Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Nov 3, 2019 | 08:13 PM
  #1246
Brshctr's Avatar
Brshctr
Originally Posted by Brshctr
The door had been replaced, thankfully he swaped the plate over to the replacement door, thank you so much for this info.
The wheels are 6 lug 20 inch not sure of the width, I'll have to check that.
Old Nov 9, 2019 | 09:52 PM
  #1247
cowdog86's Avatar
cowdog86
Hey numberdummy, can you decipher this vin for me please
F70EVHB1196
Thank you
Old Nov 11, 2019 | 11:03 AM
  #1248
OldSchoolSuperDuty's Avatar
OldSchoolSuperDuty
Hi Number Dummy,
Can you decode this VIN for me?
1FDYC90P7BVJ02521
Thanks,
-Nick
Old Nov 11, 2019 | 11:45 AM
  #1249
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by OldSchoolSuperDuty
Hi Number Dummy, can you decode this VIN for me?
34,000 lbs. Gross Vehicle Weight Rating.
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
Y = Class 8 - Air Brakes - 33,001-55,000 lbs. Gross Vehicle Weight Rating range.
C90 = C900 Tilt Cab (gas).
P = 534 4V (8.8L) Super Duty V8 engine.
7 = Check digit, FoMoCo use only.
B = 1981.
V = Kentucky Truck Assembly Plant.
J02521 = 1981 Numerical Sequence of Assembly, the trucks specific serial number.
99 = Not listed in the parts catalog.
112884:
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
2884 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
175" Wheelbase.
C904 = C900 Tilt Cab (gas), 34,000 lbs. GVWR
BS6: BS = Black Heavy Duty Vinyl with Gray Appointments - Full Width Seat / 6 = Tilt Cab.
SF = Spicer model CM-6052-C 5 Speed Direct.
DPP:
DP = Eaton model 23221 Two Speed Rear Axle / 6.17/8.40 / 23,000 lbs. Rear Axle Capacity.
P = Rockwell/Timken model FF-903 12,000 lbs. Capacity Front Axle with Power Steering.
Old Nov 26, 2019 | 07:08 PM
  #1250
Longbox Lecky's Avatar
Longbox Lecky
Trying to figure out more info on my C700 grain truck
vin: C70EUF57433
W.B: 153
Color: J
Model: C700
Body: A291
Transmission: 2
Axel: E3D
Max G.V.W: 24000
H.P: 182
RPM: 3800
D.S.U: B49097
thanks
Matt
AB. Canada
Old Nov 26, 2019 | 11:56 PM
  #1251
NumberDummy
VIN: C70EUF57433 // W.B: 153 / Color: J / Model: C700 / Body: A291 / Transmission: 2 / Axle: E3D / Max G.V.W lbs: 24000 / Cert Net H.P: 182 / RPM: 3800 / D.S.O: B49097
C70 = C700 Tilt Cab (gas).
E = 361 2V FT engine.
U = Louisville KY Assembly Plant.
F57433 = 1969.
153" Wheelbase.
J = Rangoon Red.
C700 Tilt Cab (gas), 24000 lbs. GVWR
A291: A2 = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 91 = 91B Custom Cab.
2 = Clark model 282V 5 Speed Direct.
E3D:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
24,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
B49097:
B4 = FoMoCo of Canada Ltd., Midwestern Ford Division, where the original selling dealer ordered the truck from.
9097 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Nov 27, 2019 | 08:25 AM
  #1252
rob_clay's Avatar
rob_clay
Whew, spent awhile browsing through this post. I just picked up a 1986 LTL9000? Ford Dump Truck. Bill, If you could decode the VIN I'd appreciate it. I am wanting to pick up service manuals/ parts manuals. Right now it has a 300 cummins, but the previous owner said he threw that in it used after the original cummins started having issues. I also am wondering if it is an eaton 9 speed. I need to get the gauges hooked up. speedo, tac, temperature gauges are all out.
1FDYA92W4GVA20833 this is the VIN on the title.
Thanks
Robert
Old Nov 27, 2019 | 11:42 AM
  #1253
NumberDummy
1FDYA92W4GVA20833
A92 = LTL 900 Diesel - Single Sleeper // 900 is a 9000 w/a diesel engine.
W = Cummins 855 cid 6 Cylinder (14.0L) Diesel (see W in pic below for the various types).
4 = Check digit, FoMoCo use only.
G = 1986.
A20833 = 1986 Numerical Sequence of Assembly, the trucks specific serial number.
TRANS, AXLE and etc codes printed on the Certification Label, glued to the left door face below the latch. Post a pic of it.
Considering this truck originally had a sleeper, the dump body was added later after the sleeper was removed.
Old Nov 27, 2019 | 01:55 PM
  #1254
rob_clay's Avatar
rob_clay
Thank you sir. Here's the sticker. I crawled under it today and did find a eaton sticker on the trans.
Old Nov 27, 2019 | 03:09 PM
  #1255
Destroked 450's Avatar
Destroked 450
What where the numbers on the Eaton tag.
It's odd the the Cummins NTC350 and NTC400 are not listed.
I had a 86 LTL-9000 with a Big Cam III NTC400 and Eaton RTO14613, 13 spd OD trans
Old Nov 27, 2019 | 04:00 PM
  #1256
NumberDummy
DSO: 464970
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
4970 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
222" Wheelbase.
TYPE/GVW A92480 = LTL900 (diesel), 48,000 lbs. Gross Vehicle Weight Rating.
BODY FA8: FA = Charcoal Cloth & Vinyl // 8 = Standard Cab.
TRANS CODE: None, trans was installed after the truck left the assembly line, making it a Domestic Special Order.
AXLE YRP:
YR = Rockwell model SQ100P Single Speed Rear Axle / 3.55-1 / 40,000 lbs. Rear Axle Capacity.
P = Rockwell model FF-903 12,000 lbs. Capacity Front Axle with Power Steering.
Old Nov 27, 2019 | 06:00 PM
  #1257
rob_clay's Avatar
rob_clay
Thank you very much. Here's the Engine and trans tag. Looks like Eaton RT-14609A.
Old Nov 27, 2019 | 09:02 PM
  #1258
NumberDummy
There's no Eaton transmissions listed for these trucks, only Clark, Fuller, New Process, Rockwell, Spicer and Warner.
Because there's no Eaton and the original purchaser wanted one, the truck was sent out after it left the assembly line to have it installed.
This makes the truck a Domestic Special Order, because this would have been the only way to discover what trans it had and where the parts could be found.
Old Nov 28, 2019 | 12:34 AM
  #1259
Destroked 450
Eaton owns the Fuller series transmissions
RT 14609A transmission is a 9 spd direct, no over drive
The engine is a NTC300 built in 1985
Old Dec 4, 2019 | 10:36 AM
  #1260
watongaokie's Avatar
watongaokie
Needing info
how about this one?
