yoke and front of the diff to the point you can get to the seal. Look for numbers and search by those.
Some risk there, but otherwise you have a road oiler.
Old Sep 19, 2019 | 09:52 PM
  #1193
72rustwarrior
How old is this truck?
I'll try my luck, I'm an old econoline guy, but NumberDummy knows all...
If you go by 1972 numbers
Wheel Base 189" , f-600 series truck,390-2v-8cyl engine,made at Kentucky plant, paint color Medium Bright Aqua & Lt Blue, Chassy cab ,Transmission newprocess 435-4speed,of course 23,000GVW,the DSO is the district special order code, I can't find and axle code for "E34"
that's the best I can do with it
Old Sep 19, 2019 | 10:10 PM
  #1194
fyn409's Avatar
fyn409
Yea, that is kind of where we are at now. Going to try and pull the yoke this weekend.
Thanks,
Ryan
Old Sep 20, 2019 | 01:21 AM
  #1195
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Azlin
I'm new to this forum, but after reading through the messages it appears to me that NumberDummy has most if not all the answers, so I'm wondering if you would be so kind as to tell me what you can about this truck from decoding the VIN??? We are trying to find parts for it but everything we order is not right, leading us to believe the information we have is incorrect. Any help would be appreciated.
F61 = F600 2WD (gas).
H = 370 2V or 4V
V = Kentucky Truck Assembly Plant.
GA1132 = 1980.
3B = Midnight Blue Metallic.
584498:
58 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
4498 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
189" Wheelbase.
F612 = F600 2WD (gas), 23,100 lbs. Gross Vehicle Weight Rating.
AB8: AB = Blue all Vinyl - Full Width Seat / 8 =Conventional Cab.
A = New Process 435 4 Speed Manual Transmission.
E34:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,600 lbs. Rear Axle Capacity.
4 = Ford 7,000 lbs. or 12,000 lbs. Capacity Front Axle without Power Steering.
Old Sep 20, 2019 | 02:01 PM
  #1196
85e150's Avatar
85e150
Originally Posted by Mikeiby
Hi, I have a 82 F 600 with a 4 speed transmission that has a piece of speedometer cable in the speedometer gear assembly in the transmission. How do I remove the gear assembly from the transmission so I can get the piece of cable out?
You may not have to take the whole thing apart. The top cover comes off, and I'm pretty sure your can get a thorough visual tour of the entire transmission with that cover off. You might have a removable panel in the floor of your cab. This is an expanded view of the trans.
https://www.drivetrain.com/parts-cat...n-illustration
Old Sep 20, 2019 | 02:06 PM
  #1197
NumberDummy
I have a 82 F 600 that has a piece of speedometer cable broken off in the speedometer gear in the transmission. How do I remove the speedometer gear assembly from the transmission so I can get the piece of cable out?
The speedometer DRIVEN gear is located at the end of the cable in the trans. The speedometer cable housing has a bracket that attaches to the side of the trans w/a bolt.
The DRIVEN gear attaches to the cable with a clip.
Old Sep 21, 2019 | 07:21 PM
  #1198
Hillbillysuv's Avatar
Hillbillysuv
Numbers Dummy.
Any chance you'd have part numbers for the metal coolant pipes on a 63 SD engine in a C850. Mainly the one that goes between the coolant reservoir and the engine, as well as the one between the engine and upper radiator.
The ones for my reservoir is rough and the one for the rad has some weird fitting that looks to have been brazed in by a crosseyed howler monkey.
Sadly both are among the few things from my parts truck. I know I could just use a long flexible hose but I figured I'd see if someone is sitting on an old one anywhere first.
I'm going through the cooling system and so far everything looks good but those two.
Old Sep 21, 2019 | 08:44 PM
  #1199
NumberDummy
Originally Posted by Hillbillysuv
NumberDummy.
Pic: Type the basic part numbers you need and I'll get the complete part numbers and see if anyone has them.
Old Sep 21, 2019 | 09:55 PM
  #1200
Hillbillysuv
Thank you Sir!
8002
8290
