Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Aug 13, 2019 | 08:04 AM
  #1156
Onefordtruck's Avatar
Onefordtruck
Thank you for the fast answer, and part numbers. This brake booster issue has been ongoing for awhile. I contacted a shop in Pittsburg, PA, a while back, that specializes in big truck brakes. They rebuild boosters, but the cost, plus shipping was out of site, and no Warrenty..... We have a fleet pride here in SW MO, and they were no help at all.
In another thread I see " Matt07 " from last year. He posted the 2 different booster details from NAPA. So I've asked him how his worked out, if he purchased the 11 3/4 booster from them.
I also saw your comments on where I posted. I read a lot of info on this site, and posted where other members would have knowledge about my F 600. So was surprised when I received a message that it had been moved to the "PICK UP TRUCK SECTION"...?
Old Aug 18, 2019 | 04:49 PM
  #1157
Andy Martin's Avatar
Andy Martin
Please
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Please decode mine,sir.
Old Aug 18, 2019 | 08:09 PM
  #1158
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
VIN doesn't tell you much once it's decoded.
Warranty Plate riveted to the left door face below the latch, post a pic of it.
VIN: C91LVEJ7762
C91 = C900 Tilt Cab (gas).
L = 534 4V V8.
V = Kentucky Truck Assembly Plant.
EJ7752 = 1979.
Old Aug 18, 2019 | 08:31 PM
  #1159
Andy Martin
Welcome to FTE
VIN: C91LVEJ7762
L = 534 4V V8.
EJ7752 = 1979.
Will do sir, thank you for help, you are a legend.
Old Aug 19, 2019 | 03:19 PM
  #1160
Andy Martin
here you go, he wants 1500 for it.FYI 35000GVWR
Old Aug 19, 2019 | 04:22 PM
  #1161
85e150's Avatar
85e150
Andy, you nervous when you're taking those pictures? Like you're shaking or something....? Mighty blurry....ND can't decode what he can't read.
All that truck for $1500?
CDL and 534 parts availability drive the prices down on those I'd guess. 3 to 4 mpg maybe a factor as well.....
Old Aug 20, 2019 | 09:47 AM
  #1162
Aligater's Avatar
Aligater
Hi Bill, found a few more
C61BUF31806
175 J C611 4B91 M? 62D
32000 139 3600 160443
and
C60DUD27235
111 C C600 A 91 2 F3
20000 164 3800 A49472
Old Aug 20, 2019 | 10:02 AM
  #1163
Aligater's Avatar
Aligater
Looks like,
C91LVE47762
175 T C91 4 DA5? E FGP
35000 161667
Old Aug 30, 2019 | 06:45 PM
  #1164
lakeboy52's Avatar
lakeboy52
Hello, I'm Jerry, Lakeboy52.. I'm a new member, August 30, 2019. I have a 1975 C600 that I'm bringing back to life after being stored for 16 years, and looking for parts or parts outlets. Specifically,
She runs after a new water pump, gas tank flush, a set of plugs, and a new Holley carb. Now I need her to stop... Master cylinder needed
I'm currently in need of the Master Cylinder. Any thread recommendations, Parts outlets, etc., would be appreciated.
Old Aug 30, 2019 | 10:25 PM
  #1165
NumberDummy
NAPA, independent auto parts stores.
Almost all of the C series Tilt Cab parts are obsolete, can be very difficult to find...especially the brake drums and weatherstrips.
Old Sep 3, 2019 | 05:12 PM
  #1166
NumberDummy
Originally Posted by Aligater
C61BUF31806 // 175 / J / C611 / 4B91 / M? / 62D / 32000 / 139 / 3600 / 160443
C61 = C600 Tilt Cab (gas).
B = 300 1V I-6.
U = Louisville KY Assembly Plant.
F31806 = 1969.
175" Wheelbase.
J = Rangoon Red.
C611 = C600 Tilt Cab (gas), 32000 lbs. GVWR
4B91: 4B = Black all Vinyl / 91 = 91A Standard Cab.
M = Clark model 285V 5 Speed Direct.
62D:
62 = Timken model F106N Single Speed Rear Axle / 6.20-1 / 15,000 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
32,000 lbs. Gross Vehicle Weight Rating.
139 net HP @ 3,600 RPM
160443:
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
0443 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
C60DUD27235 / 111 / C / C600 / A91 / 2 / F3 / 20000 / 164 / 3800 / A49472
C60 = C600 Tilt Cab (gas).
D = 330 2V H/D FT engine.
D27235 = 1968.
111" Wheelbase.
C = Pure White.
C600 Tilt Cab (gas), 20000 lbs. GVWR
A91: A = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic // 91 = 91B Custom Cab.
2 = Clark model 282V 5 Speed Direct.
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
A49472:
A4 = FoMoCo of Canada Ltd., Midwestern Lincoln/Mercury Division, where the original selling dealer ordered the truck from.
9472 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Sep 5, 2019 | 10:17 PM
  #1167
elpound's Avatar
elpound
Hey Number Dummy! You have helped me before with my 68 N600. This time I'm looking for the hydroboost and brake master cylinder. If you could help I would greatly appreciate it! My warranty plate N60DUD02244 / WB: 199 / COLOR: UM / MODEL: N602 / BODY: 4381 / TRANS: 2 / AXLE: F2B / MAX GVW LBS: 20000 / CERT NET HP: 164 / RPM: 3800 / DSO: 422625:
Old Sep 6, 2019 | 02:06 AM
  #1168
NumberDummy
N60 = N600 (gas).
D02244 = 1968.
199" Wheelbase.
UM: U = Lunar Green / M = Wimbledon White.
4381: 43 = Charcoal Black Crush Vinyl & Charcoal Black Ladder Pattern Vinyl / 81 = 81A Standard Cab.
N602 = N600 (gas), 20000 lbs, GVWR
F2B:
F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.17 / 15,000 lbs. Rear Axle Capacity.
B = Ford 5,500 lbs. Capacity Front Axle.
422625:
42 = Fargo ND Ford District Sales Office, where the original selling dealer ordered the truck from.
2625 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Where is the brake booster, on the firewall or the frame rail?
Old Sep 6, 2019 | 03:33 PM
  #1169
elpound's Avatar
elpound
It's under the cab by the driver step.
Master cylinder on the firewall
Old Sep 6, 2019 | 04:28 PM
  #1170
NumberDummy
1964/69 N/NT500/850 with single hydraulic brakes:
D0TZ-2005-B (replaced C3TZ-2005-S) .. Remote Mounted 12.75" diameter Hydro-Vac P/B booster. / Bendix # 2503594 (replaced 2503258) / Obsolete
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 96 = 800-476-9653.
C3TZ-2140-L .. Master Cylinder / Obsolete
CARPENTER has 1.
Try NAPA or independent auto parts stores for both parts.
