Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Feb 10, 2020 | 01:36 PM
  #1276
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 85e150
Numberdummy has not been on the site since early December. He may be coming back, but this is a volunteer/hobby gig for him and everyone else contributing here.
I have removed the most recent unanswered posts and placed them in Large Truck.
The posts in this thread contain tons of information, including attachments or links to Ford parts and other manuals. You can use the search function to mine this forum for info.
This will be kept as a Sticky at the top for the time being. Hopefully it will be restored to a working thread soon.
Thanks for your support!
Thread restored. Thank you all again!
I'll decode these transferred requests later today. I'm only going to post in 2 or 3 forums from now on. I turned off the P/M feature, the email feature I turned off awhile back.
So the only responses I'll get is from members who already have my email. I was able to read your P/M, but cannot respond to it.
Old Feb 10, 2020 | 08:34 PM
  #1277
Destroked 450's Avatar
Destroked 450
Glad to see a response from you, I was getting worried.
Old Feb 10, 2020 | 08:56 PM
  #1278
BTBBT's Avatar
BTBBT
Bill, I was worried also. Glad you hear from you again. I understand about needing a break. We aren't machines.
Thanks again, though, for everything you contribute here.
Old Feb 12, 2020 | 08:45 AM
  #1279
cparker20093's Avatar
cparker20093
Hi, I’ve got two F700’s and one 50’s F100 that I would like the vin numbers decoded. I have the plate from one and the numbers are F70DVK52545
thank you very much in advance!
Old Feb 12, 2020 | 09:23 AM
  #1280
NumberDummy
I have the plate from one and the VIN is: F70DVK52545
F70 = F700 (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
K52545 = 1971.
Old Feb 12, 2020 | 09:28 AM
  #1281
NumberDummy
Originally Posted by ethanw04
Hello I have a LN750. Can you tell any information from this.
Impossible to read as it's been painted over. Take another pic after you use some steel wool to remove the paint from the codes, or type the info.
Old Feb 12, 2020 | 09:29 AM
  #1282
NumberDummy
Originally Posted by Phantomtruck68
Can you tell me what engine this truck came with origanally? The vin is 1FTYR82EXRVA20983
thank you.
I know its a 1994 LN8000.
I have no info for 1990 and later vehicles. Call Green Sales and ask them: 800-543-4959.
Old Feb 12, 2020 | 10:36 PM
  #1283
85e150's Avatar
85e150
Hello I have a ln750. Can you tell any information from this.
do you know what engine options was available for this model ?
N76EVJ45795
148 N760 A28 Q (orO) HHN
27500 182 3800 877865 (or B77865)
Old Feb 13, 2020 | 05:10 AM
  #1284
NumberDummy
N76EVJ45795
WB: 148 / COLOR: Blank * / MODEL: N760 / BODY: A28 / TRANS: Q (or O) / AXLE: HHN / MAX GVW LBS: 27500 / CERT NET HP: 182 / RPM: 3800 / DSO: B77865 (OP in Canada)
N76 = LN750 (gas).
E = 361 2V FT engine.
J45795 = 1970.
148" Wheelbase.
COLOR: Blank.*
N760 = LN750 (gas), 27,500 lbs. GVWR
A28: A2 = Light Gray & Medium Gray Vinyl // 8 = 81B Custom Cab.
O = Fuller model T905-B 5 Speed Direct or New Process model 542-FL 5 Speed Direct or Q = Dana/Spicer model 5652 5 Speed Direct.
HHN:
HH = Eaton model 17221 Two Speed Rear Axle / 7.17/9.77 / 18,500 lbs. Rear Axle Capacity.
N = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle with Power Steering.
27,500 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
B77865:
B7 = Ford Motor Co. of Canada Ltd., Pacific Lincoln-Mercury Division, where the original selling dealer ordered the truck from.
7865 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
* When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Old Feb 13, 2020 | 04:04 PM
  #1285
85e150's Avatar
85e150
Originally Posted by Springhill Auctioneers
Number Dummy,
Can you please help me with this Vin and let me know any information I may need.
Bump to the top.
Old Feb 13, 2020 | 04:46 PM
  #1286
NumberDummy
^ Post #1287 - Pic doesn't appear when post is quoted.
C90 = C900 Tilt Cab (gas).
L = 534 4V
Y07690 = 1977.
153" Wheelbase.
AT: A = Raven Black // T = Candyapple Red.
C904 = C900 Tilt Cab (gas), 27,500 lbs. GVWR
DA6: DA = Black Vinyl // 6 = Custom Cab.
7 = Spicer model CM-5052A 5 Speed Direct.
GQN:
GQ = Eaton model 17121 Single Speed Rear Axle / 6.50-1 / 18,500 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
431682:
43 = Milwaukee WI Ford District Sales Office, where the original selling dealer ordered the truck from.
1682 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Feb 13, 2020 | 05:18 PM
  #1287
85e150's Avatar
85e150
Looks like 1270 and 1271 are pending as well. Thanks for the updates!
Old Feb 13, 2020 | 05:24 PM
  #1288
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Bill, has anyone told you that you are awesome today?
Well, consider yourself told!
NumberDummy spinning Ford parts binders
Old Feb 13, 2020 | 06:05 PM
  #1289
NumberDummy
Originally Posted by Matthewwiggins
Could you decode this for me trying to find out some information on my 1981 thanks
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 Air Brakes - 26001-33000 lbs. Gross Vehicle Weight Rating range.
C80 = C800 Tilt Cab (gas).
H = 370 2V or 4V (6.1L).
3 = Check digit, FoMoCo use only.
B = 1981.
J41007 = 1981 Numerical Sequence of Assembly, the trucks specific serial number.
6S = Chrome Yellow.
113124:
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
3124 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
135" Wheelbase.
C802 = C800 Tilt Cab (gas), 27,500 lbs. GVWR
AS8: AS = Gray all Vinyl - Full Width Seat / 8 = 91B Custom Cab.
CD = Clark model 285 5 Speed Direct.
HHN:
HH = Eaton model 17221 Two Speed Rear Axle // 7.17/9.77 // 18,500 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs Capacity Front Axle with Power Steering.
Old Feb 13, 2020 | 06:30 PM
  #1290
NumberDummy
Exclamation
Originally Posted by BTBBT
22,000 lbs. Gross Vehicle Weight Rating.
N = Class 6 Hydraulic Brakes - 19501-26000 lbs. Gross Vehicle Weight Rating range.
F60 = F600 2WD (gas).
O = Check digit, FoMoCo use only.
H = 1987.
A05559 = 1987 Numerical Sequence of Assembly, the trucks specific serial number.
415378:
41 = Chicago IL Ford District Sales Office, where the original selling dealer ordered the truck from.
5378 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." No PAINT code, truck was painted a non standard color, the reason for this DSO
153" Wheelbase.
F60220 = F600 2WD (gas), 22,000 lbs. GVWR
HK8: HK = Black all Vinyl (Heavy Duty) / 8 = 81B Custom Cab.
AA = Allison model AT-545 Automatic Transmission.
TFM:
TF = Rockwell model RS-15-120 Single Speed Rear Axle // 6.14-1 // 15,000 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
