Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Oct 30, 2019 | 03:45 PM
  #1231
BroncoDave's Avatar
BroncoDave
Ford N700 door tag decode
I recently recovered my uncle's stake truck from a barn that was about to fall down on his farm. I remember this truck from my childhood, but I don't know anything about it. I would greatly appreciate any info you are able to provide. I'm sure I will be back requesting parts help when I dig into this project in the spring.
Thanks much!
Dave
Old Oct 30, 2019 | 08:31 PM
  #1232
dmtanderson's Avatar
dmtanderson
1970 f600
Thanks
Just got today. Online is not helpful.
Old Oct 31, 2019 | 08:22 PM
  #1233
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by searay60
new to me, any help would be appreciated
F00 = F1000 (gas).
L = 534 4V
U = Louisville KY Assembly Plant.
F55300 = 1969.
146" Wheelbase.
J = Rangoon Red.
F000 = F1000 (gas), 32000 lbs. GVWR
D81: D = Black all Vinyl / 81 = 81B Custom Cab.
U = Dana/Spicer model 6852-G 5 Speed Direct.
DPE:
DP = Eaton model 19221 Two Speed Rear Axle / 6.17/8.40 / 23,000 lbs. Rear Axle Capacity.
E = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle w/o Heavy Duty Front Brakes.
32,000 lbs. Gross Vehicle Weight Rating.
235 net HP @ 3,000 RPM
87 = Purchased by a Body Company.
Old Oct 31, 2019 | 08:38 PM
  #1234
NumberDummy
N70 = N700 (gas).
E = 361 2V FT engine.
E15065 = 1969.
199" Wheelbase.
J = Rangoon Red.
N700 (gas), 22,000 lbs. GVWR
4C81: 4C = Black all Vinyl / 81 = 81A Standard Cab.
M = Clark model 285V 5 Speed Direct.
54D:
54 = Rockwell model H170 Single Speed Rear Axle / 6.83-1 / 17,500 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
22,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
33 = Detroit MI Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Oct 31, 2019 | 08:51 PM
  #1235
NumberDummy
Exclamation 1971 F600
Originally Posted by dmtanderson
Thanks
F60 = F600 2WD (gas).
C = 330 2V Medium Duty FT engine.
V = Kentucky Truck Assembly Plant.
M20001 = 1971 (1971 F100/750 serial number range: J70001-M30000).
156" Wheelbase.
G = Chrome Yellow.
F602 = F600 2WD (gas), 20000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
64 = Rockwell model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
76 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Nov 1, 2019 | 12:28 PM
  #1236
BroncoDave's Avatar
BroncoDave
Thank you, sir!
Old Nov 1, 2019 | 09:20 PM
  #1237
Joshua Cline's Avatar
Joshua Cline
71 f600 pto Info
I have a 71 f600 that was converted to a hydraulic dump truck from a 30ft u-haul. I would truly appreciate any info regarding the options for the pto pump that was installed. I currently cannot raise the bed to do any cleaning or to find the stamp or plate etc. In the process of rebuilding the carb and locating a fuel pump. Any info on the pto or even the best way to go about finding it on my own would really help me.
Old Nov 1, 2019 | 11:35 PM
  #1238
NumberDummy
Ford did not sell PTO's, so I cannot help you. See if you can find a name on it....post it, then someone else may know.
I read your posts in the New Member Introduction Forum, there were two different 330 engines, post the VIN to determine which one your truck has.
Old Nov 2, 2019 | 01:41 AM
  #1239
Joshua Cline
Here is the VIN. Also, I am going to do a very thorough cleaning of the entire undercarriage once I am able to raise the bed. I will post all of the information that I discover once its clean.
Old Nov 2, 2019 | 04:02 AM
  #1240
NumberDummy
F61 = F600 2WD
D = 330 2V Heavy Duty FT engine.
E = Mahwah NJ Assembly Plant.
L80178 = 1971.
Original carburetor: Holley 2V
Old Nov 3, 2019 | 06:57 PM
  #1241
Brshctr's Avatar
Brshctr
77 F600
I would love to have any info you have for vin# F60DVY60119.
Also,I am in need for Wheel studs and lug nuts for the left front wheel, any chance any are available?
Old Nov 3, 2019 | 07:26 PM
  #1242
NumberDummy
Originally Posted by Brshctr
I would love to have any info you have for VIN F60DVY60119.
Also, I am in need for Wheel studs and lug nuts for the left front wheel, any chance any are available?
Probably from NAPA
F60 = F600 2WD
Y60119 = 1977.
VIN doesn't tell you much once it's decoded. Warranty Plate riveted to the left door face below the latch, post all the info stamped on it.
Studs/nuts: I need the AXLE code stamped on the 2nd line-far right on the Warranty Plate, also need to know the size of the wheel, how many studs/nuts it has (usually either 5 or 6).
Old Nov 3, 2019 | 07:32 PM
  #1243
searay60's Avatar
searay60
F00 = F1000 (gas).
L = 534 4V
F55300 = 1969.
146" Wheelbase.
J = Rangoon Red.
DPE:
Thank for the help, I’m sure I’ll be needing more as this project moves forward.
im interested in shop manuals, parts lists for this truck if there is such a thing. I will be doing a body off restoration
Old Nov 3, 2019 | 07:39 PM
  #1244
NumberDummy
1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com
Try faxonautolit.com for a shop manual, owners manual, sales brochure and etc. paper ephemera that silverfish love to feast on.
Old Nov 3, 2019 | 08:04 PM
  #1245
Brshctr's Avatar
Brshctr
F60 = F600 2WD
Y60119 = 1977.
The door had been replaced, thankfully he swaped the plate over to the replacement door, thank you so much for this info.
