F60CK832260 // WB: 156 / COLOR: Blank / MODEL: F602 / BODY: 481 / TRANS: A / AXLE : B / MAX GVW LBS: 20000 / CERT NET HP: 164 / RPM: 3800 / DSO: 720323
I need 5 tie rodends one for the bendix ram 3332 this no is from a 73 f600 ram I think they are the same I think I have to disassemble the 4 inner and outer tie rods and measure length and threads thickness dont know what front axle it is all I know I've learned at the truck forum 1965 ford vs cal chp last operating truck I'n nor cal
As I told you in your other thread, the AXLE code has to have at least 2 digits. There in no code of just B
Are you saying the P/S has been swapped from another year truck?
F60 = F600 (gas).
C = 330 2V Medium Duty FT engine.
K = Kansas City MO Assembly Plant.
832260 = 1966, assembled March 1966.
156" Wheelbase.
COLOR: Blank (DSO special order).
F602 = F600 (gas), 20000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
B =
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
720323:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0323 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color, making it a Domestic Special Order.
This is a 1993 and I don't presently have a truck parts catalog after 1989 that I can access.
Thank you for the quick reply. I was really just hoping for the trans and axle code info as I can't find it anywhere. I'm about 6 hours from the truck so it's not as simple as quickly visiting the truck. I appreciate it anyway
Thank you for this!! The truck now has 90000 original miles, has a 391 installed by the Ford dealer in Parker, Az. in 1988 at 71000 miles. Has A/C under the dash. It has spent it's whole life in Arizona, hauling furniture from Las Angeles to Parker, Az. I am putting a 1000 gallon water tank on it to use for my off grid home in Az.
Just bought this F600 from the original owner. 73k miles and needs a few things but runs like a top even after sitting for the last 5 years and 50psi oil pressure. It even had the original ford truck owners identification card in it. Appreciate any extra info you can come up with beyond what I have gleaned from all the other great posts.
