Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Mar 25, 2020 | 03:59 AM
  #1321
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by aharleycpl
Just bought this F600 from the original owner. 73k miles and needs a few things but runs like a top even after sitting for the last 5 years and 50 psi oil pressure.
It even had the original Ford Truck Owners Identification card in it. Appreciate any extra info you can come up with beyond what I have gleaned from all the other great posts.
F60 = F600 (gas).
A = 330 2V Medium Duty FT engine.
K = Kansas City MO Assembly Plant.
696387 = 1965, assembled June 1965.
1?4" Wheelbase.
J = Rangoon Red.
F602 = F600 (gas), 20000 lbs. GVWR
M81: M = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic / 81 = 81A Standard Cab.
W = Clark model 2621-V1 or 2622-V1 5 Speed Direct.
F7C:
F7 = Eaton model 13802 Two Speed Rear Axle / 5.83/8.11 / 15,000 lbs. Rear Axle Capacity.
C = Ford-Rockwell/Timken 6,000 lbs. Capacity Front Axle.
20,000 lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Do not believe the miles shown on the odometer, as it reads to 99999.9 then returns to ZERO!
Old Mar 25, 2020 | 04:42 AM
  #1322
aharleycpl's Avatar
aharleycpl
F60 = F600 (gas).
Thanks for the great info. We know the owners and have the service records available on it and it hasn't rolled over yet. Was an orchard truck that ran 2 to 3 weeks a year then became a yard truck for a while at the warehouse. There it made runs of less than 3 blocks now and then. Just got to be too small for the operations and they run 40' flatbeds nowadays for about everything. They parked it because the brakes were intermittent. Supposedly work great first push of the pedal then brute force after that until she runs a ways. Sounds like a leak somewhere in the braking system vacuum so will throw a few parts at that to help it out. Got it started real quick today but couldn't drive it because tweakers stole the generator and voltage regulator. Gonna throw a GM alternator on it then roll it home on its road test.
Old Mar 25, 2020 | 04:56 AM
  #1323
NumberDummy
Two different types of power brakes on these trucks. The parts do not interchange.
The master cylinder bolts to the power brake booster on the firewall.
The master cylinder bolts to the firewall, the booster is a Hydro-Vac, located below the master on the frame rail.
Old Mar 25, 2020 | 05:20 AM
  #1324
aharleycpl's Avatar
aharleycpl
It has the master cyl with the booster under the drivers seat on the frame. One of the hoses looks a bit questionable. A line hooked to the booster that has ridges and what looks like an outer layer and inner layer of shielding. After we get her home which is about a quarter mile will track down what is causing the brake loss. Or maybe before then do some brake work. The E Brake has been on for 5ish years so it might take a bit to break it loose. Or we could get lucky.
Old Mar 26, 2020 | 05:56 PM
  #1325
cparker20093's Avatar
cparker20093
Thank you so so much!
F70 = F700 (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
K52545 = 1971.
Thank you thank you thank you! I finally got the vin for the 50’s Ford
97HY 288442 CS
thank you again in advanced I really appreciate it a lot!!
Old Mar 26, 2020 | 07:06 PM
  #1326
NumberDummy
Originally Posted by cparker20093
I finally got the vin for the 50’s Ford: 97HY 288442 CS
Ask in the 1948/56 forum, I don't have this info.
Old Mar 26, 2020 | 07:23 PM
  #1327
cparker20093
Thank you
Okay no problem thank you very very much again I really appreciate all your help. I still have one more F700 but I don’t have the vin handy at the moment I’ll see if I can get it tomorrow. Again thank you for your help!
Last edited by cparker20093; Mar 26, 2020 at 07:24 PM. Reason: Finger slipped and I pushed submit on accident
Old Mar 27, 2020 | 05:29 PM
  #1328
cparker20093
I finally got the other vin
I just went and looked at the other VIN for the other F700. Now I don’t know if this is the original door or not. The truck has 3 different paint schemes going on. Where else could I find a vin on it? None of my trucks came with existing registrations or anything so that doesn’t help and the kids I got them from were clueless on them so here’s the vin:
F70DVJ22921
Again thank you for all your help!
Old Mar 27, 2020 | 06:15 PM
  #1329
85e150's Avatar
85e150
Passenger side frame rail on top about even with the alternator, possibly further back and even under the passenger footwell under the cab. Wire brush, mirrors etc.
Old Mar 28, 2020 | 03:20 AM
  #1330
NumberDummy
F70DVJ22921
F70 = F700 (gas) // D = 330 2V Heavy Duty FT engine // V = Kentucky Truck Assembly Plant // J22921 = 1970.
Old Mar 28, 2020 | 06:05 AM
  #1331
joe_mamma's Avatar
joe_mamma
1980 C600
Thank You in advance
Old Mar 28, 2020 | 07:16 AM
  #1332
NumberDummy
17,000 lbs. Gross Vehicle Weight Rating.
C60 = C600 Tilt Cab (gas).
H = 370 2V or 4V (6.1L).
JA7381 = 1980.
22 = Rangoon Red.
48 = Detroit MI Ford District Sales Office, where the original selling dealer ordered the truck from.
153" Wheelbase.
C602 = C600 Tilt Cab (gas), 17,000 lbs. GVWR
BS8: BS = Black Heavy Duty all Vinyl with Gray Appointments // 8 = 91A Standard Cab.
NA = New Process 435 4 Speed Manual Transmission.
63M:
63 = Rockwell/Timken model F-106 Single Speed Rear Axle / 6.14-1 / 15,000 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
Small pic hard for 75 1/2 year old eyes to make out, even w/a 27" screen.
Old Mar 28, 2020 | 07:38 AM
  #1333
joe_mamma's Avatar
joe_mamma
thank you, this is very helpful. Sorry about the small picture, I did have the option to make it bigger but chose that one. They must have repurposed this truck, it now has a Clark transmission with a Muncie pto and an Eaton 2 speed rear axle
Joe
Old Mar 30, 2020 | 10:06 PM
  #1334
Defbob's Avatar
Defbob
I am looking at a 1990 LTL9000 this weekend.
Vin: 1FTYA90WXLYA20742
WB: 204
Type: A90480
Body: PG8
Trans: ES
Axle: 6E
Ext PNT: MR
DSO: 029611
Old Mar 31, 2020 | 07:24 AM
  #1335
NumberDummy
VIN: 1FTYA90WXLYA20742
EXTERIOR PAINT COLORS: MR // DSO: 029511
WB: 204 // Type/GVW: A90480 // Body: PG8 // Trans: ES // Axle: 6E
Sequence rearranged as it appears on the Certification Label.
I have two questions before I decode this jazz.
1) Are you sure the VIN begins with 1FT? Usually it begins with 1FD on 600 and larger series trucks.
2) There is no DSO code that begins with 0 (zero) or the letter O
